• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF ZigBee® Software & IEEE 802.15.4 Forum » Large Scale Zigbee Networks
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Sam Elia
Posted by Sam Elia
on Jul 24 2012 09:20 AM
Prodigy140 points
I am trying to create a 250 node zigbee network (36 routers and 214 end devices).  Each node sends it sensor readings every minute (payload = 30 bytes).  Each router sends it Network Link Status every 15 seconds.  End Device Poll Rate messages have been disabled.
It seems that when my networks gets to the size of about 60 devices, I start seeing packet corruption.  From the packet sniffer, It looks like the traffic is very heavy to the point where it sometimes takes a node up to 5 minutes of continuously trying to send its packet before it is successful.
According to my calculations, in a 60 device network of 36 routers and 24 end devices:
Sensor Reading Packets: 60
Acknowledgments:             60
Router NWK LinkStat:        36*4    (every 15 sec)
=  264 packets per minute
= 4.4 packets per second
Is 4.4 packets a second too much for Zigbee to handle?  I ran the PER sample program and sent 100 packets per second with 0% error.
I know there are other factors that go into packet corruption such as interference but I was hoping you could give me some advice specific to the Z-Stack that would help with implementing a 250 node network.  Is there a general rule of thumb for maximum packets per second?
ex. Change router NWK_LINK_STATUS PERIOD to 30 seconds to reduce traffic?
Also, I noticed from the packet sniffer that after leaving the 60 node network over the weekend, some nodes have switched PAN IDs.....  How is this possible when I specified the PAN ID in f8wConfig.cfg file.
Z-Stack CC2530 large networks packet corruption
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Igor Sherer
    Posted by Igor Sherer
    on Jul 24 2012 09:35 AM
    Guru22030 points
    I don't know yet what might be the solution in your case, however you have to answer several questions first:
    • What is the version of Z-stack?
    • What about security, is it enabled or not (my guess it's disabled)?
    • Have you implemented many-to-one routing, I believe that all these 60 devices sends
      data to some sort of sink (Coordinator)?
    Br,
    Igor
    Report Abuse
    • Reply
  • Sam Elia
    Posted by Sam Elia
    on Jul 24 2012 09:52 AM
    Prodigy140 points
    Hi Igor,
    I am using the latest Z-stack 2.5.1a.
    Yes, security is disabled.
    The devices only need to send their data to the coordinator which serves as a gateway to a server.  They do not need to communicate with each other except to route packages.  The application is built off the GenericApp sample.  How can I implement many-to-one routing?
    Report Abuse
    • Reply
  • Sam Elia
    Posted by Sam Elia
    on Jul 24 2012 09:59 AM
    Prodigy140 points
    Sorry to waste your time, I should have just done a search before replying.  This is what I found you said in another forum:
    1. Schedule a Route discovery request (this is actually a "many to one" routing property of ZigBee - PRO),
      by calling NLME_RouteDiscoveryRequest( 0xFFFC, 0x03, 0 ); every 15 + jitter seconds .
    2. Add this line in project options (Alt+F7)->C\C++ compiler->Preprocessor (tab)->Defined symbols (sub window):
      CONCENTRATOR_ENABLE=true
    It looks like these settings are only for the coordinator?  I am using TI cc2530 routers and end device with a Digi x4 gateway.  Is there anything I can set on the cc2530 nodes to enable many-to-one routing?
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 24 2012 10:00 AM
    Guru22030 points
    Sam Elia
    In coordinator FW project add CONCENTRATOR_ENABLE=TRUE (preprocessor->defined symbols)
    Additionally, in your application, once device status changed to DEV_COORDINATOR,
    set a reload timer which invokes a MANY_TO_ONE event (it's your own event), let's say 10 seconds +
    some jitter. In this event call NLME_RouteDiscoveryRequest( 0xFFFC, 0x03, 0 );
    Br,
    Igor
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 24 2012 10:07 AM
    Verified Answer
    Verified by Sam Elia
    Guru22030 points
    Nice, I've written this before. :)
    Sam Elia
    Not sure if you can do something with cc2530 and many-to-one feature while the Digi x4 used as gateway.
    However, the "sink" can be every router in your network, it's not only for coordinators, therefore, if you have some
    router that can be hooked up to a PC, in other words, used by you as coordinator concentrator, you can use
    the same technique in this specific router.
    You know, coordinator is used only to start a network, after the network is up, coordinator behaves as other routers
    Br,
    Igor
    Report Abuse
    • Reply
  • Derek9531
    Posted by Derek9531
    on Jul 24 2012 14:05 PM
    Verified Answer
    Genius5595 points
    Another trick is to be sure to stagger the transmissions in time. This way if all the devices are powered on at the same time (like after a power outage) then the network doesn't get jammed with everyone talking at once. I sometimes have devices delay their periodic reporting by a number of milliseconds equal to the last byte of the MAC address * 10 or something like that. You could also use a random number generator, but the MAC address way is simple.
    fixituntilitsbroken.blogspot.com
    Report Abuse
    • Reply
  • Guanqiang Chen
    Posted by Guanqiang Chen
    on Jul 30 2012 04:20 AM
    Intellectual465 points
    HI Igor:
    i  have some questions now,
    1、Do you mean that i have to set a reload timer  if i want to  use the many to one feature,like using a WatchDog? and when to set it,and if i can stop it?
    2、Are there some docoments introducing how to use the many to one feature? or what's best ,can you email some sammple codes to my mailbox? 371471521@qq.com
    Report Abuse
    • Reply
  • Igor Sherer
    on Jul 30 2012 04:31 AM
    Guru22030 points
    Guanqiang Chen
    U can use a reload timer (OSAL timer), which periodically sets an event which in turn invokes the many
    to one request (say every 10 seconds). You can stop timer run whenever you want, which will effectively
    stop the many to one requests.
    However if "you" know when a network reached it's final formation (no more router will be added from
    this point on), a gateway can initiate the many to one routing request only once, when the formation is
    done.
    Guanqiang Chen
    I have mentioned in the other post where you can read regarding many-to-one property, however I don't
    know if there a document describing the exact how to.
    You can use the isntructions I've posted in this thread and the other thread (same in both threads), it should
    pretty straight forward. The extra effort from you would be defining a new event and add a call for reload timer.
    If you asks yourself at which point in the code you should start a new reload timer, well, it's hard to answer,
    you probably should analyze your application needs.
    Br,
    Igor
    Report Abuse
    • Reply
  • Guanqiang Chen
    on Jul 30 2012 04:35 AM
    ok,i see!thank you very much!
    Report Abuse
    • Reply
  • Rui Zhang69778
    Posted by Rui Zhang69778
    on Jul 30 2012 15:04 PM
    Genius4525 points
    Your network size and traffic seems OK, just be careful for two issues based on my experience
    1. end device broadcast, that is too much traffic
    2. router discovery, some configure it as 30s, but if your routers are stationary, I guess you can change this into a much larger value
    Rui
    Report Abuse
    • Reply
  • Sam Elia
    Posted by Sam Elia
    on Jul 30 2012 16:40 PM
    Prodigy140 points
    Thanks Rui,
    I faced the same thing.  Much better results when changing broadcast mode to 16 bit destination mode and destination to 0x0000 for coordinator.
    Sam
    Report Abuse
    • Reply
  • Rui Zhang69778
    on Jul 30 2012 16:43 PM
    Genius4525 points
    Do you turn on APS level Ack?
    Rui
    Report Abuse
    • Reply
  • Sam Elia
    Posted by Sam Elia
    on Jul 31 2012 15:30 PM
    Prodigy140 points
    Rui Zhang69778
    Rui
    No, I don't think so. Just the NWK level Ack.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
