• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » WLAN Applications Forum » Getting started with WL1271 and Rev G omap3evm
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
DaveB123
Posted by DaveB123
on Jan 31 2010 22:39 PM
Expert4775 points
I'm trying to take a factory "demo flashed", new-in-the-box Mistral Rev G OMAP3EVM and install the WLAN/BT drivers to get the WL1271 daughter card working.
It seemed like the easiest way to do this is to simply transfer the "v2......tar.bz" over to the evm...then untar...and run the scripts to install.
Here are the things I've stumbled over...
1st) Pumpkin seems to have a size limit and does not work as a TFTP server very well since the tar fils is over 32M so I had to untar on my host and then pull the DEMOs over seperately.
2nd) I'm getting an error in insmod sdio.ko stating that
"insmod: error inserting 'sdio.ko': -1 Invalid module format"
I'm assuming I have a versioning issue between what I DL-d from the WIKI for the WL1271 and what Rev G ships with...
Dave
Pumpkin Rev G evm wl1271 driver
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • sinoj issac
    Posted by sinoj issac
    on Feb 01 2010 05:42 AM
    Expert2800 points
    Hi Dave,
    As you pointed out, there is a versioning issue between WL1271 drivers and kernel uImage. You need to use the uImage and
    WLAN/BT drivers (v2.01.03.11-WL6.1.3.1.tar.bz2) from the below link to get the WL1271 daughter card working.
    (http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/dvsdk/DVSDK_3_00/latest/index_FDS.html
    Package is v2.01.03.11-WL6.1.3.1-1.0-Linux-x86-Install.
    The binaries will be available under //software/images/.
    The WL1271 Setup Guide.pdf describes how to reflash uImage and load WLAN/BT drivers.
    Sinoj
    Report Abuse
    • Reply
  • jason liu
    Posted by jason liu
    on Feb 02 2010 21:46 PM
    Prodigy60 points
    I refer the guid to complie the driver but i have shis err, how can i do?
    /usr/local/arm-2009q1/bin/../arm-none-linux-gnueabi/libc/usr/include/linux/if.h:125: error: redefinition of 'struct ifmap'
    /usr/local/arm-2009q1/bin/../arm-none-linux-gnueabi/libc/usr/include/linux/if.h:161: error: redefinition of 'struct ifreq'
    /usr/local/arm-2009q1/bin/../arm-none-linux-gnueabi/libc/usr/include/linux/if.h:211: error: redefinition of 'struct ifconf'
    Report Abuse
    • Reply
  • sinoj issac
    on Feb 03 2010 00:09 AM
    Expert2800 points
    Hi Jason,
    It seems that you have compiled the driver with tool chain version arm-2009q1.
    Please use compiler version arm-2007q3 for building the package.
    Sinoj
    Report Abuse
    • Reply
  • jason liu
    Posted by jason liu
    on Feb 03 2010 02:10 AM
    Prodigy60 points
    1) I just complie the WiLink6.1.3.1.tar.bz2 package
    2)my step is
    # soucre omap3530_env_noXCC.sh
     KERNEL_DIR=/home/jason/tipsp/OMAP35x-PSP-SDK/src/kernel/linux-02.01.03.11
    #make
    show the follow err:
    ipc_wpa.c:38:22: error: wpa_ctrl.h: No such file or directory
    Report Abuse
    • Reply
  • sinoj issac
    on Feb 03 2010 02:59 AM
    Expert2800 points
    Hi Jason,
    The WLAN driver needs to be compiled with open source wpa_spplicant-05.7 and openssl-0.9.8e.
    Please follow instructions given in "WL1271 Linux SDK Build Environment Instructions.pdf" to build the packages
    and execute commands given in Chapter-4 of the same.
    The wpa_supplicant and openssl must be downloaded into //common/wireless_src/.
    Hope that help.
    Sinoj
    Report Abuse
    • Reply
  • jason liu
    Posted by jason liu
    on Feb 04 2010 01:15 AM
    Prodigy60 points
    tanks
    compiled correctly~
    Now i want  this drvier  support WL2151,but I found that there is no Fw1251r1c.bin firmware release,
    how can i do ? in some of Makfiles  FW ?= 1273,but WL1251 is not supported .
    Tanks for you help.
    Report Abuse
    • Reply
  • Matt Kurtz
    Posted by Matt Kurtz
    on Feb 04 2010 10:03 AM
    Prodigy665 points
    Jason,
    This platform is designed to work with the WL1271 device, and does not include software support for WL1251.
    Matt
    Report Abuse
    • Reply
  • jason liu
    Posted by jason liu
    on Feb 04 2010 10:37 AM
    Prodigy60 points
    Tanks ,which drvier support wl1251-wg7210.
    Report Abuse
    • Reply
  • Matt Kurtz
    on Feb 04 2010 20:06 PM
    Prodigy665 points
    Jason,
    As we are only supporting WL1271 driver on this platform, I would advise that you could either :
    1. work directly with Jorjin for WL1251 support using their WG7210 module, or
    2. consider moving to WL1271
    Matt
    wl1271 driver wl1251
    Report Abuse
    • Reply
  • DavidVescovi
    Posted by DavidVescovi
    on Feb 06 2010 11:04 AM
    Genius4150 points
    Would love to see WL1271 support rolled into the Windows CE BSP..... that is unless part availability its going to be restricted to only large OEMs.
    Why even bother designing a module for the EVM if that is going to be the case.
    Report Abuse
    • Reply
  • Matt Kurtz
    on Feb 11 2010 08:35 AM
    Prodigy665 points
    David,
    WL1271 support in WinCE is coming mid-year; the work is already well underway now.
    The intent is that both the Linux & WinCE OMAP35x+WL1271 platforms can be adopted by a wide range of customers, big or small.
    Matt
    WL1271 WinCE WL1271 driver
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
