Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Proprietary Software & SimpliciTI Forum » Changing the tx power
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 31 Replies
  • 9 Subscribers
  • 2920 Views
  • Postedover 3 years ago
Options
  • Subscribe via RSS
Tags
  • #pragma register_bank
  • #sniffer #CC1111
  • //CC1110
  • __xdata
  • 0xFFFE
  • 1.1.0
  • 2.4 GHz
  • 2.4GHz
  • 2.4GHz QFM-TRX1-24G board
  • 2274
  • 2400
  • 2430 RF04EB Problem
  • 2500RF
  • 2500T
  • 2-FSK
  • 32 kHz Oscillator
  • 32 MHz
  • 32kHz
  • 433 MHz
  • 500 kBaud
  • 555
  • 6LowPan
  • 6lowpan cc2530
  • 6LowPan devices
Forum - Title
Welcome to the Low Power RF & Wireless Connectivity Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Announcements
  • Forums
  • Files
  • Design Notes
New Post
This question is not answered
Wayne13013
Posted by Wayne13013
on Jul 2, 2009 5:44 AM
Prodigy10 points
I'm new to using eZ430-rf2500 development kit.
If I want to change the transmit power of the transreceiver, do I use smartrf studio to do so? (there seems to be a way to do it from there)
After that, how do i integrate the settings from smartrf studio into the hardware?
Thanks in advance!
SmartRF Studio TxPower
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Lisa TI
    Posted by Lisa TI
    on Jul 2, 2009 11:05 AM
    Mastermind47015 points
    Hi Wayne,
    I hope the following helps.  You generate the .h file Simpliciti need from SmartRF Studio by going File->Export CC2500 Code.  The export box opens where there is a simpliciti option in the bottom left box.
    In the following directory (typical Simpliciti installation)  is the .h file Simpliciti uses (smartrf_CC2500.h).  Make a backup of the original and export to here from SmartRF Studio.
    C:\Texas Instruments\SimpliciTI-IAR-1.1.0\Components\mrfi\smartrf\CC2500
    Have fun developing ...
    Cheers,
    Yoda
    Report Abuse
    • Reply
  • Notsane
    Posted by Notsane
    on Jul 2, 2009 11:54 AM
    Expert3045 points
    You might want to look here: http://tiexpressdsp.com/index.php?title=Low_Power_RF_Solutions#Workshop_Contents
    Check out Lab5a in the SImpliciTI module.
    Scott
    Report Abuse
    • Reply
  • ardoster
    Posted by ardoster
    on Sep 21, 2009 5:56 AM
    Intellectual715 points
    Hi
    I'm also trying to change the tx power, so I recover this thread. Actually, I'm trying to increase the tx power to the maximum possible power. So, following your indications, I've used SmartRF to create a new configuration, upgrading the parameter "RF Output Power" from 0dBm to +10dBm (the maximum power allowed). But when I export the code to SimpliciTI, the file created is exactly the same as the original.
    The steps I've followed to export my code are:
    1) File / Export CC1101 code
    2) Double click over "SimpliciTI settings"
    3) Click over "Write to file" to save the file.
    I don't know what the problem is. Are you sure this is the correct way to change the tx power?
    Thanks you in advance.
    SimliciTI smartrf tx power
    Report Abuse
    • Reply
  • ardoster
    Posted by ardoster
    on Sep 21, 2009 11:46 AM
    Hi another time
    Exploring the code of SimpliciTI, I've found a function called MRFI_SetRFPwr that is used to change the transmission power. This function configure the tx power using the values declared in the table mrfiRFPowerTable, defined in the line 188 of mrfi_f1f2.c.
    static const uint8_t mrfiRFPowerTable[] =
      0x0F,
      0x27,
      0x50
    If I change the values of this table, I'm changing the tx power of my radio chip? How is defined the value of this table? In dBm? In -dBm? In other words, 0x50 is using more power in the transmission that 0x27? What's the maximum value?
    Report Abuse
    • Reply
  • Will10140
    Posted by Will10140
    on Sep 21, 2009 11:58 AM
    Prodigy40 points
    This values correspond to a power : 0x0F : -20dBm, 0x27 : -10 dBm and 0x50 : 0dBm.
    The SmartRF Studio tool is interresting to understand this. You want download it in TI website.
    Will
    Report Abuse
    • Reply
  • ardoster
    Posted by ardoster
    on Sep 21, 2009 12:11 PM
    Thanks you for your quickly response.
    And yes, I use SmartRF Studio. In fact, I tried to use it to change my tx power editing the file smartrf_CC1101.h, which contains all information about the tx parameters. But as I said in my previously message (at 5:56AM), it looks like that no information about tx power is contained in this file. So I'm trying to search alternative methods to increase my tx power.
    Thanks you another time. I will use SmartRF to change these values and increase my tx power.
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Sep 22, 2009 3:43 AM
    Genius13915 points
    Hi Ardoster,
    Having the CC1101 datasheet available might be handy, especially chapter 24 and tables 36-39.
    The reason the PATABLE is not exported to simpliciTI code is that this is overridden by SimpliciTI. The mrfiRFPowerTable contais register settings for the PATABLE register and you will have to look in the datasheet to see what they corresponds to in term of output power. MRFI_SetRFPwr() in MRFI_Init() initializes this and this can be changed using a IOCTL call any time (IOCTL_ACT_RADIO_SETPWR).
    Hope this helps.
    Kjetil
    PS. Thank you for clicking  Verify Answer  if this answered your question!
    Report Abuse
    • Reply
  • ardoster
    Posted by ardoster
    on Sep 22, 2009 4:29 AM
    Thanks you. Yes, it looks like more flexible the way you say that having exported the tx power in the SimpliciTI code.
    Thanks you a lot of
    Report Abuse
    • Reply
  • Ky Pa
    Posted by Ky Pa
    on Feb 8, 2012 1:26 PM
    Prodigy215 points
    Kjetil
    Hi Ardoster,
    Hope this helps.
    Kjetil
    I am using the ez430_chronos sample project and I want to use it for a very near range application so I changed the ioctlLevel from the preset IOCTL_LEVEL_2 to IOCTL_LEVEL_0 but that did not appear to shorten the range to the device at all. Any advice?
    CC1111 eZ430 CC430 chronos
    Report Abuse
    • Reply
  • Bruce Mitchell
    Posted by Bruce Mitchell
    on Feb 8, 2012 10:54 PM
    Prodigy245 points
    Unfortunately TI did not develope the code for the eZ430-Chronos it was done by BM innovations GmbH http://www.bm-innovations.com/ and they are interested in monitoring athletes and want to sell BlueRobin™.  I am not saying anything bad about BlueRobin™, as I have not really even used it.  But BM innovations GmbH, IMHO, made some compromises to support TI's SimpliciTI, you may be see one of them.
    Report Abuse
    • Reply
  • Bruce Mitchell
    on Feb 8, 2012 11:01 PM
    Prodigy245 points
    BTW - in addition to adding support for BlueRobin™ and switching to and from TI's SimpliciTI, BM innovations GmbH added Over The Air Firmware Update.  This can be a real plus!
    Report Abuse
    • Reply
  • mark sonn
    Posted by mark sonn
    on Feb 9, 2012 2:46 AM
    Expert1705 points
    SimpliciTI uses the first entry in the mrfiRFPowerTable by default, which you also use, therefore nothing changed.
    Report Abuse
    • Reply
  • simon rees
    Posted by simon rees
    on Feb 9, 2012 5:20 AM
    Prodigy200 points
    I am also new to Simpliciti and have been reading this with great interest. as I have been having trouble getting good range on on my 433 module in the CC1110-CC1111 dev kit.
    I have been getting inconsisent results so I am at a loss as how to improve things.
    Could someone confirm my understanding from this topic thread which
    Simpliciti does NOT use any power settings from RFStudio. even if it outputs it.
    SimpliciTi ONLY uses the Power Table built in?
    If the above is true is the IOCTL API the prefered (only) way to adjust the power in an application.
    Also if the above is true does RFstudio have a table output mode?
    If not I have to change the value in the table myself, in which case how do choose the the vaules, do I really have to read the CC1110 datasheet. The tools were supposed to make things easier.
    I want to make the the max power the max power of the circuit i.e. 10dbm waht value do I use.
    Report Abuse
    • Reply
  • mark sonn
    Posted by mark sonn
    on Feb 9, 2012 6:41 AM
    Expert1705 points
    Correct, SimpliciTi always uses a hardcoded power table, which is an array called mrfiRFPowerTable.
    It writes the first entry of this array in the power register of the radio by calling the smpl_init() function.
    If you call the smpl_ioctl function then another value of this array is written into radio register.
    The design note DN013 gives you a list of all possible values.
    If you want to amplify the output power by 10 dbm then you have to write the value 0xC0 in the register. Keep in mind that this doubles the current consumption
    Report Abuse
    • Reply
  • simon rees
    on Feb 9, 2012 7:52 AM
    Prodigy200 points
    Thanks thats a brilliantly clear answer. I didin't see that app note as its only on the CC1101 webpage and I have a CC1110 so I would never have looked.
    I'm not sure I do need 10dbm but I have to test the radios in a harsh environment to see what error rate and range I get and the test needs to run automatically for 24 hours.
    So obviously I need to test at different transmision powers to see what happens but I couldn't start the test a I didn't even get good range on the bench.
    The setup was supposed to be an acess point running at full power( or high) and then 4 enpoints running at four different power settings each one built with a different export from RFStudio. However it transpires that this would never have worked.
    Hopefully I can move forward now, Thanks again
    Report Abuse
    • Reply
123
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
