• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF RemoTI for RF4CE Remote Controls Forum » CC2530 does not get detected on the SmartRF Flash Programmer.
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Charvi Mehta
Posted by Charvi Mehta
on Dec 23 2011 05:09 AM
Prodigy150 points
    I have got some problem with getting my board detected on the SmartRf Flash Programmer. My CC2530 board does not get detected. During the SmartRf setup it gave me some errors as to not being able to install some drivers and delete some directories. May be the problem is related to that.
  I tried uninstalling and installing the SmartRF Flash Programmer twice but with no luck.   I am very short of time please help soon.
Thanks in advance.
CC2530 IAR Embedded Workbench RemoTI zigbee Flash Programmer Zigbee RF4CE
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Igor Sherer
    Posted by Igor Sherer
    on Dec 23 2011 05:19 AM
    Guru21965 points
    How exactly you have connected your board to the smartRF flash programmer, through
    CC debugger or smartRF05EB. Have you applied power to your board once it's connected
    using one of the above tools?
    Br,
    Igor
    Report Abuse
    • Reply
  • Charvi Mehta
    on Dec 23 2011 07:32 AM
    Prodigy150 points
            I have connected my board through smartRf05EB. and yes I connected my board first gave power to the smartRF05EB and then to my board. Does it work that way?
    Charvi.
    Report Abuse
    • Reply
  • Igor Sherer
    on Dec 23 2011 07:40 AM
    Guru21965 points
    In case of smartRF05EB do as follows:
    1. Apply power to your custom board
    2. Connect your board with a flat cable to a smartRF05EB
      Make sure that the direction of the cable is alright and
      pin #9 on the flat cable is connected to power comming
      from your board.
    3. Connect smartRF05EB to a PC with USB cable, make
      sure there no evaluation module mounted.
    4. Turn on power switch on the smartRF05EB, the third
      line on LCD should be "CC2530", once you see it, consider
      your board connected.
    Br,
    Igor
    Report Abuse
    • Reply
  • Rui Zhang69778
    Posted by Rui Zhang69778
    on Apr 19 2012 15:12 PM
    Genius4505 points
    Hi Igor:
    Connect your board with a flat cable to a smartRF05EB Make sure that the direction of the cable is alright and pin #9 on the flat cable is connected to power coming from your board.
    from the datasheet of EB 1.8.1, the pin 9 is not connected to anything. Do we need to connect pin 9 to power supply?
    Rui
    Report Abuse
    • Reply
  • TIABO
    Posted by TIABO
    on May 11 2012 02:23 AM
    Suggested Answer
    Expert6765 points
    Rui,
    If you wish to power the target board with +3.3V from the SmartRF05EB, connect the target's VDD to pin #2 and #9 (remember to mount a 0 ohm resistor in position R30 on SmartRF05EB).
    If your target is self powered, then connect its VDD to pin #2 only (e.g. by not having R30 mounted). Pin #2 goes to the level shifter onboard the SmartRF05EB.
    Igor Sherer
      pin #9 #2 on the flat cable is connected to power comming
      from your board.
    Br,
    ABO
    If this post answered your question, thank you for clicking  Verify Answer  below.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
