• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » CC1101-1190 Ref Design - GDOx Usage
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Dave Matus
Posted by Dave Matus
on Aug 13 2012 11:15 AM
Prodigy170 points
I am a first time user of the TI Chipcon products and am trying to use the CC1101_CC1190EM 869MHz reference design to layout a "daughter board (DB)" that is to communicate with a "mother board (MB)" via Asynchronous Serial operation.  An additional requirement is that the DB interface with the SmartRF development board (via 4-wire SPI).  The ref design uses GDO0 and GDO2 to set two of the CC1190 control signals (PA_EN & LNA_EN) while the third control pin (HGM) can be hardwired to GND/VDD.  The CC1101 part spec recommends using GDO0 and GDO2 for asynchronous serial operation.   Other than using an external MCU, is there a way for the GDOx lines to be used to:  1) use asynch serial comm,  2) control the CC1190 and 3) interface with SmartRF ?  Any suggestions/recommendations would be appreciated.  Dave
# CC1110 #CC1111 design
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • TER
    Posted by TER
    on Aug 13 2012 13:09 PM
    Mastermind21710 points
    You need two GPIOs for asynchronous mode and you need two control signal to control CC1190. So you need some control signals from the MCU.
    PS. Thank you for clicking  Verify Answer  if this answered your question!
    Report Abuse
    • Reply
  • Dave Matus
    on Aug 13 2012 14:52 PM
    Prodigy170 points
    TER,
    The daughter board (DB) I am designing based on the ref design will connect to a separate mother board (MB) via a 60 pin male connector.  To interface the DB with the SmartRF development system, I envision an adaptor board with a 60 pin female connector on one side.  On the other side of the adaptor board will be the P1 and P2 connectors from the ref design which will plug into the SmartRF board.  During development with the SmartRF, the DB will be on top, the adaptor board in the middle and the SmartRF board on the bottom.  In the product application, when the DB is connected to only the MB, the 4-wire SPI interface pins will not be used.  Is it possible to use one or more SPI pins to control the CC1190  when the DB is not connected to the SmartRF ?
    I have never used the CC1190 part, but I assume that the PA_EN & LNA_EN pins cannot be hardwired to GND or VDD since their states need to continously change depending on whether the CC1190 is in the RX or TX mode.  Is this correct ?
    Obviously, I am trying to avoid adding additional circuitry to the ref design and would like to look at other ways of doing 1) asynch serial comm, 2) CC1190 mode control and 3) SmartRF interface from the existing ref design.
    Dave
    Report Abuse
    • Reply
  • TER
    Posted by TER
    on Aug 14 2012 00:46 AM
    When using the reference design together the TRXEB some of the MSP430 IOs are routed to the EB connectors to control the CC1190.
    The HGM pin on CC1190 normally will be hardwired to Vdd. PA_EN and LNA_EN controls the PA and LNA and have to be controlled either by CC1101 or a MCU. If you intend to use asynch serial mode you only need one IO for this making it possible to use the two others for controlling the CC1190. Note that GDO1 is shared with the SPI interface.
    Report Abuse
    • Reply
  • Dave Matus
    on Aug 14 2012 12:04 PM
    Prodigy170 points
    TER,
    Could you please explain exactly your idea about how to use only GDO1 for asynchr serial communication.  The Mother Board (MB) that I need to interface with has two pins, RXD & TDX.  In the CC1101 part spec (p,63/98, sec27.1) it only refers to using two I/O pins for asynch serial operation,  "In TX, the GDO0 pin is used for data input (TX data).  Data output (RX data) can be on GDO0, GDO1 or GDO2".  I was thinking that I needed to use GDO0 to receive data from the MB and either GDO1 or GDO2 for transmitting data to the MB.  How would you propose to use only a single pin (GDO1) to do asynch serial operation ?   Please be specific.  Incidently, I was only aware of the SmartRF04EB and not the TrxEB.  I will look into the TrxEB and determine if it is a better fit for my application.  Thanks.
    Report Abuse
    • Reply
  • Timothy Barr
    Posted by Timothy Barr
    on Aug 16 2012 13:23 PM
    Expert2445 points
    I think that there are seperate LNA and PA control signals mainly to be able to shut down both sections for low power applications. I bet you can use one signal to control both, by using an inverter on the LNA enable line. You just would have a higher power usage because the LNA would be on when in receive mode or idle, instead of just during a recieve.
    Tim Barr
    Multitech Systems Inc
    Report Abuse
    • Reply
  • Dave Matus
    on Aug 17 2012 09:25 AM
    Prodigy170 points
    Thanks Tim, I had the same idea about possibly using an inverter and one line to control LNA_EN and PA_EN.  I was hoping to find a posting on the Forum from someone who actually tried this approach sucessfully.
    My main question still relates to TER-TI Employee's response that "you only need one I/O line to implement asynch serial mode instead of two".  As I indicated earlier, I need to interface the CC1101 with a mother board with RXD and TXD connections.  Can someone clarify how asynch serial can be done on the CC1101 with only one I/O line instead of two.
    Report Abuse
    • Reply
  • TER
    Posted by TER
    on Aug 19 2012 00:39 AM
    What I was thinking was to use GDO0 for both RX and TX
    Report Abuse
    • Reply
  • Dave Matus
    on Aug 19 2012 18:02 PM
    Prodigy170 points
    TER,
    Please provide a few more details,  For example, would you set the CC1101 to be in asynch serial RECEIVE to start and wait for a message from the master  then change to TRANSMIT ?  What type of h/w would you use to connect the one GDO0 pin to the two RDX and TDX pins of the master ?  Do you know of any TI design notes, ref designs or examples that I could follow ?  Thanks,  Dave
    Report Abuse
    • Reply
  • TER
    Posted by TER
    on Aug 21 2012 03:19 AM
    We have done some software examples (nopt yet released) for the TRXEB board with CC1120 where we use only one IO on the MSP430 for RX/TX. If CC1101 should start being in RX or TX depends on your protocol, not on if one or two GDO pins are used. The CC1101 has to be set in RX or TX either way.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
