• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF ZigBee® Software & IEEE 802.15.4 Forum » Managing power consumption of CC2530 when in Orphan and joining to network states
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Igor Sherer
Posted by Igor Sherer
on Jul 20 2012 09:41 AM
Guru22030 points
Hi Guys,
This is a long post, so please be patient when you read it. :)
Here's my question:
Is it possible for orphaned ED (Z-Stack 2.5.0 - CC2531 devices) to sniff for potential parent
instead of constantly sending rejoin requests?
Here's the long description:
The reason I'm asking this question is of course to reduce power consumption to a possible minimum.
I've implemented a simple state machine, in my application, according to the following policy:
  • Application layer (my application) is informed that device changed its state to orphan state
    (ZDO_STATE_CHANGE) the device will try, for the next 20 seconds, to find a new parent and rejoin
    to network (20 seconds period is intended for roaming devices letting them to find a new potential parent)
  • Parent isn't found within 20 seconds period, ZDApp_StopJoiningCycle() is called to halt the join request
    messages sending (letting to device to switch to lower power mode PM2 or PM3).
  • Schedule call for state 1 in 60 seconds.
  • State 1: Wake up and try to rejoin to network, by calling ZDApp_StartJoiningCycle(), for 12 seconds,
    then stop joining and schedule this state to be called again in one minute. This state is called 5 times,
    after the 5th try State 2 is called.
  • State 2: Wake up and try to rejoin to network, by calling ZDApp_StartJoiningCycle(), for 12 seconds,
    then stop joining and schedule this state to be called in 5 minutes. This state is
    scheduled endlessly, or
    until the device is successfully joined to a new parent.
I have to provide an intelligent solution/s to both cases.
First case:
We have a set-up of 20 routers and 35 static (non roaming) EDs at client's site. It's an office like site with
concrete (rocket blowup impenetrable) walls. :) Each router is mounted at each entrance (above the door)
of an office room, inside every room there is/are single/2 EDs that is/are mounted on a wall. We are
experiencing bad RF performance in several rooms (caused by PCB printed antennas, possibly ill RF design
and concrete walls). The side effect of bad RF performance is frequent orphaning of EDs which leads to a
frequent high amount of current (~28mA) draw. Long story short, when the RF link is good, ED can work for
~6 months (even more) before we need to replace 2 AAA batteries with fresh ones, where fresh batteries in
the same device with the same FW can last for ~3 weeks (before we need to replace'em) when the the RF
link is poor.
Second case:
ED (user), for some amount of time (can be several minutes to several days), have no network to
communicate with, hence it's found in orphan state and must not transmit or search (too often) for
a parent in order to extend battery life. However once a user enters to a site with ZigBee network coverage,
the ED have to join to this network and transmit/receive X/Y amount of data. It have to find this network
without any intervention from a user (at this stage no push buttons are allowed). Moreover, once the device
is inside the area of this site, it can rapidly move from one router to another (user is running). Eventually
the user will leave this site, at this point ED must (somehow) to "understand" that it's not inside network
coverage and start to manage it's power consumption in an efficient way again.
I think that's all I have to say at this moment.
If you'r reading this line (and not cursing me for my English) I want to thank you for your time and  patience. :)
Again, please excuse me for the long post.
I'll be glad to hear your professional opinion, insights, suggestions, anything useful :)
Br,
Igor
Z-Stack CC2530 orphan state
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Guanqiang Chen
    Posted by Guanqiang Chen
    on Jul 20 2012 11:56 AM
    Intellectual465 points
    hi Igor:
    i have read through your words,but i can't understand them all blame to my bad eng.
    what's your mean by saying "sniff "?
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 20 2012 12:06 PM
    Guru22030 points
    Hey,
    By "sniff" I mean something like turning on Receiver and only listen, w/o actually transmitting.
    Receiving packets consumes less power then transmitting.
    Br,
    Igor
    Report Abuse
    • Reply
  • Guanqiang Chen
    on Jul 20 2012 12:42 PM
    hi,
    i see! but parent can't  know that the end device change to a orphan,so we don't know when to inform the end device(send a message to enddevice).
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 20 2012 15:36 PM
    Guru22030 points
    Hey,
    Well, I don't want the parent to inform end device.
    I do want the End Device to make "smart" conclusions in such cases, in other words, I want to write some
    sort of intelligent algorithm. Which, I believe, is possible to do with the help of ideas and experience of other
    people plus my own.
    Br,
    Igor
    Report Abuse
    • Reply
  • Guanqiang Chen
    on Jul 21 2012 06:59 AM
    i am not sure i have understood your words completely.
    if yes.i have some suggests:
    1、you said the ED should "know" the coverage of the specific network.i think you can judge it by checking nwkdisclist where all network shown.
    2、before go to sleep.then you can close the DPOLL so that halt the join request,in this way,there is no data communicate until you restart the DPOLL  which can scan the network again.
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 26 2012 02:36 AM
    Guru22030 points
    Any other thoughts?
    Br,
    Igor
    Report Abuse
    • Reply
  • Igor Sherer
    on Aug 05 2012 08:08 AM
    Guru22030 points
    I want to update this post with additional info:
    Following image is an oscope screenshot of voltage measured on 2.7Ohm resistor connected
    serially from 2.8V source to our custom PCB with cc2531 on it.
    When CC2531 is in sleep mode, the drawn current is ~12uAmpers; An onboard Hall effect sensor
    draws about 11uAmpers and the remain current is drawn by CC2531 IC.
    The ~6 Seconds window (marked with red rectangle) happens when End Device goes into orphan
    state, the peak-to-peak (without added noise) amplitude of the signal is about 75mV (which means
    current draw of ~28mAmps).
    Well, the practical question (from my original post) is there any possibility in Z-stack just to sniff for
    a new parent, potentially avoiding excessive power consumption like presented on the screenshot?
    Br,
    Igor
    Report Abuse
    • Reply
  • Rowan Chattock
    Posted by Rowan Chattock
    on Oct 15 2012 05:16 AM
    Prodigy70 points
    Hi Igor
    Have you managed to find a solution for this. I am currently trying to do something very similar. I am using the ZNP mini kits as my end nodes running Zstack 2.5.0 on the CC2530. I want to stop the end node batteries from being completely drained if the coordinator looses power. I have noticed that if I turn my coordinator off and forget to remove the end node batteries on friday night when I leave the office then the end node batteries are flat on Monday morning.  There must be something I can do to reduce the drain on a battery as power cuts are not exactly unexpected and it must be possible to reduce the current consumption in these circumstances.
    I tried tuurning the radio off but found that the CC240 did not go to sleep in these circumstances and the current drain was 1.5mA which is still better than the 28mA drain that you get if the end node is continually looking to join a network.
    Thanks for any advice
    Rowan
    Report Abuse
    • Reply
  • Igor Sherer
    on Oct 16 2012 03:58 AM
    Guru22030 points
    What is this CC240 device??
    Br,
    Igor
    Report Abuse
    • Reply
  • Rowan Chattock
    on Oct 16 2012 04:12 AM
    Prodigy70 points
    Hi
    Sorry typing error I am using an MSP430F2275 for the application code and the Zstack is on a CC2530. Hope this clarifies things.
     I am using the TI ZNP Mini kit for my end node. I have been measuring my current consumption using the same method outlined in the Power Management For The CC2530.pdf document provided by TI with their zStack download. I need to be able to find a way of stopping the CC2530 draining its battery when the coordinator looses power.
    So far I have had get the MSP430 to hold the CC2530 in reset when it knows that the ZDO_STATE_CHANGE_IND returns DEV_NWK_ORPHAN. This does reduce the current from a nearly constant 28mA to 1.5mA, but this is no where near the few micro amps when the CC2530 is sleeping. This is a bit extream, but everything else I have tried so far has only drwan more current.
    Report Abuse
    • Reply
  • Igor Sherer
    on Oct 16 2012 05:25 AM
    Guru22030 points
    Unfortunately am not familiar with ZNP, so I don't know it's possible to invoke
    functions like ZDApp_StopJoiningCycle(), ZDApp_StartJoiningCycle() through
    ZNP interface. I don't see such option in ZNP documentation in Z-stack 2.5.0
    releise. Try the Z-stack 2.5.1, may be it was added there (or you could wait
    for me getting home and checking it).
    By the way, did you try to search the forum, I think I saw a discussion about
    this issue.
    Br,
    Igor
    Report Abuse
    • Reply
  • Rowan Chattock
    on Oct 16 2012 07:59 AM
    Prodigy70 points
    Hi
    It does not look as if ZDApp_stop and ZDApp_start joining functions are supported in the Z-stack 2.5.1.a
    I have tried searching the forum and have noticed several discussions relating to power consumption but none of them are specifically handling the case of power consumption durung a power cut or if they come close there is no resolution to the issue. Your question came the closest to the situation I am trying to resolve, hence my posting.
    Thanks for your help I will go back to searching thorugh postings to see if I can track something down.
    Regards Rowan
    Report Abuse
    • Reply
  • Rui Zhang69778
    Posted by Rui Zhang69778
    on Oct 16 2012 13:54 PM
    Genius4525 points
    Hi Igor:
    You can try a wakeup join/sleep schedule with a backoff sleep time period to save time:
    1 rejoin: wake up try 5mins, then if can not join, sleep for 5 min
    2 join, wake up try 5 mins, then if can not join, sleep for 10 min
    repeating this process and double sleep time as 5*n mins,
    external INT can trigger the state to go back 1,
    Can save a lot of energy
    Rui
    Report Abuse
    • Reply
  • Rui Zhang69778
    on Oct 16 2012 13:57 PM
    Genius4525 points
    I think your question is how to sniffer a beacon without sending any orphan/beacon request?  if so, theoretically you can change to passive mode to do so
    Rui
    Report Abuse
    • Reply
  • Igor Sherer
    on Oct 17 2012 04:20 AM
    Guru22030 points
    Hi Guys,
    Rowan, check out this thread, maybe you'll find it helpful.
    Rui, the join/sleep schedule with a backoff schema you suggested is pretty much
    what I have implemented, though there are only one backoff step.
    My main concern is the ~7 seconds of constant TX in orphan to rejoin to a new parent.
    I was wandering how can one to reduce 7 seconds, to let's say, ~1, ~2.
    Br,
    Igor
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
