• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF PurePath Wireless Audio Forum » CC85XXDK-HEADSET Noise
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Gary Siu
Posted by Gary Siu
on Feb 29 2012 21:38 PM
Intellectual350 points
Hi Kjetil
I use Headset Kit, and set fixed offset Volume to 45db inconfigurator have bigger noise in receive output. Do you have solution to solve it?
Gary Siu
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Gary Siu
    Posted by Gary Siu
    on Feb 29 2012 21:43 PM
    Hi Kjetil
    I recorded a noise and attached.
    Click here to play this audio clip
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Mar 05 2012 09:55 AM
    Genius17795 points
    Hi Gary,
    Why do you want to set this high offset and what are your trying to acvhieve?
    The noisefloor will be increased by 45 dB and that is what you hear on the other end.
    Kjetil
    PS. Thank you for clicking  Verify Answer  if this answered your question!
    Report Abuse
    • Reply
  • Gary Siu
    Posted by Gary Siu
    on Mar 05 2012 20:16 PM
    Hi Kjetil
    I use for condenser Mic input and set it as high gain.
    Gary Siu
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Mar 12 2012 09:49 AM
    Genius17795 points
    Thanks Gary,
    You could look into adjusting the MICBIAS inside the AIC3204.
    If you in the configurator enable  custom setup under external audio device (audio interface tab) for the slave, you will see that a new panel pop's up called audio device customization. Press "reset all" and select the configuration for INACTIVE to LOW-POWER. This will set the mic bias to whatever you feel like. You should be able to set this higher than what is used today. Cross-check with the AIC3204 datasheet:
    6.2.130 Page 1 / Register 51: MICBIAS Configuration Register
    http://www.ti.com/lit/ds/symlink/tlv320aic3204.pdf
    Hope this helps.
    Please let me know if you have any questions with regards to this.
    Kjetil
    Report Abuse
    • Reply
  • MD Home
    Posted by MD Home
    on Mar 12 2012 12:31 PM
    Intellectual570 points
    Kjetil,
    I try Headset kit with peaker output. We facing some problem about echo when speaker talk close the speaker output, I use condensor MIC. May I check with you whether adjusting the MICBIAS can solve this issue or not? and how to do this?
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Mar 20 2012 04:44 AM
    Genius17795 points
    Hi MD Home,
    Two things you can play with, one is the input volume offset in the PurePath Wireless Configurator and the other is adjusting and playing with the MICBIAS setting. What you can do is to try to lover the microphone gain and see if this help with the issue.
    To adjust the input volume offset, please use the Volume Control panel in the cofigurator to adjust this (Fixed offset).
    To adjust the MICBIAS settings you will need to enale custom setup in the audio interface panel and then alter the MICBIAS settings in the INACTIVE to LOW-POWER settings in the Audio Device Customization panel.
    In your final design you can look at implementing a echo cancellation algorithm. You will need to replace the AIC3204 with a CODEC with miniDSP capabilities (e.g the AIC3254 or similar) and have a small MCU to configure the codec/dsp as the memory for a echo cancellation algorithm exceedes what we have internal available in the CC85xx device. You can find more info on a echo cancellation algorithm here:
    http://e2e.ti.com/support/data_converters/audio_converters/f/64/t/70540.aspx
    Hope this helps.
    Kjetil
    Report Abuse
    • Reply
  • MD Home
    Posted by MD Home
    on Apr 03 2012 13:40 PM
    Hi Kjetil,
    Now we considering to replace AIC3204 with AIC3254. Per your suggestion, we need to have one more MCU(MCU + CC85XX) to configure echo cancellation algorithm in AIC3254?
    Report Abuse
    • Reply
  • Knighty Nimp
    Posted by Knighty Nimp
    on Apr 04 2012 10:44 AM
    Intellectual660 points
    We are working on  wireless MIC. In my design used CC8520 plus AIC3254 for Microphone side and CC8531 plus AIC3420 for speaker side. My question is how do we know when paring btweew Mic side and speaker successful.
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Apr 17 2012 04:59 AM
    Genius17795 points
    MD Home
    Hi Kjetil,
    Hi MD Home,
    I am quite certain you do. Do not know the AIC devices in full detail, but echo cancellation is one of those things that I would assume uses more than the 1500 bytes we have internally for CODEC config. The guys over at the codec forum would know:
    http://e2e.ti.com/support/data_converters/audio_converters/default.aspx
    Kjetil
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Apr 17 2012 05:06 AM
    Genius17795 points
    Knighty Nimp
    Hi Knighty,
    First of all I am a little confused to why you selected CC8531 for the speaker side. This one have USB interface and not I2S so it can't work with any of the AIC devices.
    In our reference designs we have a status led that can be used to show the different states (Alone, Standby, Active and Pairing). You can configure this in the PurePath Wireless Configurator in the status indication panel.
    Hope that helps.
    Kjetil
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
