• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » BLE Server/Clent Parameters
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Peter Clerico
Posted by Peter Clerico
on Feb 15 2012 07:57 AM
Intellectual355 points
Hello, my customer (on copy) is evaluating BLE using the KeyFobDemo server demo with an iOS app.  His concerns/comments are below:
"I'm writing the test code for iOS, using Apple's Core Bluetooth.  There are some restrictions in connection management imposed by this - the very first is that the client app cannot specify connection parameters, it is up to the server device to negotiate preferred values if they are different from the initial connection values.
 The KeyFobDemo has several constants in peripheral.c that appear to specify the connection interval, the slave latency and the supervisor timeout.  I've changed these and yet don't see any change in the performance of my app.  Using the Packet Sniffer I see there ADV_CONNECT_REQ message, but don't see any response from the device, to negotiate different parameters.
 So before I go too far I'm wondering if the server code uses these values, and should it be attempting to negotiate with the client?"
Thanks in advance for any advice/direction.
Peter
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • kazola
    Posted by kazola
    on Feb 15 2012 08:13 AM
    Guru11075 points
    I think these are some issues that are getting included in the new TI BLE Stack, coming this february.
    Bye.
    Please click the     Verify Answer     button on a post if it answers your question! :)
    Report Abuse
    • Reply
  • GregS
    Posted by GregS
    on Feb 15 2012 09:12 AM
    Verified Answer
    Verified by Peter Clerico
    Expert4165 points
    Look at simpleBlePeripheral example. and set the automatic update negotiation.
    // Whether to enable automatic parameter update request when a connection is formed
    #define DEFAULT_ENABLE_UPDATE_REQUEST FALSE
    GAPRole_SetParameter( GAPROLE_PARAM_UPDATE_ENABLE, sizeof( uint8 ), &enable_update_request );
    Note - that either side should have a range of these values, and the negotiation should find a value both side agree on.
    BR,
    -Greg
    Report Abuse
    • Reply
  • Don Clark
    Posted by Don Clark
    on Apr 11 2012 07:06 AM
    Prodigy130 points
    I did that, and re-built the executable, re-flashed into my CC2540 dongle.  Running the Sniffer I see traffic, and I see three SIG_Connection_Param_Update_Req go across, and one SIG_Connection_Param_Update_Rsp with value 0x0001.  But the connection to the keyfob is never established.  The parameter settings should be acceptable to Core Bluetooth - I've included the constants as they are set in my current executable, below.  So I'm wondering about the actual negotiation protocol - what should I be seeing?  I've included the psd file from the TI packet sniffer.2604.Connection session FAILED-3.psd
    //#define DEFAULT_ENABLE_UPDATE_REQUEST         FALSE  // 2/17/12 dfc made TRUE
    #define DEFAULT_ENABLE_UPDATE_REQUEST         TRUE
    // Use limited discoverable mode to advertise for 30.72s, and then stop, or
    // use general discoverable mode to advertise indefinitely
    #define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_LIMITED
    //#define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_GENERAL
    // Minimum connection interval (units of 1.25ms, 80=100ms) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     80
    // Maximum connection interval (units of 1.25ms, 800=1000ms) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     800
    // Slave latency to use if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_SLAVE_LATENCY         0
    // Supervision timeout value (units of 10ms, 1000=10s) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_CONN_TIMEOUT          1000
    Report Abuse
    • Reply
  • Su mington
    Posted by Su mington
    on Apr 27 2012 00:04 AM
    Prodigy60 points
    Any update ?
    I'm facing the same issue now. The connection is never established if "DEFAULT_ENABLE_UPDATE_REQUEST" was enabled. The connection parameters should be acceptable to my iPhone4S.
    Report Abuse
    • Reply
  • Don Clark
    Posted by Don Clark
    on Apr 27 2012 08:19 AM
    Prodigy130 points
    Yes.  There are some constraints required by Core Bluetooth, and if your settings conflict then the negotiation won't happen.  This worked for me, using my iPhone 4S:
    // Minimum connection interval (units of 1.25ms, 80=100ms, 16=20ms) if automatic parameter update request is enabled
    // For Core Bluetooth must be => 20 mSecs (or 16 units), <= 1980 ms (2000 ms - 20 ms)
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     16    // 20 ms
    // For Core Bluetooth must be <= 2000 mSecs (2 seconds, or 1600 units)
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     32     // 40 msecs
    #define DEFAULT_DESIRED_CONN_TIMEOUT          600  // 6 seconds, max allowed by Core Bluetooth
    Report Abuse
    • Reply
  • Su mington
    on May 01 2012 01:41 AM
    Prodigy60 points
    Following is my setting. Those values should meet the constrains required by Core Bluetooth. Did i make any mistake ?
    // Minimum connection interval (units of 1.25ms) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     200
    // Maximum connection interval (units of 1.25ms) if automatic parameter update request is enabled
    // Supervision timeout value (units of 10ms) if automatic parameter update request is enabled
    Report Abuse
    • Reply
  • tylerw
    Posted by tylerw
    on May 01 2012 12:44 PM
    Intellectual525 points
    https://developer.apple.com/hardwaredrivers/BluetoothDesignGuidelines.pdf
    See section "Connection Parameters" within Bluetooth Low Energy.
    -Tyler
    Report Abuse
    • Reply
  • Su mington
    on May 01 2012 21:42 PM
    Prodigy60 points
    I use PC software with USB dongle to connect to my device. It has the same situation. So it's not related with iPhone4S.
    Report Abuse
    • Reply
  • Karel Seeuwen
    Posted by Karel Seeuwen
    on Jul 18 2012 20:27 PM
    Intellectual280 points
    Just a comment regarding the CONNECTION PARAMETER UPDATE REQUEST as implemented in the peripheral.c file, and the iPhone4S.
    I had been trying for days to get my code working with
    but no matter what settings I used for MIN_INTERVAL, MAX_INTERVAL etc the iPhone4S would disconnect the connection.
    Next I downloaded and installed the packet sniffer software (should of done this ages ago) and noticed the iPhone4S was
    severing the connection with a LL_Terminate_Ind. I also noticed that the CONNECTION PARAMETER UPDATE REQUEST packet
    had IntervalMin and IntervalMax set to the same value, and this value corresponded to the
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     n     // n msecs
    value.
    In reference to https://developer.apple.com/hardwaredrivers/BluetoothDesignGuidelines.pdf where the maxInterval should be
    at least 20mSec greater than the minInterval it does surprise me that people have posted that using peripheral.c as is
    and setting DEFAULT_ENABLE_UPDATE_REQUEST to TRUE has in fact worked!?!
    How I got it working
    I made a modified copy of GAPRole_SendUpdateParam from this
    bStatus_t GAPRole_SendUpdateParam( uint16 connInterval, uint16 latency, uint16 connTimeout, uint8 handleFailure )
    to this
    bStatus_t BOGUS_GAPRole_SendUpdateParam( uint16 connIntervalMin, uint16 connIntervalMax, uint16 latency, uint16 connTimeout, uint8 handleFailure )
    set DEFAULT_ENABLE_UPDATE_REQUEST to FALSE and "manually" called BOGUS_GAPRole_SendUpdateParam with appropriate parameters
    e.g. BOGUS_GAPRole_SendUpdateParam(   30,   46 , 0x0000  , 500   , GAPROLE_NO_ACTION );
    and suddenly I started getting a positive response from the iPhone4S.
    Notes:
    1) where I say "manually", my project uses the UART on the CC2540 connected to a PC via a USB serial dongle and a level shifter.
    I send a command from the PC to the CC2540 to "manually" execute the BOGUS_GAPRole_SendUpdateParam command.
    I have yet to "reautomatify" (how's that for a new word) the code.
    2) the iPhone4S (ios5) does take its time to think about the CONNECTION PARAMETER UPDATE REQUEST. Presently it is
    about 5seconds. Maybe in the future they'll offer faster response times for higher paying customers or such like.
    D'oh!
    Just after posting this I came across this
    http://e2e.ti.com/support/low_power_rf/f/538/p/167385/717343.aspx
    which you should also read.
    Karel Seeuwen
    2540 2541 "CONNECTION PARAMETER UPDATE REQUEST" GAPRole_SendUpdateParam
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
