• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF PurePath Wireless Audio Forum » CC debugger won't work with CC85XX development kit
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Igor Majki��
Posted by Igor Majki��
on Nov 23 2011 05:52 AM
Prodigy60 points
I just received from my professor new CC85XX development kit.  The boards seem to work correctly, and pair correctly.
However, the CC Debugger doesn't seem to work correctly.  When connected to the PurePath Wireless AudioEB, with either a CC85XX, or CC85XX-CC2590 range extender module,  there is a steady RED light, indicating no RF device was found.
 The SmartRF Studio program as well as the SmartRF Flash Programmer and the PurePath Wireless Configuration programs all show the CC Debugger as connected in the programs, so the USB drivers are working.
I have completely uploaded the latest CC Debugger firmware, and still no change in the situation.
The failure occurs regardless of which of the 2 AudioEB boards is attached, and regardless of any combination of AudioEB and RF module from the CC85XX development kit.
i am runing software on 64 bit win7 and 32 bit XP but the problem remains the same
thanks
igor
(majkic.igor@gmail.com)
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Igor Sherer
    Posted by Igor Sherer
    on Nov 23 2011 06:24 AM
    Guru22030 points
    Hi Igor,
    Have you followed exactly the same way as described in "CC85xx Development Kit Hardware User’s
    Guide", figure 3 - page 8? (Purepath Wireless AudioEB must be powered)
    Br,
    Igor
    Report Abuse
    • Reply
  • Igor Majki��
    on Nov 23 2011 07:01 AM
    Prodigy60 points
    Of course, everything is connected as in Figure 3
    Report Abuse
    • Reply
  • Igor Majki��
    on Nov 23 2011 07:03 AM
    Prodigy60 points
    I followed the red line on the cable
    Report Abuse
    • Reply
  • Igor Sherer
    on Nov 23 2011 07:10 AM
    Guru22030 points
    Try to do the following:
    1. Unplug the PurePath Wireless AudioEB and CC debugger.
    2. Ensure that you have powered the PurePath Wireless AudioEB.
       LEDs sould be blinking (there are some LEDs on this board,
      are there??)
    3. Unplug CC debugger from USB cable and then connect it with
      the flat ribbon cable to AudioEB (as described in figure 3).
    4. Connect CC debugger to a PC with USB cable, do you see the
      LED on CC debugger goes green?
    Br,
    Igor
    Report Abuse
    • Reply
  • Susan Williams
    Posted by Susan Williams
    on Nov 23 2011 09:43 AM
    Intellectual385 points
    Did you try pressing the little button?  Sometimes I have to press that before the light goes green.
    Report Abuse
    • Reply
  • Igor Majki��
    on Nov 23 2011 13:24 PM
    Prodigy60 points
    I tried, but again does not work
    Report Abuse
    • Reply
  • Igor Majki��
    on Nov 23 2011 13:27 PM
    Prodigy60 points
    you mean the reset button on the debugger, and I tried, but again does not switch to green
    Report Abuse
    • Reply
  • Fredrik K
    Posted by Fredrik K
    on Nov 24 2011 00:50 AM
    Genius10250 points
    Hi Igor,
    The audioEB is connected to power, right? Try rotating the debug connector 180 deg, and see if that helps.
    /Fredrik
    PS. If I answered your question, please hit   Verify Answer  !
    Report Abuse
    • Reply
  • Igor Majki��
    on Nov 24 2011 05:06 AM
    Prodigy60 points
    yes it is connected to power. I tried rotating debug conector and in one case there is red LED, and on other case there are no light at all, with debbugrer conected to PC by USB cable.
    Report Abuse
    • Reply
  • Igor Sherer
    on Nov 24 2011 05:16 AM
    Guru22030 points
    Hi Igor,
    Can you please check with a voltmeter if cc85xx powered through its power pins (all the pins
    supplied with proper voltage). For the list of these pins, please refer to cc8520 datasheet, pin
    description table.
    Also please ensure that J10's (on AudioEB) Pin1 and 2 are jumpered!
    Br,
    Igor
    Report Abuse
    • Reply
  • Fredrik K
    Posted by Fredrik K
    on Nov 24 2011 06:21 AM
    Genius10250 points
    Measure the output voltage of U7 and U10 on the EB. Output voltage is on pin 6. If one of them doesn't work you can try to bridge 3V3_IO and 3V3_SEC on P7.
    /Fredrik
    Report Abuse
    • Reply
  • fernando rivas
    Posted by fernando rivas
    on Aug 09 2012 01:19 AM
    Prodigy50 points
    I have the same problem and I have tried everything right now and my CC debugger doesn´t identify the CC8531 chip connected on EB, such as TI user guide shows.
    Is it possible that CC debugger fails? I have verified all signals and supply and I/O voltages are correct.
    Please, help me!
    Thanks in advance.
    Fernando
    Report Abuse
    • Reply
  • Kristoffer S
    Posted by Kristoffer S
    on Aug 09 2012 03:55 AM
    Expert6090 points
    Hi Fernanndo,
    You can try step 8.1 in the user's guide for the CC Debugger: http://www.ti.com/lit/ug/swru197e/swru197e.pdf
    -Kristoffer
    Thank you for clicking  Verify Answer  if this answered your question!
    Report Abuse
    • Reply
  • fernando rivas
    on Aug 09 2012 04:53 AM
    Prodigy50 points
    Hi Kristoffer,
    I have tried step 8.1 too, and the result was the same. I have also tried step 8.2 but SmartRF Flash Programmer doesn´t detect CCDebugger again.
    As Igor Majki says, I tried rotating debug conector but the  led lights RED, but I knwo this isn´t the right way to connect it.
    Besides, I have tried step 8.3 to reboot CCdebugger, but it doesn´t solve the problem
    I haven´t tried 8.4 step, because I have only one CCdebugger and SmartRF05EB. I have SmartRF04EB, but I think it is no possible to make it with this.
    Any idea?
    Report Abuse
    • Reply
  • Igor Sherer
    on Aug 09 2012 04:58 AM
    Guru22030 points
    Hi Victor,
    Could you connect the CC debugger to smartRF05EB, the smartRF flash programmer should
    detect CC2511 device, is it detected?
    To be more precise, could you debug the CC2511 SoC on smartRF05EB with your CC debugger,
    simply connect a flat cable from CC debugger to P2 (USB debug) header on smartRF05EB
    Br,
    Igor
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
