• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Proprietary Software & SimpliciTI Forum » LQI function
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
LQI function
LQI function
This question is not answered
Evan Carabona
Posted by Evan Carabona
on Apr 27 2011 00:38 AM
Prodigy40 points
Is there a function to generate LQI?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Siri
    Posted by Siri
    on Apr 27 2011 02:37 AM
    Expert4600 points
    Which chip are you referring to?
    Report Abuse
    • Reply
  • Evan Carabona
    on Apr 27 2011 03:16 AM
    Prodigy40 points
    cc2500
    eZ430-rf2500
    Report Abuse
    • Reply
  • Siri
    Posted by Siri
    on Apr 27 2011 03:39 AM
    Expert4600 points
    The LQI can be read from the LQI status register or it can be appended to the received packet in the RX FIFO. LQI is a metric of the current quality of the received signal. The LQI gives an estimate of how easily a received signal can be demodulated by accumulating the magnitude of the error between ideal constellations and the received signal over the 64 symbols immediately following the sync word. LQI is best used as a relative measurement of the link quality (a high value indicates a better link than what a low value does), since the value is dependent on the modulation format.
    To simplify: If the received modulation is FSK or GFSK, the receiver will measure the frequency of each "bit" and compare it with the expected frequency based on the channel frequency and the deviation and the measured frequency offset. If other modulations are used, the error of the modulated parameter (frequency for FSK/GFSK, phase for MSK, amplitude for ASK etc) will be measured against the expected ideal value
    RSSI (Received Signal Strength Indicator) is a signal strength indication. It does not care about the "quality" or "correctness" of the signal. LQI does not care about the actual signal strength, but the signal quality often is linked to signal strength. This is because a strong signal is likely to be less affected by noise and thus will be seen as "cleaner" or more "correct" by the receiver.
    There are four to five "extreme cases" that can be used to illustrate how RSSI and LQI work:
    1. A weak signal in the presence of noise may give low RSSI and low LQI.
    2. A weak signal in "total" absence of noise may give low RSSI and high LQI.
    3. Strong noise (usually coming from an interferer) may give high RSSI and low LQI.
    4. A strong signal without much noise may give high RSSI and high LQI.
    5. A very strong signal that causes the receiver to saturate may give high RSSI and low LQI.
    Note that both RSSI and LQI are best used as relative measurements since the values are dependent on the modulation format.
    BR
    Siri
    Report Abuse
    • Reply
  • Grigoris Tsonis
    Posted by Grigoris Tsonis
    on May 01 2012 14:04 PM
    Prodigy10 points
    Is LQI calculated the same way in CC2420 (chip on a CC2420EB and LQI read through SmartRF PacketSniffer)?
    smartrf CC2420 cc2420eb
    Report Abuse
    • Reply
  • emrah spl
    Posted by emrah spl
    on Jan 30 2013 09:37 AM
    Intellectual330 points
    Hi Dears,
    Also, I have problem with getting LQI values, I have searched on hal_rf and basic_rf functions but I have not find anything, reading LQI in sniffer is really good (I have not checked yet but in registers will be good) but I want to use LQI values in my program.
    Could you help about that issue?
    ES
    CC2530 LQI
    Report Abuse
    • Reply
  • emrah spl
    Posted by emrah spl
    on Jan 30 2013 09:42 AM
    My question for CC2530,
    thank you for your consideration.
    CC2530 LQI
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
