• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » WLAN Applications Forum » OMAP3530 WLAN ifconfig error
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Glenn Wainwright
Posted by Glenn Wainwright
on Jun 24 2010 16:40 PM
Expert1425 points
So I've already had some build issues that you guys have helped out with - perhaps you can also solve what will hopefully be the last remaining problem on this setup.  I'm working with an OMAP3530 using linux 02.01.03.11 and trying to get the v2.01.03.11-WL6.1.3.1 software (patched to use 2008q1 toolchain) working on a setup that is hardware-equivalent to the Mistral WLAN daughter card.
Everything is building now (hooray) and I'm able to insmod the modules (yay!), but ifconfig is not able to bring the interface up.
Here's the process:
root@omap3evm:~/wlan/wlan# insmod sdio.ko
root@omap3evm:~/wlan/wlan# insmod bmtrace.ko
root@omap3evm:~/wlan/wlan# insmod tiwlan_drv.ko
tiwlan0 (): not using net_device_ops yet
Old CONTROL_PADCONF_UART1_CTS value = 0x01000110
Old CONTROL_PADCONF_UART1_RTS value = 0x00000000
New CONTROL_PADCONF_UART1_CTS value = 0x01000104
New CONTROL_PADCONF_UART1_RTS value = 0x011c0000
GPIO-150 autorequested
Inside hPlatform_DevicePowerOff()
root@omap3evm:~/wlan/wlan# ./tiwlan_loader
root@omap3evm:~/wlan/wlan# ifconfig tiwlan0 10.1.100.56 netmask 255.255.255.0 up
ifconfig: SIOCSIFFLAGS: Cannot assign requested address
Running ifconfig -a shows the following for tiwlan0:
tiwlan0   Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          inet addr:10.1.100.56  Bcast:10.255.255.255  Mask:255.0.0.0
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:100
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
I'm concerned that there is no MAC address assigned - that looks like a likely problem to me - does the loader take care of that automatically, or is that something I need to specify myself somehow?  Any other thoughts on what the issue might be?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Glenn Wainwright
    on Jun 24 2010 16:42 PM
    Expert1425 points
    Err, actually that ifconfig output looks like this (with the right netmask):
              inet addr:10.1.100.56  Bcast:10.1.100.255  Mask:255.255.255.0
    Report Abuse
    • Reply
  • sinoj issac
    Posted by sinoj issac
    on Jun 25 2010 02:49 AM
    Expert2800 points
    Hi Glenn,
    Please let me know what does happen to 'ifconfig tiwan0 up after running tiwlan_loader',  whether firmware is downloaded or not?
    If SDIO interface is fine, it will read chip-id and download the firmware. To get more debug messages run 'dmesg' and verify whether firmware is downloaded or not?
    Sinoj
    WL1271 module start WLAN
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 25 2010 09:23 AM
    Expert1425 points
    Running 'ifconfig tiwlan0 up' just gives the 'Cannot assign requested address' message that I posted above.  There is nothing in dmesg except what I already posted... which is odd, because looking at the source, there are a lot of status messages that I should be seeing.  I'll see about adding a few more debug messages in the initialization and see where it's stopping.  Thanks for the hint - let's see if that's enough to get me going.
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 25 2010 09:42 AM
    Expert1425 points
    For some reason, the 'os_error_printf' calls weren't outputting to screen or to dmesg.  Go figure.  Replacing those with simple printf's allowed me to see what was going on inside... and it's getting to the end of init_driver without any errors.  Is there a way to verify that the device does actually have the firmware loaded like the loader claimed to do?
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 28 2010 13:01 PM
    Expert1425 points
    It looks like the problem is that ndo_validate_addr is being set to the wrong function.  Somehow, it's being set to dev->set_multicast_list instead of dev->validate_addr.  The structures in netdevice.h look equivalent, so I'm not sure how that's happening.  Still investigating, but I was wondering if that clue jars loose any ideas here.
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 28 2010 17:49 PM
    Suggested Answer
    Expert1425 points
    So, indeed, manually setting up the netdev_ops structure instead of relying on dev.c to simply assign dev->netdev_ops to &dev->init means that the correct function pointers are now being assigned... and we don't get a MAC address verification failure.
    Now, I am able to get some activity in the driver when I call ifconfig:
    root@omap3evm:~/WL1271_demo_01/wlan# ifconfig tiwlan0 10.1.100.56 netmask 255.25
    5.255.0 up
    wlanDrvIf_Start()
    Before drvMain_InsertAction()
    Inside drvMain_InvokeAction()
    drvMain_Sm():  State = 0, Event = 0
    drvMain_Sm():  State = 1, Event = 1
    Inside drvMain_SetDefaults()
    pInitParams->RoamingScanning_2_4G_enable 0
    Inside hPlatform_DevicePowerOn()
    drvMain_Sm():  State = 2, Event = 2
    @@@ enable_mmc_power() 2
    setting SDIO F&I clock Configuration
    done setting SDIO F&I clock Configuration
    SDIO clock Configuration is now set to 24Mhz
    After sdioDrv_ConnectBus, iStatus=0
    After SD_IO_GO_IDLE_STATE, iStatus=0
    sdioDrv_ExecuteCmd() SDIO Command error status = 0x18000
    After VDD_VOLTAGE_WINDOW, iStatus=-1
    Try to SDBus Connect again...
    It appears to get to the point where it sends the initialization stream, and I can verify that there is activity on the clock for a short period of time, but the MMCHS_STAT.CC bit does not appear to be set before we time out.  It then attempts to re-connect, and we alternate several times between an request_irq failure and the failure above until it finally quits.
    sdioDrv_InitHw() -  request_irq FAILED!!
    After sdioDrv_ConnectBus, iStatus=-16
    ...snip...
    [WLAN] Exit application
    Before netif_start_queue()
    Leaving wlanDrvIf_Start()
    Any thoughts on what the issue might be?
    Report Abuse
    • Reply
  • Sanjay Kumar42857
    Posted by Sanjay Kumar42857
    on Jun 29 2010 01:00 AM
    Intellectual265 points
    Hi Glenn,
    From the above log it seems that SDIO inteface is not behaving properly.  Please follow the below procedure to test SDIO interface.
    Commands:
    # insmod sdio.ko
    # insmod testsdio.ko (available under  "external_drivers/omap3530/Linux/sdio/" after build the driver)
    # echo i > /proc/sdio_test  (Initializing  the SDIO interface and it will provide the CHIP id)
    #echo cs > /proc/sdio_test
    This above command will transmit the 64 to 512 byte data over the SDIO interface and check the success of data transmission.
    Please verify the SDIO inteface, wheather it is working properly.
    wl1271 driver
    Report Abuse
    • Reply
  • sinoj issac
    on Jun 29 2010 02:21 AM
    Expert2800 points
    Hi Glenn,
    Could you please try the pre-built binaries (uImage and wlan) available in v2.01.03.11-WL6.1.3.1 package? Is it possible to run on your set up?
    That will help us in identifying whether the problem is build issue or hardware issue.
    Sinoj
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 29 2010 09:43 AM
    Expert1425 points
    Thank you guys for the excellent suggestions.  So, I'm using now only the pre-built kernel image and driver package.  Running the sdio test, I get an error similar to the one I saw before.  In sdioDrv_ExecuteCmd(), it sends a command and then checks the Command Complete bit to see that it sent... and we get nothing.
    Full error text:
    root@omap3evm:~/v2.01.03.11-WL6.1.3.1/wlan# insmod sdio.ko
    root@omap3evm:~/v2.01.03.11-WL6.1.3.1/wlan# insmod testsdio.ko
    OMAP3430_Wlan_Hardware_Init start
    OMAP3430_Wlan_Hardware_Init() enter
    Configuring OMAP3530 pin MUX
    OMAP3430_Wlan_Hardware_Init() exit
    OMAP3430_Wlan_Hardware_Init - SUCCESS
    OMAP3430_TNETW_HardReset start
    OMAP3430_TNETW_Power(-OFF-)
    OMAP3430_TNETW_Power(-ON-)
    OMAP3430_TNETW_HardReset - SUCCESS
    sdio_test_module_init: SDIO Test Reset OK
    sdio_test_module_init: OK
    root@omap3evm:~/v2.01.03.11-WL6.1.3.1/wlan# echo i > /proc/sdio_test
    sdioDrv_ExecuteCmd() SDIO Command error status = 0x18000  //First error here
    In sdio_test_init: going to perform set_partition. mem size = 0x16800, mem addr =
      0x0, reg size = 0x8800, reg addr = 0x300000
    Running set_partition status = sdioDrv_WriteSyncBytes() SDIO Command error status
     = 0x18000
    -1 NOT OK
    sdioDrv_ReadSyncBytes() SDIO Command error status = 0x18000
    Read device ID via ReadByte: 0x0
    sdiodrv_send_data_xfer_commad() SDIO Command error! STAT = 0x18010
    sdiodrv_data_xfer_sync() buffer disabled! length = 4 BLK = 0x4 PSTATE = 0x0
    sdioDrv_WriteSync() FAILED!!
    sdiodrv_send_data_xfer_commad() SDIO Command error! STAT = 0x18000
    Report Abuse
    • Reply
  • sinoj issac
    on Jun 29 2010 10:18 AM
    Suggested Answer
    Expert2800 points
    Hi Glenn,
    It looks like a hardware issue. You need to verify the SDIO connectivity and check whether WLAN chip is powered on or not.
    Also, could you please tell us about your setup/platform? Is that MMC2 on omap3530? and which GPIO is used for WL_EN?
    Sinoj
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 29 2010 10:26 AM
    Expert1425 points
    It is MMC2 on OMAP3530.  The WL_EN pin is currently not under GPIO control, but is hooked up to a jumper that is pulling it high (and I can manually switch it to low).  I can verify clock signals going over the clock pin and that something is changing in the CMD line while those clock signals are running.  Does WL_EN need to be connected to a GPIO?  Is there anything else that I can test that would be helpful?
    Report Abuse
    • Reply
  • sinoj issac
    on Jun 29 2010 10:48 AM
    Suggested Answer
    Expert2800 points
    The WL_EN is not necessarily to be GPIO.  echo i > /proc/sdio_test is the best way of validating the hardware from driver.
    Also, you can try to reduce interface clock rate to some  lower value (6Mhz) in SdioDrv.c and use it.
    Sinoj
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 29 2010 11:24 AM
    Expert1425 points
    6Mhz clock doesn't seem to change any behavior.  Looking at the output above though... the point where it fails is not the first command sent across the interface.  It completes sdioDrv_InitHw successfully, and it sends the SD_IO_GO_IDLE_STATE command successfully, but then it fails on VDD_VOLTAGE_WINDOW.  So it's not that it can't execute any commands... any idea what VDD_VOLTAGE_WINDOW does - maybe that might give a clue?
    Report Abuse
    • Reply
  • sinoj issac
    on Jun 29 2010 12:12 PM
    Expert2800 points
    For SD_IO_GO_IDLE_STATE command we do not expect any response from SD card. VDD_VOLTAGE_WINDOW  is the first command that the host expect some response from the device. It is about the voltage range that card can support. Here, it looks like card/device does not respond to that command at all.
    Report Abuse
    • Reply
  • Glenn Wainwright
    on Jun 30 2010 17:26 PM
    Verified Answer
    Verified by Glenn Wainwright
    Expert1425 points
    I knew it would be something simple and stupid, but I didn't think it would be this stupid.  Going over the connections to the board again for the half-dozenth time, we noticed that the power source jumper wasn't set to DC.  Isn't that always what happens...
    Thank you guys again for your excellent help.  Hopefully that was the last hurdle.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
