• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » [CC2500] Error floor at 500 kB with good RSSI
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Arnaud Bouttier
Posted by Arnaud Bouttier
on Aug 10 2012 10:56 AM
Prodigy20 points
I am currently testing the 500 kB capability of the CC2500 chip at 2.4 GHz using the SmartRF04EB board. I started with the ex_link2 example provided with tool to perform a simplex transmission at 500 kB. The chip was configured with the settings provided by SmartRF Studio for 500 kB. The 2 SmartRF04 EB are interconnected through a coaxial cable to avoid any external noise and multipath. The Tx noise level is set to get an RSSI between -30 to -50 dBm (the issue is actually the same). I modified the ex_link2 example to perform testing over many packets (60000). This basic test generates a few CRC errors while it should not do so (with an RSSI of -30 dBm, the SNR shoud be good enough to ensure a reliable transmission). This occurs for packet lengths of 10, 30 and 50 bytes. I have tried a large number of register configurations that somehow gave some improvement but never an error free transmission. I initially though that my code could be faulty. I ended up by testing the 500 kB transmission using the Packet test of the Smart RF Studio tool. I you select the 500 kB default configuration registers, set an infinite number of packets with length 30 B, a TX power for having an RSSI of -30 dBm, if you leave the code run (a very long time) to transmit more than 10000 packets, you will obtain a few errors. I have really tried many configurations (longer preamble, fixed packet length, CS, PQT, all timing and freq offsets configurations, different PA and AGC settings - what for over a cable !! - and always this error floor at good SNR.
In my understanding, this could be related to some mismatches between the Tx and Rx crystals of the CC2500EM. The errors are relatively systematic (same byte) - thus it is not related to noise. I implemented a software frequency offset compensation algorithm and when I put my finger on the crystal for quite a long time, I see the frequency offset drifting (this is normal as it is not a VCXO oscillator) and the PER increases. The issue is that the default settings for 500 kB proposes to set BSCFG.BS_LIMIT to 0, i.e. without timing compensation at 500 kB !! It may occur that due to phase noise in the crystals, we may have some bad behavior of the time synchronization. I tried many other configurations for the time sync., and indeed, it gives more CRC errors.
I am wondering if somebody has already tested thoroughly the  500 kB mode with the CC2500 chip. Have you ever met this issue of error floor and how did you solve it. Ultimately, could you confirm that the CC2500 is not reliable enough for 500 kB transmissions, at least without controlled oscillators without good phase noise ?
With my best regards,
Arnaud
CC2500 2.4 GHz PER 500 kB error floor
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sverre
    Posted by Sverre
    on Aug 10 2012 11:01 AM
    Genius14060 points
    The following link describes the same issue when using CC1101 at 500 kBaud. https://e2e.ti.com/support/low_power_rf/int-low_power_rf/f/162/p/197597/731798.aspx?Redirected=true
    Increased AGCCTRL0.FILTER_LENGTH and setting AGCCTRL0.HYST_LEVEL = 3 seems to get rid of the "grey holes". Setting AGCCTRL0 = 0xF3 should hopefully show an improvement . Try also with AGCCTRL2 = 0xC6 instead of 0xC7 in combination with AGCCTRL0 = 0xF3.
    Report Abuse
    • Reply
  • Arnaud Bouttier
    on Aug 13 2012 02:03 AM
    Prodigy20 points
    Many thanks for providing an answer. Unfortunately, this parameter set does not change anything in the issue. Recall that the test is performed over a cable. I have checked that the RSSI value appended at the end of the faulty packets is correct and similar to those of good packets.
    By the way, the link provided in the feedback does not seem to work. I would be very interested anyhow to have a deep look on it.
    Arnaud
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
