• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » CC2540_keyfob_SimpleBLEPeripheral.hex incorrect Value Handle
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
CodeNybbler57196
Posted by CodeNybbler57196
on Mar 02 2012 20:22 PM
Prodigy140 points
I have loaded \BLE-CC254x-1.2\Accessories\HexFiles\CC2540_keyfob_SimpleBLEPeripheral.hex into a V1.01 keyfob and \BLE-CC254x-1.2\Accessories\HexFiles\CC2540_USBdongle_HostTestRelease_All.hex into a rev 1.0 USB dongle. When I do the tutorial in swru270b.pdf section 4.3.1 Reading a Characteristic Value by UUID, the value read is 0x25 instead of 0x22. The other values are also 3 off. 4.3.4  Discovering a Characteristic by UUID returns 02 28 00 F2 FF.
What is going on?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Joakim Lindh
    Posted by Joakim Lindh
    on Mar 04 2012 02:09 AM
    Genius13370 points
    Handles are used for addressing local attributes and are enumerated during device initiation, when all services are registered. I would guess that a service may have gotten more attributes added in BLEv1.2, supposedly "Device Information". This would result that everything after those "new" attributes would be shifted in terms of handles. This is why it is importatnd to use the UUIDs and do Service Discovery OTA, so that you know the handles that corresponds to UUIDs.
    I will make sure that the documentation gets attention. Thanks for indicating the confusion.
    Br
    Report Abuse
    • Reply
  • CodeNybbler57196
    on Mar 04 2012 10:42 AM
    Prodigy140 points
    I also have a SmartRF05 & a CC2540EM. I loaded CC2540_SmartRF_SimpleBLEPeripheral.hex into the CC2540EM and tried the demo. The handles returned match the documentation in that case. The source for CC2540_SmartRF_SimpleBLEPeripheral.hex is included in BLEv1.2, but the source for cc2540_ble1.1_keyfob_SimpleBLEPeripheral.hex is not. Is that source available? It would be interesting to compare the two.
    Thanks for clearing up the confusion.
    Report Abuse
    • Reply
  • Adam Cohen
    Posted by Adam Cohen
    on Mar 05 2012 07:26 AM
    Prodigy250 points
    Nick L
    Br
    I've been confused by this as well. With version 1.1a of the BLE stack, we were able to issue a Discover Characteristic by UUID with the value f1:ff and we'd receive "0A 22 00 F1 FF", then it was possible to use Read Charactersitic UUID with f1:ff and we'd receive the value stored at handle 0x22, which we could then modify and write to.
    With stack version 1.2, if I use Discover Characteristic by UUID with value f1:ff, I get "0A 25 00 F1 FF"  CodeNybbler pointed out. This is fine, and I understand why the handle value may be different, but what I can't understand is why issuing Read Using Characteristic UUID with the value f1:ff gives me a failure response.  I'm also unable to use Read Characteristic Value/Descriptor with 0x0025, which is the correct handle, nor can I write to this handle, even though it's got 0x0A for the permissions (read/write capable).
    So to recap, why can we no longer read/write this characteristic handle with BLE stack version 1.2?  Thanks,
    Adam
    Report Abuse
    • Reply
  • kazola
    Posted by kazola
    on Mar 05 2012 16:18 PM
    Guru10665 points
    Hi Adam & Nick,
    I think Adam may be right. The other day, during a quick test, I realized I was not able to activate the "Link loss alert", which I think is the same one Adam is trying to activate. Am I wrong, Adam?
    If I do not remember wrong, because my keyfob is almost destroyed due to intense hardware tests, I suffered from the same issues, but I repeat, I tested in a quick way. Can anybody at TI test this?
    Please click the     Verify Answer     button on a post if it answers your question! :)
    Report Abuse
    • Reply
  • Joakim Lindh
    on Mar 06 2012 03:14 AM
    Genius13370 points
    Hi Adam,
    That is weird. I dont not see the issue you are experiencing. I have tried both flashing the keyfob from IAR using simpleBLEPeripheral project and also using CC2540_keyfob_SimpleBLEPeripheral.hex with Flash Programmer. As you see in the PrintScreen image below, I can successfully read and write.
    Please have another go, or correct me if I understood your problem in a wrong way.
    Br
    Report Abuse
    • Reply
  • Adam Cohen
    on Mar 06 2012 06:23 AM
    Prodigy250 points
    Hi Nick, thanks for your response, now that I know it's not expected behaviour, I managed to track down the problem.  Turns out I had flashed the keyfob to the 1.2 software, but the USB dongle was still using the software from the 1.1a stack.  So if anyone runs into the issue of receiving a failure response when attempting to use Read Using Characteristic UUID, or a failure when writing a Characteristic Value Handle, make sure you're using the same stack version on the USB dongle, keyfob and BTool.  Thanks again Nick, you've saved me a lot of confusion!!
    Adam
    Report Abuse
    • Reply
  • kazola
    Posted by kazola
    on Mar 06 2012 08:19 AM
    Guru10665 points
    Same thing here. Sorry.
    Report Abuse
    • Reply
  • Mr. White
    Posted by Mr. White
    on Mar 14 2012 11:44 AM
    Prodigy175 points
    Hi!
    I had the same problem. Can anyone explain why this is happening?
    If both versions (1.1 and 1.2) meet the BE specifications, why it's impossible to read characteristics by UUID or by right handle?
    Serg
    Report Abuse
    • Reply
  • Joakim Lindh
    on Mar 15 2012 03:37 AM
    Genius13370 points
    Hi Mr White,
    Handles has nothing to do with any specification, they are just internal addressing. For example, you use the UUID to discover the handles, that is a specification procedure.
    Consider following user case. You are going to visit a library to get a specific book, but since libraries not place their books in same manner (since libraries are not built the same) you would have to ask a librarian where the book can be found. You would get the internal address.
    I dont know if this made any sense to you but I hope so.
    Br
    Report Abuse
    • Reply
  • Mr. White
    Posted by Mr. White
    on Mar 15 2012 04:24 AM
    Prodigy175 points
    Hi Nick L
    1. I discover characteristic by UUID, as specification procedure, and got a right handle (rigth "internal address for this library"). Why it's unable to read characteristic by this right handle, as specification procedure?
    2. Let's forget about handles. Is this specified procedure to read characteristic by UUID? Why it's unable to read characteristic by UUID, as specification procedure, if I using different versions of stack in KeyFob and in USB Stick?
    Br
    Report Abuse
    • Reply
  • Joakim Lindh
    on Mar 15 2012 06:58 AM
    Genius13370 points
    Mr. White
    When you do the "discover characteristic by UUID" procedure, you will get a response with permission, UUID, and handle. As long as you have permission to write/read to that characteristic (Read permission bit is 0x01 and Write permission bit is 0x02), you shall be able to do it
    Mr. White
    That should not happen, which UUID are you trying to read? For example, you cannot read/write to "keyPressed" (UUID 0xFFE1) attribute in simpleKeys. For this you would write 01:00 to the handle + 1 to enable notifications, which would be how you obtain button pushes OTA.
    Br
    Report Abuse
    • Reply
  • Mr. White
    Posted by Mr. White
    on Mar 15 2012 07:14 AM
    Prodigy175 points
    Hi Nick L
    Are you tried to do so?
    Try to flash v1.1 to USB Stick and v1.2 to KeyFob and you'll be surprised.
    I told you again: it's impossible in this situation (v1.1 in USB Stick and v1.2 in KeyFob) to read characteristic (0xFFF1 for example) with read permission and right handle!!!
    And more, it's impossible to read characteristic by UUID (0xFFF1 for example)!!!
    Just try!!!
    Br
    Report Abuse
    • Reply
  • Joakim Lindh
    on Mar 15 2012 07:38 AM
    Genius13370 points
    Mr. White,
    I suppose you use the latest BTool as well (1.20c), I could replicate what you are experiencing. I did however tested with an older BTool (1.10a) as well, which worked fine. So maybe there is something in the newer BTool that has been updated so that it do not longer fully support older versions of HostTestRelease.
    I can only conclude that you should use the latest HostTestRelease build (v1.2) and the latest BTool (v1.20c).
    Br
    Report Abuse
    • Reply
  • Richard Dolf
    Posted by Richard Dolf
    on Mar 27 2012 17:08 PM
    Intellectual700 points
    Hi Nick,
    I also discovered the change in handle values from V1.1 to V1.2, having also taken the shortcut of using 'well known' handle values.
    FWIW, the change in handle values is not reflected in the CC2540/41 Bluetooth® Low Energy Software Developer’s Guide v1.2 (doc ID SWRU271B) which still has the values from v1.1 in the attribute tables on pages 36 and 37.
    Richard
    Report Abuse
    • Reply
  • rider
    Posted by rider
    on Apr 11 2012 07:47 AM
    Intellectual330 points
    Hello Nick,
    An additional typo which could be corrected in a newer version: the handle 0x20 is two times in the list.
    Is it possible to publish all versions of the table that one does not need to read out every value?
    rider
    cc2540 simplebleperipheral application complete attribute table
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
