• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF PurePath Wireless Audio Forum » AIC3254+CC8530 : Click noise on the microphone input
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Bernard Franzi
Posted by Bernard Franzi
on Jul 25 2012 09:17 AM
Prodigy150 points
I am testing a prototype of a new project using AIC3254 + CC8530 + CC2590 in host mode with a microchip controler. sending the SPI commands to the chips.
I have realized two PCB to have a master and a slave. The transmission is only monophonic bidirectionnal.
On the master the input and the output are made on differentials signals.
On the slave the HP is differential and i use an electret microphone.
The channel master to slave works perfectly and the sound is good in the HP but the channel slave to master involving the microphone as a source has some clicks added to the sound signal. these clicks appears only when the microphone is used. There are no clicks during the silents. I noticed also rthat the level of the clicks is quite constant. That's to say if you increase the sound signal, the clicks level remain constant.
I have tried some modifications in the decoupling of the AIC3254 but with no result.
In this design i used the SDK scheme as a basic cabling to respect in terme of component value. The main difference is the VDD that i choose to be 3V instead of 1.8V. I also used the BQ25015 as a lipo charger and main regulator for the 3V supply.
I will be glad to receive any idea
Thank you
Bernard
CC8520 AIC3204
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kjetil
    Posted by Kjetil
    on Jul 31 2012 07:36 AM
    Genius17795 points
    Hi Bernard,
    Hard to say for certain here but a few questions to try to narrow this further down:
     - reduce the output power to the minimum (but do not select range extender none) for the slave side - any reduction or changes to the click?
     - "reverse" the slave and master roles for the two boards and see if behavior changes
     - does touching the mic connector on the slave change things?
     - are the click frequent in period/time?
     - if you have access to the Headset SDK, could you try the same configuration there and use the same electret microphone?
    Kjetil
    PS. Thank you for clicking  Verify Answer  if this answered your question!
    Report Abuse
    • Reply
  • Bernard Franzi
    on Sep 20 2012 01:21 AM
    Prodigy150 points
    Hi Kjetil,
    It took a long time to answer due to holidays and a new routing of the board.
    But now the "cjick" remains the same with the new board.
    We have seen that the "clic" frequency is exactly 75 Hz and it appears as a pulse that is added to the main signal.
    The 'clic" doesn't seem to be depending of the output power nor of any touch on the microphone.
    Changing the decoupling of the board has no effect.
    If you have some idea you are welcome.
    Bernard
    audio transceiver transmitter receiver handset radio project audio codec bidirectional communication
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Sep 20 2012 06:58 AM
    Genius17795 points
    Hi Bernarnd,
    Tough one. If the click frequency is 75 Hz we can rule out any power pulling introduced by the RF protrocol (output power not having an effect indicates the same).
    Most likely this is picked up by the analog path prior to the AIC device. I'm not an expert in these devices but do believe these have a loopback option so that you can test just the audio/analog path on your boards to see if it becomes more obvious where the click is generated.
    Might be helpful if you could record and post a short sample that includes the click but is otherwise silent.
    Kjetil
    Report Abuse
    • Reply
  • Bernard Franzi
    on Sep 21 2012 09:47 AM
    Prodigy150 points
    Hi Kjetil,
    Up to now i have some problems to see the power pulling and i didn't solve my deffect.
    I made a creen caoture og the cjick that appear as a pulse reaching the 0V that is added to the main signal.
    On the screen capture we see the ouput of the master in blue. I put a sinus signal on the microphone entry of 100 mV CC precisely at 75.00 Hz
    At this frequency the clic is completely synchronous
    I ll try some other experiments to find the signal on the board.
    Thank you for help
    Best regards
    Bernard
    AIC3204 8520 8530
    Report Abuse
    • Reply
  • Bernard Franzi
    on Sep 26 2012 11:12 AM
    Prodigy150 points
    Hi Ketjil,
    A new information on my problem
    It seems that my snapshot wasn't in my message so i try it again.
    THe new information is that if i change the frequency from 48000 Hz to 32000 Hz the pollution pulse frequency step down from 75 Hz to 50 Hz
    That means that the ration is constant equal to 640
    If someone has a idea to explain that behaviour
    Best regards
    Bernard
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Sep 27 2012 10:20 AM
    Genius17795 points
    Hi Bernard,
    Interesting information - could you also check if latency setting will affect the frequency of the click?
    Another thing that would be interesting to know is if this disappears if you configure the master as a mono microphone base station.
    Can you please send us the configuration files and configurator version number (including build id) as seen on the start panel?
    Kjetil
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Sep 28 2012 02:50 AM
    Genius17795 points
    Bernard,
    One thing that can lead to periodic clicks like this or poor audio performance is (from the help system in the PurePath Wireless Configurator - troubleshooting):
    Audio is heavily distorted in host-controlled operation, but OK in autonomous operation: Verify parameters used in the NWM_ACH_SET_USAGE EHIF command.
    Kjetil
    Report Abuse
    • Reply
  • Bernard Franzi
    on Sep 28 2012 03:20 AM
    Prodigy150 points
    Hi Kjetil,
    I have tried various latency but the pulse fréquency remains the same. It seems to be depending only of the sample rate.
    I have also tried to change the ratio of BCLK with 32 or 64 with no change.
    For information i use de PPWC 1.4.0.37396
    I send the project files for information
    Best  regards
    Bernard
    Report Abuse
    • Reply
  • Kjetil
    Posted by Kjetil
    on Sep 28 2012 09:46 AM
    Genius17795 points
    Hi Bernard,
    Thank you for that information. Please let us know when you have verified your NWM_ACH_SET_USAGE parameters (quickest might be to just operate the cards in autonomous mode). The periodic behavior that changes with sample rate bare signs that something potentially could be going haywire with our FW and want to rule this out or find the root cause so that we can fix any issue.
    Have been running several tests here in my office over the two days and have not found anything wrong nor do we have other reporting something similar, wrong NWM_ACH_SET_USAGE is the only explanation we can think of right now.
    Will run more tests when you have posted your project files - please share your code (snippet is enough) of the  NWM_ACH_SET_USAGE command so that we can look at the parameters vs. your project files.
    Kjetil
    Report Abuse
    • Reply
  • Bernard Franzi
    on Oct 01 2012 03:08 AM
    Prodigy150 points
    Programmation Texas.rar
    Hi kjetil,
    Thank you for your interst to my problem.
    For the use of the NWM_ACH_SET_USAGE, i have tried 2 configurations.
    The first one was :
    master / chapter audio streaming / master to slave / Front primary left + AD0 + right + SLAC
    master / chapter audio streaming / slave to master / Microphone0  + AD1 + left + SLAC
    The matrix sent for the NWM_ACH_SET_USAGE was 00 FF FF FF - FF FF FF FF - FF FF FF FF - 01 FF FF FF
    The second one was:
    master / chapter audio streaming / slave to master / Input Left+ AD1 + left + SLAC
    The matrix sent for the NWM_ACH_SET_USAGE was 00 FF FF FF - FF FF FF FF - FF FF 01 FF - FF FF FF FF
    The two configurations gave the same result.
    As i tried some other possibilities for the NWM_ACH_SET_USAGE the result was directly no sound at all.
    I didn't see if my file was correctly attached in my last post so i tri it again.
    I will make some other  tests today and i will report you.
    Best regards
    Bernard
    Report Abuse
    • Reply
  • Kristoffer S
    Posted by Kristoffer S
    on Oct 01 2012 04:47 AM
    Expert6050 points
    Hi Bernard,
    Try the following vector:
    00 FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF
    This corresponds to the channel index you see in the configurator (see picture below):
    Best regards
    Kristoffer
    Report Abuse
    • Reply
  • Bernard Franzi
    on Oct 01 2012 07:01 AM
    Prodigy150 points
    Hi Kristoffer,
    Thank you for your help
    That is the right solution to my problem
    It is amazing to see or hear  the bad effect of a 1 instead of a 0 in that register.........
    I can now continue my project
    Best regards
    Bernard
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
