• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » WLAN Applications Forum » Bad BT sensitivity
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Bad BT sensitivity
Bad BT sensitivity
This question is not answered
tom tom101167
Posted by tom tom101167
on Mar 22 2012 01:23 AM
Prodigy60 points
The chipset is OMAP3630+ WL1271+TQM679002. But the sensitivity of BT is only about -70dBm.
Single_slot sensitivity will pass the spec which is -70dBm, but the Multi-slot sensitivity always fail.
We have supply power of WL1271 by single battery, it seems has no use. The circuit has almost no match circuit, so we have no ideal about it.
Would you give us som advice? thank you!
bluetooth omap3530 wl1271 tiwi bluetooth PCM BSP1 audio BT
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Moshe Meir
    Posted by Moshe Meir
    on Mar 26 2012 22:06 PM
    Intellectual1340 points
    At the beginning I would ensure that the fast clock source is appropriate and meet the WL1271 spec.
    Since you are using the WL1271, the Trio chip set – WLAN and BT,
    Could you let me know if the WLAN sensitivity is OK? This could clean up the fast clock.
    Are you using Module design or discrete design?
    Moshe
    Report Abuse
    • Reply
  • tom tom101167
    on Mar 27 2012 04:20 AM
    Prodigy60 points
    It has a bad wifi sensitivity, too, which is only -81dBm at 11Mbps and -66dBm at 54Mbps.
    We don't know the difference between Module design and discrete design. We layout the PCB of OMAP3630+WL1271+TQM679002 by ourselves, so we think it maybe a discrete design.
    Report Abuse
    • Reply
  • Moshe Meir
    on Mar 27 2012 04:32 AM
    It appears that you design a discrete design, means component on board. Module is a integrated solution on package.
     According the data you had shared it seems like you have HW issue, I would address the issue firstly to the fast clock phase noise.
    Please make sure that the fast clock meets the WL1271 spec.
    Moshe
    Report Abuse
    • Reply
  • Arild Kolsrud
    Posted by Arild Kolsrud
    on Mar 27 2012 10:52 AM
    Intellectual1320 points
    Hi:
    Does the PCB layout have 50 Ohm controlled impedance lines between WL1271, TQM679002 and the antenna/RF connector?
    Arild
    Report Abuse
    • Reply
  • tom tom101167
    on Mar 29 2012 23:50 PM
    Prodigy60 points
    Sorry for delay reply.
    The crystal we used is KDS DSG321G 38.4MHz. It seems meet the WL1271 spec.
    We also exchanged the crystal with another phone which has good BT sensitivity. Our phone still had the same bad BT sensitiviy and another phone still has good sensitivity.
    Would you give us more advice? thank you!
    Report Abuse
    • Reply
  • tom tom101167
    on Mar 29 2012 23:55 PM
    Prodigy60 points
    We used the 50ohm microstrip and attached the layout picture.
    Would you help check it? thank you!
    Report Abuse
    • Reply
  • tom tom101167
    on Mar 30 2012 01:04 AM
    Prodigy60 points
    We also did the experiment to delete the TQM79002, and connected the RF cable to PIN3 of TQM79002 directly to test the BT sensitivity.
    The performance has no improvement.
    Report Abuse
    • Reply
  • Moshe Meir
    on Apr 03 2012 06:44 AM
    Hello ,
    It looks like you have HW issue, it is reflected from WLAN and BT performance.
    Since your design is based on discrete design (chip on board) and not module solution (integrate solution) it is complicate to comment without reviewing the schematic and layout.
    There are appropriate WL1271 reference design and PCB design guideline to need to follow.
    Can you please let me know how did you get the information of WL1271 so far?
    Moshe
    Report Abuse
    • Reply
  • tom tom101167
    on Apr 04 2012 20:46 PM
    Prodigy60 points
    Our project is a smart phone which use OMP3630 as AP and VIA module as Modem.
    We got the reference design of WL1271 from VIA
    Would you help us check the SCH and Layout if you think it maybe has some problem in them?
    Thank you!
    Report Abuse
    • Reply
  • Arild Kolsrud
    on Apr 11 2012 12:00 PM
    Yes, we will check the schematic and layout.  Please email the files to akolsrud@ti.com
    Arild
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
