• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » Is CC430 compatible with IEEE802.15.4 standard?
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
jan2809
Posted by jan2809
on Jan 09 2011 23:13 PM
Expert2740 points
Befor I go deeper into CC430F6137 development can someone confirm/deny if it is compatible with
IEEE 802.15.4 standard (PHY)?
Unlike with other transceivers it is not specify (datasheet) that it does.
I see it supports ASK modulation, but does it have DSSS built in?
Is there a MAC stack for CC430?
Is there any progress on TI's 6LoWPAN?
Any pointers will be appreciated.
Jan
IEEE 802.15.4 CC430
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RF
    Posted by RF
    on Jan 10 2011 10:22 AM
    Intellectual930 points
    Hi Jan,
    No, the CC430 is not compatible with the 802.15.4 standard. It uses the same radio as the CC1101 which is not a DSSS radio. It can be used for proprietary protocols with 2-FSK, 4-FSK, GFSK, MSK or OOK.
    As far as I know, there are very few 802.15.4 radios available for the 900MHz band, even though the standard includes that band (TI doesn't have any). The 2.4GHz band is more globally available and has more bandwidth available. The standard for 900MHz uses a lower data rate for narrower bandwidth.
    For a stack you can use SimpliciTI on the CC430, which is a simple, proprietary network protocol stack from TI.
    Russ
    Report Abuse
    • Reply
  • jan2809
    Posted by jan2809
    on Jan 10 2011 16:06 PM
    Expert2740 points
    Hi Russ,
     Thank you for that explanation.
    I was confused after seeing an advertisement from Sensinode about their 6LoWPAN stack running on CC430. I had an impression
    that 6LoWPAN runs on top of 802.15.4 PHY and MAC. Am I right or not necessary?
    As I am investigating 6LoWPAN and 802.15.4 transceivers, can I ask you what are the best 802.15.4 radio transceivers?
    I know of CC2520 from TI/Chipcon and ATRF231 from Atmel (both for 2.4GHz)
    Jan
    2.4GHz sub 1GHz 802.15.4 6LoWPAN transceivers
    Report Abuse
    • Reply
  • RF
    Posted by RF
    on Jan 11 2011 10:45 AM
    Hi Jan,
    Sorry but I don't know much about 6LowPAN as I have never used it.
    Regarding the best 802.15.4 radios - of course TI's are the best :). I have used the CC2520 in a few projects with great success. I have looked at the Atmel radios and they look good but I have not used one in a project yet. One interesting feature I liked the looks of in the Atmel radios is the antenna diversity option. That could be a great feature for some applications.
    Good luck,
    Russ
    Report Abuse
    • Reply
  • TA12012
    Posted by TA12012
    on Jan 13 2011 06:53 AM
    Expert8395 points
    All,
    TI is getting ready to release a 6LoWPAN development kit based on the CC1180 and CC430 series Sub-1GHz devices. We are in the process of finalizing the documentation and release it. You will be able to find more information about the kits at:
    http://processors.wiki.ti.com/index.php/CC-6LoWPAN
    You will find when reading the Wiki that 6LoWPAN is not fixed to any specific PHY. 6LoWPAN is just a standards based method for reducing the networking overhead of IPv6 for use in memory/speed constrained system. It is possible to run 6LoWPAN on 802.15.4 or 802.15.4g or even PLC.
    /TA
    Please click the Verify Answer
     button on this post if it answers your question.
    Report Abuse
    • Reply
  • Derek9531
    Posted by Derek9531
    on Jan 13 2011 12:42 PM
    Genius5510 points
       Where is information on the CC1180?
    --Derek
    fixituntilitsbroken.blogspot.com
    Report Abuse
    • Reply
  • TA12012
    Posted by TA12012
    on Jan 15 2011 05:44 AM
    Expert8395 points
    Derek,
    Please contact your local FAE or TI Sales reps for more information about the CC1180.
    /TA
    CC1180
    Report Abuse
    • Reply
  • jan2809
    Posted by jan2809
    on Jan 16 2011 16:56 PM
    Expert2740 points
    Hi TA,
     Thanks for that info and link.
    Can you be more specific about the time-frame, is it a matter of months or weeks?
    Does the stack come with source code or binary only?
    Jan
    Report Abuse
    • Reply
  • TA12012
    Posted by TA12012
    on Jan 16 2011 20:02 PM
    Expert8395 points
    Jan,
    Thanks for your interest. We are in early adopter sampling phase now and it will be generally available in late Q1. There are two options:
    1. The CC1180 is a network processor and is used in conjunction with a separate applications processor (using simple API calls with source)
    2. The CC430x is a library in binary format where your final application can run along the network protocol.
    For both cases we have prepared examples for you get started with.
    /TA
    Report Abuse
    • Reply
  • Firefighter
    Posted by Firefighter
    on Jan 18 2011 02:07 AM
    Expert5430 points
    Jan,
    In addition to TA's comments; the TI/Sensinode development kit will be using a early-version of 802.15.4g frame format. I.e we'll implement as much support for 802.15.4g as possible on the CC1180/CC430 HW.
    /Jonas
    CC430 6LoWPAN CC1180
    Report Abuse
    • Reply
  • jan2809
    Posted by jan2809
    on Jan 18 2011 15:36 PM
    Expert2740 points
    TA, Jonas,
     Good to hear that TI is taking seriously that part of Low Power RF (6LoWPAN) and thanks for all the information provided.
    I contacted my local TI people (both Sydney and Melbourne)  as advised by TA to ask for more info on CC1180, however they are struggling to find any.
    Would it be possible to pass the above mentioned documentation to them Down Under so they can pass it to me and others?
    Again, appreciate your support.
    Jan
    2.4GHz sub 1GHz 802.15.4 6LoWPAN transceivers CC1180
    Report Abuse
    • Reply
  • Firefighter
    on Jan 19 2011 02:00 AM
    Expert5430 points
    All,
    Since CC1180 is not yet a released part it not possible to share the datasheet yet. As TA mentioned above you can find more information on the developer wiki: http://processors.wiki.ti.com/index.php/CC-6LoWPAN
    /Jonas
    Report Abuse
    • Reply
  • jan2809
    Posted by jan2809
    on Mar 14 2011 17:18 PM
    Expert2740 points
    Is there any progress on it?
    "TI is soon to release a development kit based on TI hardware and Sensinode software for the 868/915 MHz band, utilizing CC430 or the network processor CC1180"
    Jan
    Report Abuse
    • Reply
  • jan2809
    Posted by jan2809
    on Mar 14 2011 22:17 PM
    Expert2740 points
    I am looking here http://processors.wiki.ti.com/index.php/CC-6LoWPAN#What.27s_included_in_the_kit.3F
    There are 2 diagrams under  6LoWPAN and IPv6 Basics section, specifically:
    6LoWPAN CC1180 WNP Stack and 6LoWPAN CC430 Stack
    There is a box saying IEEE 802.15.4 Radio within CC1180 and same within CC430Fx (and it was said before, they are not 802.15.4 radios)
    How to interpret it?
    Jan
    Report Abuse
    • Reply
  • Cristian Prundeanu
    Posted by Cristian Prundeanu
    on Apr 14 2011 22:23 PM
    Prodigy80 points
    I'd also like to know if there is any time frame that can be shared at this point.
    Also, is it possible, as part of the early adoption stage, to get a 6LoWPAN unit or two to play with?
    Thank you,
    Cristian
    RF msp430 6LoWPAN CC1180
    Report Abuse
    • Reply
  • Firefighter
    on Apr 15 2011 02:59 AM
    Expert5430 points
    Targeted release for CC-6LOWPAN-DK-868 is 2H11.
    Contact your local TI sales representative for information on the Early Adopters program.
    Cheers,
    Jonas
    6LoWPAN CC1180
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
