• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF ZigBee® Software & IEEE 802.15.4 Forum » CC2530 TIMER SLEEP Mode
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Stuart Truax
Posted by Stuart Truax
on Apr 01 2011 17:21 PM
Prodigy90 points
Dear  Community,
                  I present a problem that seems to have frustrated more than a few of us. I am trying to get the GenericApp example program that comes with Z-stack 2.4.0-1.4.0 to run in TIMER SLEEP  mode. I am using a CC2530, which means the nominal current draw for should be 1 uA in this state.
                I have taken the following steps:
                1. Commented out  ZDO_COORDINATOR  and    RTR_NWK  in f8wCoord.cfg to specify an end device as a target.
                2. Set POLL_RATE=0 and RFD_RCVC_ALWAYS_ON=FALSE in f8wConfig.cfg
                3. Set POWER_SAVING in the preprocessor (using IAR EW for 8051).
                4. Hardcoded Hal_KeyIntEnable = HAL_KEY_INTERRUPT_ENABLE   in hal_key.c
                5. The only OSAL timer running is the send "Hello World" event, which is running at the maximum allowed OSAL interval (65 s).
              After downloading and debugging this application, I have noticed a few things:
               1. Nominal current consumption between OSAL events is 1.7 mA (much higher than timer sleep mode).
               2. The following code segment in osal_pwrmgr_powerconserve always has "next" values of either 600 or 1000, which means some process has events scheduled
                 every 600 or 1000 ms, despite my attempts to turn everything off except the send message OSAL event in the GenericApp.
                                // Hold off interrupts.
                                HAL_ENTER_CRITICAL_SECTION( intState );
                               // Get next time-out
                              next = osal_next_timeout();
                             // Re-enable interrupts.
                            HAL_EXIT_CRITICAL_SECTION( intState );
                            // Put the processor into sleep mode
                            OSAL_SET_CPU_INTO_SLEEP( next );
This leads me to two questions:
                                1. What further steps are needed to achieve power mode 2?
                                2. What are these events and how do I turn them off? If these events are due to some debug process, how do I turn them off in IAR?
Thanks.
---Stu
cc2530 timer sleep
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • xyzzy
    Posted by xyzzy
    on Apr 01 2011 17:36 PM
    Expert4665 points
    Hmmm, I've never tried "morphing" the Coordinator configuration to make an End-Device. Is there a particular reason why you're not using the End-Device configuration?
    If you are using the SmartRF05 platform, are you taking your current measurement at jumper P15 (V_EM)?
    Report Abuse
    • Reply
  • Stuart Truax
    on Apr 02 2011 00:04 AM
    Prodigy90 points
    xyzzy
    From experimenting with GenericApp, it seems that commenting out  ZDO_COORDINATOR  and   RTR_NWK  in f8wCoord.cfg  has the same effect as excluding f8wCoord.cfg in the build tree and including the corresponding file for end devices in its place (since there is no preprocessor flag for enabling end device functionality).  Would this functionally differ from the End-Device configuration you would use?
    I am using a custom platform with a CC2530F256 mcu, but I can precisely measure the current consumption of the mcu at all times with my setup.
    Report Abuse
    • Reply
  • xyzzy
    Posted by xyzzy
    on Apr 04 2011 09:45 AM
    Expert4665 points
    Using the End-Device configuration would "automatically" use the End-Device library. You could change the Coordinator configuration to use that library (it defaults to the Router library). I don't know that TI has done any testing of End-Device builds that used the Router library.
    Report Abuse
    • Reply
  • Stuart Truax
    on Apr 04 2011 10:04 AM
    Prodigy90 points
    xyzzy
    Per your suggestion, I have excluded f8wCoord.cfg and f8wRouter.cfg from the build and included f8wEndev.cfg. The power consumption is still the same, which is consistent with what was previously stated.
    There should be no separate "libraries" for the various device types. It should simply be the case that certain device types are enabled or disabled through flags.
    What could these 1000ms and 600ms processes be?
    Report Abuse
    • Reply
  • xyzzy
    Posted by xyzzy
    on Apr 04 2011 10:26 AM
    Verified Answer
    Verified by Stuart Truax
    Expert4665 points
    Forgive me if I wasn't clear enough in my previous answer. I should have said: "Using the End-Device configuration from the EndDevice option in the IAR IDE would "automatically" use the End_Device library, as well as, other End-Device specific options (such as f8wEndev.cfg, etc)."
    Given that you are working with your own custom platform and a modified Coordinator configuration, I would guess that there may be other changes that might need to be made - you could find them by "diffing" the Coordinator and End-Device configurations in the GenericApp.ewp file that came with ZStack.
    Here's what I would try first: in the IDE, have a look at Project->Options->Linker->Extra Options. Make sure you are using the correct ZigBee library option, ...\EndDevice-Pro.lib
    Report Abuse
    • Reply
  • Devashish Deshpande
    Posted by Devashish Deshpande
    on Apr 06 2011 11:55 AM
    Prodigy50 points
    You look quite familiar with the TI CC2530 stuff... so, can you please go through my question and help me?
    We are designing a Home Area Network/Energy Management System. For the Wireless Network, we are planning to use TI's CC2530 Development Kit. We already have the the kit with us. We also have the MSP430F5438 Board.
    You can see the overall application block diagram here:
    We are having trouble in understanding the interface between the MSP430 and CC2530EM. We went over the pdf document http://focus.ti.com/lit/wp/slyy022/slyy022.pdf. But, we could not relate it exactly to our application. Also, I am not too sure about whether we use the SmartRF05EB in this circuit or not.
    So, kindly explain how we can use the components that we currently have to build a wireless communication network.
    Many documents mention CC Debugger. However, we do not have it with us. Will we need to buy one?
    Thank You for your time,
    Devashish Deshpande (806-543-0487)
    Report Abuse
    • Reply
  • Stuart Truax
    on Apr 06 2011 12:31 PM
    Verified Answer
    Prodigy90 points
    xyzzy
       Thanks xyzzy. This appears to have solved the problem. I also noticed that one should go to Project->Options->C/C++ Compiler->Extra Options and replace -f $PROJ_DIR$\..\..\..\Tools\CC2530DB\f8wCoord.cfg   with -f $PROJ_DIR$\..\..\..\Tools\CC2530DB\f8wEndev.cfg   in addition to including/excluding the .cfg files from the build and including the above libraries.
      Now the only timer running is that which I specify for my application task.
    Thanks.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
