• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Proprietary Software & SimpliciTI Forum » 6LowPan someone ?
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
6LowPan someone ?
6LowPan someone ?
This question is not answered
JP2465
Posted by JP2465
on Jul 09 2008 22:11 PM
Intellectual340 points
Anyone working on a 6LowPan Stack or design like LPWRocks asked for Wireless HART ?
JP
6LowPan
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • LPRF Rocks the World
    Posted by LPRF Rocks the World
    on Jul 10 2008 04:05 AM
    Genius10415 points
     Hi JP,
     Check this company www.sensinode.com  and
    their CC2430 6LowPan Stack: http://sourceforge.net/project/platformdownload.php?group_id=213457
    Enjoy,
    LPWRocks
    "Customer Centricity, Enthusiasm, Mass collaboration and Great minds are the best path towards great products"
    “Victory awaits him who has everything in order – luck people call it. Defeat is certain for him who has neglected to take the necessary precautions in time; this is called bad luck.”
    Roald Amundsen, The South Pole
    6LowPan
    Report Abuse
    • Reply
  • Radiogeek
    Posted by Radiogeek
    on Jul 10 2008 07:42 AM
    Prodigy210 points
    Yes, Radiocrafts and Sensinode offer 6LoWPAN modules. Check out RC2300 at www.radiocrafts.com and the stack at www.sensinode.com
    Report Abuse
    • Reply
  • JP2465
    Posted by JP2465
    on Jul 10 2008 09:41 AM
    Yeah, but what I am seeking is comment about this stack. I was interested about size, complexity, performance, ... versus the Zigbee one but on the TI's chips.
    But thanks anyway !
    6LowPan performance
    Report Abuse
    • Reply
    on Jul 11 2008 04:02 AM
    Genius10415 points
    Hi JP,
    We have had someone take a look at this earlier.
    Pro:
    • TCP/IP style interface, so no need to reinvent the wheel. Great for developers who are familiar with BSD sockets/WinSock etc.
    • Programming-model: event-driven like Z-Stack but main() is located in the application. This makes applications more intuitive.
    • Everything is open source
    • Free development tools, (Example FreeRTOS: www.freertos.org )
    Areas for improvement:
    • Need to improve documentation.
    • Need to improve on the comments in the code
    LPWRocks
    6LowPan
    Report Abuse
    • Reply
  • JP2465
    Posted by JP2465
    on Aug 04 2008 21:41 PM
    Is it lighter than Zigbee ?
    The features are comparable ?
    Does-it perform well into an existing IP network ?
    Noone have a reliable reference, a website or any scientific paper which present clearly the benefits (and drawbacks) of the stack compared to the others (many, many others !) ?
    6LowPan
    Report Abuse
    • Reply
  • 6lp
    Posted by 6lp
    on Aug 06 2008 15:27 PM
    Prodigy80 points
    The 6lowpan stack is smaller (as small as 24K) and significantly less complex that Zigbee.  Additionally becuase it doens't have to use all of the complex mac constructs it can perform better.
    Report Abuse
    • Reply
  • 6lp
    Posted by 6lp
    on Aug 06 2008 15:31 PM
    Prodigy80 points
     JP, it is lighter.  Don't expect to run zigbee on anything less than a 64K part and more probably a 128K part.
    Zigbee does has a define security architecture (such as it is - Not good) and does have application profiles defined.  6lowpan does not.
    All of the implementations of 6lowpan that are available today play very well with existing IP networks!  this is the point.   With Zigbee you need complex gateways to translate zigbee to something that
    the internet can understand which then breaks end to end security and end to end reliability.  6lowpan you don't need a gateway, just a simple bridge or multiple bridges (which zigbee can't do either.)
    Report Abuse
    • Reply
  • OZ2550
    Posted by OZ2550
    on Aug 07 2008 05:39 AM
    Intellectual330 points
    got some questions:
    How does routing work with 6LowPan? Is there a automatic Self Healing / Route-Discovery like in ZigBee (AODV)?
    Or is it more static (manuell setup)?
     regards,
    OZ
    Report Abuse
    • Reply
    on Aug 07 2008 10:20 AM
    Genius10415 points
     HI,
    As you state each standard protocols has its nice feature. I guess the challenge and what everyone is searching for is the "killer" application where the protocol of choice can make the perfect fit.
    What is the killer app for 6LowPan?
    What about the IPv6 packet overhead on top of IEEE 802.15.4?
    BTW: I have found this overview:
    http://www.archrock.com/downloads/resources/6LoWPAN-tutorial.pdf
    LPWRock
    6LowPan Packet Overhead
    Report Abuse
    • Reply
  • 6lp
    Posted by 6lp
    on Aug 08 2008 17:31 PM
    Prodigy80 points
     6lowpan doesn't constrain you to any particular routing protocol.  With 6lowpan you can choose to use a mesh under (layer 2 routing) or a route over (layer 3 routing).  It is your choice that would best fit your needs.  Unlike zigbee you are not locked to any particular protocol.
     There are pros and cons to using mesh under or route over.  Generally with mesh under in order to ensure intreoperability every node in the pan is required to use the same mesh routing protocol (this is the contraint with zigbee), but with mesh under the higher layer architecture is really simple.  The layer 2 mesh makes the many nodes and multiple hops look like a single (albiet slow and lossy) broadcast network.  To IP every node looks like they are on the same subnet.  With mesh under unless you talk the same layer 2 mesh you can't exchange data packets with any other nodes.
    With route over the various nodes could  choose to use different routing protocols and yet every node can exchange packets.  This is the way the internet works today.  there are many routing protocol in use and still nodes can exchange packets because they are just IP packets.  The upside is interoperability.  The down side is that the routing or network topology is not as simple.  This is why there is a new working group (ROLL) working on just this topic.
    One minor nit - Zigbee does not use AODV.  They use their own modified version of AODV - unfortunately.
    With 6lowpan you can build self organizing and self healing multi-hop networks with either mesh under or route over and you can also choose to create manually set up networks.
    Report Abuse
    • Reply
  • 6lp
    Posted by 6lp
    on Aug 08 2008 17:40 PM
    Prodigy80 points
    I think the killer point for 6lowpan is that you don't need to learn new protocols, new apis, build new protocols and new gateways and increase complexity.  6lowpan allows you to build IP networks on top of 15.4 and easily interconnect them to existing IP infrastructure, manage the nodes and network with existing tools and knowledge, protect the networks with existing tools, program the networks with existing experience and knowledge.
     Additionally by using 6lowpan on 15.4 you can build sensor and control networks that make use of multiple phys as needed.  If you need to talk over PLC or 15.4 or even narrow band RF you can do it.  If you want to interconnect these networks with ethernet or wifi, just do it.  You don't need to build tunnels, you don't need to build gateways to translate to and from ip and you don't need to program end nodes to understand proprietary applications (as with Zigbee).
    As for packet overhead, for intra-pan packets the overhead can be as low as 4 bytes (single hop, no fragmentation) and if you are using a layer 2 mesh you would add 4 bytes and if you are sending large packets you would add a couple bytes for the fragmentation header.  With 6lowpan's header design you only "pay for" what you use.  In a route over design the overhead is generally only 4 bytes (much smaller than zigbee's monlithic header).
    Report Abuse
    • Reply
  • Hobbyist
    Posted by Hobbyist
    on Aug 10 2008 08:32 AM
    Prodigy120 points
     Hi 6lp,
    I am new to 6LowPan, but was wondering where to start. Any Open 6LowPan Stack you recommend to use with a TI transceiver to SoC?
    What type of logical devices do you have with 6LowPan? If you compare a ZigBee Coordinator, Router, or Ende Device
    How big is the 6LowPan API? How many function calls for the application layer to setup a network?
    Hobbyist
    6LowPan devices
    Report Abuse
    • Reply
  • Hobbyist
    Posted by Hobbyist
    on Aug 10 2008 08:38 AM
    Prodigy120 points
    Hi 6lp,
    A few more questions. Can 6LowPan be used with SP100 a or b or something? Is 6LowPan made to be used for industrial applications?
    What about sleeping routers? Can this be supported by 6LowPan. ZigBee does not support this.
    Hobbyist
    Sleeping routers
    Report Abuse
    • Reply
  • 6lp
    Posted by 6lp
    on Sep 08 2008 12:55 PM
    Prodigy80 points
    Actually 6lowpan is part of the ISA100 (SP100) standard.  SP100 uses an SP100 layer 2 self forming self healing mesh and 6lowpan on top of the mesh including IP and UDP.
    SP100 uses and support sleeping routers so, yes you can build biuld a 6lowpan network that supports sleeping routers.
    Report Abuse
    • Reply
  • WHART
    Posted by WHART
    on Oct 04 2008 05:31 AM
    Prodigy20 points
    6lowpan, write to whartstack@yahoo.com
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
