hello everyboby,
I was working in the wireless zigbee programming for the end device using the sample application as my guide. While doing so, i found that the OSAL_App.c in the application sub folder in the project has the following error.
Error[Pe144]: a value of type "void (*)(uint16)" cannot be used to initialize an entity of type "unsigned short (*)(unsigned char, unsigned short)"
Now, i couldnt solve this error.....
the osal events are to be carried out first, but due to this error the report and reading of the values is not been done.
i did the programming the based on the sample application, when i run the program there is no error.
then what is the source for this error...
the following is the code i programmed for the OSAL_Enddevice.c
// The order in this table must be identical to the task initialization calls below in osalInitTask.const pTaskEventHandlerFn tasksArr[ ] = { Hal_ProcessEvent, // HAL should be a higher priority than any ZNP task. zapEvt, // ZAP APP should be the highest priority ZNP task. zb_HandleOsalEvent};
the code in the main end device .c for the zb_handle events
voidzb_HandleOsalEvents(uint16 events)
Program for the events to be carried for the command in and report the values
