• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Proprietary Software & SimpliciTI Forum » Simpliciti Link Layer Behavior
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Joshua Einstein
Posted by Joshua Einstein
on Aug 16 2012 13:00 PM
Intellectual700 points
We have a situation where an AP needs to be aware of whether or not an ED is attempting to relink with the AP. I've been trying to figure out what is going on, but the stack seems to be automatically serving the link reply without any notice anywhere.
Process:
1) Link an ED and an AP (waiting for SMPL_SUCCESS on SMPL_LinkListen() )
2) Clear the connection from the ED, and try to relink the ED using SMPL_LinkListen()
I'm not receiving a SMPL_SUCCESS from the function (even though it is the only time that the LinkListen context is on). Is there any way to recognize this sort of situation in the SimpliciTI stack?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Leo Hendrawan
    Posted by Leo Hendrawan
    on Aug 17 2012 07:20 AM
    Mastermind28725 points
    Hi Joshua,
    Joshua Einstein
    How do you clear the connection? Are you using SMPL_Unlink() this will generate an unlink request message to the AP, so that the AP should be able to delete the connection at his side also.
    see the following functions which will be executed on the following sequence when the AP receives the unlink request:
    - MRFI_RxCompleteISR() in nwk_frame.c
    - dispatchFrame() in nwk_frame.c
    - nwk_processLink() in nwk_link.c
    - handleLinkRequest() in nwk_link.c
    - smpl_send_unlink_reply() in nwk_link.c -> will call nwk_freeConnection().
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 08:12 AM
    What I'm trying to figure out is how to recognize an ED that sends additional link messages. If the link context is only on during the LinkListen function, how does the stack handle a device that is already linked but still sends a link message? What will the SMPL_LinkListen function return?
    We can't use SMPL_Unlink to clear the connection from the ED as the ED is asleep for most of its life. I'm currently using NVOBJECT to restore the ED connection on startup, and I'm "clearing" the ED connection by ignoring the saved NVOBJECT data and attempting to relink.
    On the AP side, the ED is removed using a SMPL_Unlink or call, but it doesn't expect to hear a reply from the ED. This is actually working out well for us!
    SimpliciTI
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 08:28 AM
    Hi Joshua,
    AFAIK, there is no way the application level will get notified when receiving messages with NWL applications (port number between 0x01 - 0x07). The callback function pointer given to SMPL_Init() function will be called only when the port belongs to application port. See the dispatchFrame() fuinction in nwk_frame.c for the details.
    Joshua Einstein
    I think after the AP calls SMPL_Unlink(), you shall then try to listen again by calling SMPL_LinkListen() periodically. If the ED sends a new link request, the SMPL_LinkListe() should return success.
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 08:31 AM
    Lhend-
    Sorry not to be as clear as I should. The problem I'm running into is slightly different. If I cause the ED to forget the AP, and then set the AP into LinkListen to relink the ED, I'm not getting a SMPL_SUCCESS, but a link reply is sent. What I need to do for my application is recognize that a link reply was sent to an already linked device to enable a change of state. I'm not sure why I'm not seeing a success though!
    SimpliciTI
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 09:15 AM
    Joshua,
    now it's clear for me what the real problem is (sorry for misunderstanding it).
    How many EDs do you have actually? and how many of them will try to relink to the AP at the same time? Have you set the NUM_CONNECTIONS correctly?
    Is it possible for you to debug the AP when it replies the link request for the second time? If yes, can you put a breakpoint at nwk_link.c (i am referring to the v1.2.0 code) smpl_send_link_reply() function at this code part:
    /* The local Rx port is the one returned in the connection structure. The
    * caller is waiting on this to be set. The code here is running in an ISR
    * thread so the caller will see this change after RETI.
    if (NUM_CONNECTIONS == sNumLinkers)
    /* Something is wrong -- no room to stack Link request */
    nwk_freeConnection(pCInfo);
    /* we're done with the packet */
    return SENT_REPLY;
    sServiceLinkID[sNumLinkers++] = pCInfo->thisLinkID;
    is the last line there executed and what is the value of sNumLinkers variable?
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 09:36 AM
    Leo-
    I'm using SimpliciTI 1.1.1 with a project about to head out the door on CCS v5.1. Trying to link a new device, I reach that breakpoint and sNumLinkers increments to 1. Trying to link a device that is already linked, I don't even reach that breakpoint.
    We have a bunch of EDs, but everything is done sequentially. Only one ED is dealt with at a time, and only one is going to be in link mode at any given time.
    I noticed in the changelog for SimpliciTI that you are no longer supporting CCS with 1.2.0? Is there anything I should be aware of before I try upgrading the SimpliciTI stack?
    Josh E
    SimpliciTI
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 09:39 AM
    I'm thinking there is something going on in the nwk_findAlreadyJoined() function
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 09:48 AM
    Joshua,
    Joshua Einstein
    That is quite strange, could check another thing please?
    in the same function smpl_send_link_reply(), when trying to link  a device which is already linked, do you get into this code part?
    /* is this a duplicate request? */
    remotePort = *(MRFI_P_PAYLOAD(frame)+F_APP_PAYLOAD_OS+L_RMT_PORT_OS);
    if (pCInfo=nwk_isLinkDuplicate(MRFI_P_SRC_ADDR(frame), remotePort))
      /* resend reply */
      msg[LB_REQ_OS] = LINK_REQ_LINK | NWK_APP_REPLY_BIT;
      /* sender's TID */
      msg[LB_TID_OS] = *(MRFI_P_PAYLOAD(frame)+F_APP_PAYLOAD_OS+LB_TID_OS);
      /* Send reply with the local port number so the remote device knows where to
      * send packets.
      msg[LR_RMT_PORT_OS] = pCInfo->portRx;
    If yes, that would be strange, because you basically should have erased the connection previously using SMPL_Unlink() which should call nwk_freeConnection().
    Could you debug/show the sPersistInfo structure in nwk.c after you call SMPL_Unlink() (breakpoint at nwk_freeConnection()) and also at nwk_isLinkDuplicate() which should be called during the re-link?
    Joshua Einstein
     should be supported, but i think there is a lack of resource in the SimpliciTI team at the moment which delays the release. I am just an application support engineer who conicidentally quite familiar with SimpliciTI.
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 10:08 AM
    Leo-
    I do get into that code segment when linking an already linked device.
    I noticed this in the changelog and wonder if it is related:
    "Correctly Free connection table status in nwk_link function.
    Failure to free connection table entry when link packet failed to be
    transmitted caused connection table entries to be exhausted and
    unusable."
    Debug info:
    nwk_freeconnection() breakpoint on relink shows a next linkID of 5. What information would you like from the sPersistInfo?
    I can't get the new version of SimpliciTI to play nicely with my project as there look to be some significant differences to the files, types, and similar (variable and #define additions among others).
    SimpliciTI
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 10:12 AM
    Joshua,
    Joshua Einstein
    i missed your last reply while typing my last response. I don't think the problem lies in the nwk_findAlreadyJoined() function. Basically the reply of link request is generated in smpl_send_link_reply() function. There can be only two possibilities on how a reply can be generated:
    - first is when the nwk_isLinkDuplicate() function returns a valid pointer to the connection structure (which actually should not happen in your case)
    - second is after the line: sServiceLinkID[sNumLinkers++] = pCInfo->thisLinkID;
    I would actually think that in both cases (new link, or second link), both have to go through the second way. However if you said that in the second link, you never reach the line above, it means the function exits after the first way. However again, i don't think this is possible since the nwk_isLinkDuplicate() should return NULL in both cases because it looks only for connected state, but even in second link, the link should be in free state.
    Hope you understand my way of thinking and can debug further. Would be nice if you can share the result with others here.
    Leo Hendrawan
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 10:28 AM
    Hi Joshua,
    Joshua Einstein
    basically if you can show the whole connStruct[] member of sPersistInfo after freeing the connection with SMPL_Unlink() and when doing the second link, it would be helpful i guess.
    Leo Hendrawan
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 10:32 AM
    Joshua,
    Joshua Einstein
    This should explain why your SMPL_LinkList() fails when relinking. The next question is why does the code get into that code segment. As i said, check every connection state (connState) of connStruct[] of sPersistInfo after freeing the connection and also in nwk_isLinkDuplicate() when trying to do the relink.
    Unfortunately i got to go now, good luck for the debugging and have a nice weekend :)
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 17 2012 10:41 AM
    Suggested Answer
    Okay.
    This actually makes sense now, as an already linked device would return as a duplicate device since it is already in the connection table. That's reasonable. I guess the next question then becomes, does the new version of SimpliciTI better handle this, or would I need to build in custom semaphores to test this? The logic makes sense in case there is bad transmission, so I just need some way of handling this myself.
    Thanks for the clarification. I guess I can call this "expected behavior"
    Report Abuse
    • Reply
  • Leo Hendrawan
    on Aug 17 2012 14:40 PM
    Hi Joshua,
    now i'm online from home :)
    Joshua Einstein
    No, actually it doesn't make sense to me. Indeed the data from the previous connection is still available in the table, but the table itself has been marked as invalid/free as soon as it is passed to the nwk_freeConnection() when you call the SMPL_Unlink().
    So i think we still need to find out why this happen.
    Leo Hendrawan
    Report Abuse
    • Reply
  • Joshua Einstein
    on Aug 20 2012 07:00 AM
    Leo,
    The duplicate message is occurring if I try to relink a device BEFORE calling SMPL_Unlink. What I've been trying to do is find a way for my application to recognize when a duplicate link message is sent back to a device. Your information about the linking process definitely helped me track down what was going on, and it looks like this is the expected behavior in the stack, for example if a device sends 2+ link messages before finalizing its link.
    The problem with this is that some sort of a timeout would be nice so that if another link message is received after, say, 5 minutes, then the smpl_linklisten function would return a SMPL_DUPLICATE_LINK or similar. This would require the stack to have the capability to be integrated with a program timer, though, which currently it is not setup for.
    I'm going to have to think about this one. Maybe changing the stack so a duplicate link message first calls SMPL_IOCTL(delete) and then attempts a relink?
    SimpliciTI
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
