• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » WLAN Applications Forum » WL1271 support in DVSDK_4.03 04_03_00_06
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Veeravijayan Selvaraj
Posted by Veeravijayan Selvaraj
on May 02 2012 13:59 PM
Prodigy50 points
I want to build a linux image with WL1271 Wi-Fi drivers support using DVSDK_4.03 04_03_00_06 SDK for DM37xx EVM board. Can you please let me know the build steps/ configuration changes for that?
I am able to run Wi-Fi tests with prebuilt images which is there in the SDK release, but It's not working with the image i have created for omap3_evm_defconfig. So please let me the know the configuration changes for WL1271 support.
Veera
WL1271 + DM37xx
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Veeravijayan Selvaraj
    on May 03 2012 15:55 PM
    Prodigy50 points
    No replies so far.... Please give me the build steps to build image for DM37xx EVM board with WL1271 Wi-Fi tests support.
    Veera
    Report Abuse
    • Reply
    on May 04 2012 11:01 AM
    Prodigy50 points
    Hi All,
    Please let me know if my question is not clear.
    Veera
    Report Abuse
    • Reply
  • Eyal a
    Posted by Eyal a
    on May 06 2012 10:06 AM
    Genius9240 points
    Hi Veera,
    The Linux EZSDK Release 5.04.00.11 is available for download from http://software-dl.ti.com/dsps/dsps_public_sw/ezsdk/latest/index_FDS.html
    For WLAN Automatic build script please refer to  http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_mac80211_WLAN_build_scripts
    more information on the WLAN components and build descriptions refer to http://processors.wiki.ti.com/index.php/OMAP_WLAN_build_instructions_on_any_SDK
    Eyal
    Report Abuse
    • Reply
  • Eyal a
    Posted by Eyal a
    on May 06 2012 10:10 AM
    Genius9240 points
    Hi Veera,
    Please ignore the EZSDK Release, since it is not for the DM37xx, please try the WLAN Automatic build script  WiKi page.
    Eyal
    Report Abuse
    • Reply
    on May 07 2012 18:52 PM
    Prodigy50 points
    Hi Eyal,
    Thanks for your reply, I tried to build the WL12xx components using the build procedure given in http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_mac80211_WLAN_build_scripts.
    I'm getting following error:
    libtool: install: /usr/bin/install -c .libs/libnl.lai /home/vselvara/targetfs/lib/libnl.la
    libtool: install: warning: relinking `libnl-genl.la'
    libtool: install: (cd /home/vselvara/ti-dvsdk_dm3730-evm_04_03_00_06/wl12xx/libnl-2.0/lib; /bin/sh /home/vselvara/ti-dvsdk_dm3730-evm_04_03_00_06/wl12xx/libnl-2.0/libtool  --tag CC --mode=relink arm-arago-linux-gnueabi-gcc -g -O2 -version-info 2:0:0 -o libnl-genl.la -rpath /home/vselvara/targetfs/lib genl/ctrl.lo genl/family.lo genl/genl.lo genl/mngt.lo libnl.la -lm )
    libtool: relink: arm-arago-linux-gnueabi-gcc -shared  genl/.libs/ctrl.o genl/.libs/family.o genl/.libs/genl.o genl/.libs/mngt.o   -Wl,-rpath -Wl,/home/vselvara/targetfs/lib -L/home/vselvara/targetfs/lib -lnl -lm    -Wl,-soname -Wl,libnl-genl.so.2 -o .libs/libnl-genl.so.2.0.0 /home/vselvara/ti-dvsdk_dm3730-evm_04_03_00_06/wl12xx/libnl-2.0/
    libtool: line 7827: arm-arago-linux-gnueabi-gcc: command not found
    libtool: install: error: relink `libnl-genl.la' with the above command before installing it
    make[2]: *** [install-libLTLIBRARIES] Error 1
    make[2]: Leaving directory `/home/vselvara/ti-dvsdk_dm3730-evm_04_03_00_06/wl12xx/libnl-2.0/lib'
    make[1]: *** [install-am] Error 2
     make[1]: Leaving directory `/home/vselvara/ti-dvsdk_dm3730-evm_04_03_00_06/wl12xx/libnl-2.0/lib'
    make: *** [install-recursive] Error 1
    Can you please help me to resolve this error?
    Thanks in advance,
    Veera
    Report Abuse
    • Reply
  • Vita Preskovsky
    Posted by Vita Preskovsky
    on May 09 2012 07:04 AM
    Prodigy430 points
    Veera, hello.
    In order to help you I need more information about your Linux distribution, build environment, the way you untar the target file system and how you invoke the build script.
    Vita.
    Report Abuse
    • Reply
    on May 10 2012 18:06 PM
    Prodigy50 points
    Hi Vita,
    I'm using DVSDK_4.03 04_03_00_06 (dvsdk_dm3730-evm_04_03_00_06) linux SDK http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/dvsdk/DVSDK_4_00/latest/index_FDS.html
    Build Environment : Ubuntu 10.04 LTS 32 bit on VMware player.
    I installed dvsdk_dm3730-evm_04_03_00_06_setuplinux on ubuntu linux, and executed "${DVSDK}/setup.sh " to create targetfs.
    targetfs got created in my home folder.
    To build WiFi components, I followed the steps given in http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_mac80211_WLAN_build_scripts
    I copied wl12xx_build.sh and set_env (downloaded from the wiki site) to sdk folder and modified the set_env variable paths for my build environment.
    After setting up the Environmental variables and defconfig, I ran the script "wl12xx_build.sh all"
    Report Abuse
    • Reply
  • Vita Preskovsky
    on May 13 2012 08:21 AM
    Prodigy430 points
    Hi, Veera.
    The problem you've experienced is because of different behavior of sudo command on different machines: user's environment does not pass to sudo command. Therefor we changed the script in such way to have all needed environment variables inside setup-env file and do not use 'sudo' command inside the script.
    Please, download again http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_mac80211_WLAN_build_scripts the script and edit setup-env to provide necessary environment variables. If your root file system is opened with root privileges, run script with sudo:
    sudo ./wl12xx_build.sh all
    Vita Preskovsky
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
