Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » CC1101 modem configuration 2-FSK vs GFSK vs MSK.
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 2 Replies
  • 3 Subscribers
  • 1231 Views
  • Postedover 1 year ago
Options
  • Subscribe via RSS
Tags
  • # CC1110 #CC1111 design
  • # CC1110 #CC1111 design SPI
  • #sniffer #CC1111
  • "Flash Programmer"
  • "front-end"
  • _D_CODE_START
  • 0402 0603
  • 0-ohm resistors
  • 1.27 mm
  • 100 mW
  • 125 degrees
  • 15.4
  • 16 bit
  • 16 kB
  • 169 MHz
  • -174
  • 1Ghz or 2.4Ghz
  • 1W
  • 2.4 GH
  • 2.4 GHz
  • 2.45 GHz
  • 2.4GHz
  • 2.4GHz antenna
  • 2.4GHz antenna design
  • 2007
Forum - Title
Welcome to the Low Power RF & Wireless Connectivity Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Announcements
  • Forums
  • Files
  • Design Notes
New Post
This question is not answered
M MAR
Posted by M MAR
on Feb 10, 2011 5:20 AM
Intellectual895 points
I see the CC1101 transceiver can be configured for several modulation formats, of which the more interesting one for me are :
2-FSK
GFSK
MSK
My question relates to the statement in the CC1101 documentation that "MSK is only supported for data rates above 26kBaud''.
I am currently trying out the CC1101 with a modulation configuration of GFSK with a frequency deviation (fd) which is 1/2 the bit-rate (rb), which conforms to the condition for coherent FSK/MSK, where fd = 1/2 x rb. The bit rate of my CC1101 modem is configured so that I essentially transmit an MSK signal by setting the fd = 1/2 x rb but with the GFSK modulation configured in the MDMCFG2 register.
So my question relates to this settings - can I essentially obtain an MSK modulation by using the GFSK configuration, but with a setting of fd = 1/2 x rb for the deviation and data rate settings ?? Will the receiver modem be capable of coherent FSK demodulation in this mode ? or do I really need to configure both the modems (Tx & Rx) for MSK (with the 26kb/s data rate limit) ??
Essentially, the spectral efficiency that I seek is important, and I would like to obtain best sensitivity with the best spectral efficiency, but it is not entirely clear which modem configurations would yield these two optimal conditions I seek, and if my above settings would give me GMSK communication for instance ??
Can somebody please clear this up for me ? Can I "emulate" GMSK modulation with the fd = 1/2 x rb settings with GFSK modem configuration in the
MDMCFG2 register, or not, and why not if so, in a nutshell ?
thanks in advance.
Regards, M
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sverre
    Posted by Sverre
    on Feb 11, 2011 5:18 AM
    Expert8570 points
    You can use a modulation index of 0.5 and "emulate" GMSK modulation in MDMCFG2 and DEVIATN registers. Please note though that the sensitivity will be degraded as you reduce the modulation index (you can of course scale down the Rx filter BW if possible when reducing the deviation). Theoretically, there is an optimum deviation/datarate setting if you simultaneously minimize the receiver filter bandwidth. Every halving of receiver filter bandwidth increases sensitivity with 3 dB whereas sensitivity vs deviation/datarate decreases with about 1.5-2.5 dB per halving down to a certain limit where the loss increases very fast.
    None of our transceivers are coherent. Although we need the preamble/sync word for initial symbol timing recovery, we generally track symbol timing during the entire packet. The sync word is also needed for identifying the start of the payload. To put it simple, each 2FSK bit is detected as the sign of the phase change over one symbol period.
    Report Abuse
    • Reply
  • JP Norair
    Posted by JP Norair
    on Feb 12, 2011 12:22 AM
    Prodigy240 points
    Is there an app note about how the constellation diagram works depending on the DEVIATION_M setting, when using MSK?  I always thought that common MSK used a pi/4 (45 degree) constellation offset.  I assume this would mean to use 4/8=011.  Am I correct?  Thanks!
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
