• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » Supervisor timeout in shorter connection interval
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Asha Vijay
Posted by Asha Vijay
on Jul 17 2012 06:50 AM
Prodigy60 points
     I'm using CC2540 in our product, where it reads a huge data from the sensor interfaced to CC2540 and transmit the same over BLE to the host. I'm able to collect huge data (8 KB of data) and transmit 20 bytes of data at a time over BLE.With this I'm able to achieve transfer speed of 535 bytes/second.
My connection parameters are as below (Set from BTool)
   Connection Interval -> 8 to 80
   Supervision Timeout -> 3000.
With this, I'm able to transmit the complete 8 Kilo Bytes of data in 15 seconds. This is not an acceptable speed. I'm trying to reduce the time taken to transmit. I've modified the connection interval to 8 (instead of 80). With this, I'm data being transferred in 8 seconds. But soon after completing the transfer the connection is lost and end up in supervision timeout. Please let me know is there any way I can transfer with higher speed without losing the connection.
2540 2540 2541 external clock timer counter
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • senthil kumar69729
    Posted by senthil kumar69729
    on Jul 17 2012 08:23 AM
    Expert1075 points
    Hi Kazola /Karl,
    Even I am facing the same issue ,Kindly revert back ,
    Thanks in advance for your valuable reply
    Senthil
    NiceDay,
    Senthil
    Report Abuse
    • Reply
  • kazola
    Posted by kazola
    on Jul 17 2012 08:38 AM
    Guru10665 points
    Hi!
    I would try values around 10 at least.
    If not, I've experienced several issues with connection events.
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL 10
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL 10
    This should transfer your data in much less than 15 seconds. Do not stress the CC2540. If not, try higher values.
    Good luck.
    Please click the     Verify Answer     button on a post if it answers your question! :)
    Report Abuse
    • Reply
    on Jul 17 2012 08:53 AM
    Expert1075 points
    Thanks kazola for your very quick reply ,
    I had one more quesiton , i have read that transfer speed of BLE is 1 Mb/sec ,but practically we could able to achieve only ~4 Kb/sec.
    May i know under which circumstance that 1 Mb/sec (PHY layer data rate ) and 305Kb/sec (BLE data rate ) is calculated ?
    Please find the document(BLE_TechDay_2011.pdf)  in the link below ,
    http://e2e.ti.com/support/low_power_rf/m/videos__files/653594.aspx
    refer the page number Page number 19 and 55 ,where the data rate of BLE is mentioned .
    Thanks again
    Senthil
    NiceDay,
    Senthil
    Report Abuse
    • Reply
  • kazola
    Posted by kazola
    on Jul 17 2012 10:27 AM
    Guru10665 points
    Hey Senthil, thanks for the link :)
    In the TI BLE implementation, you are going to achieve 10kBps at most (kilobytes per second).
    The different with 1MBps is that this value is the raw theoretical capacity of the BLE PHY layer.
    Around 300kBps is the theoretical capacity of the BLE APP layer, and you will not reach this neither :) Perhaps with other chips, but not tiny embedded things as CC2540, by the moment.
    Please, close and verify the thread. New questions in new threads :)
    Good luck!
    Report Abuse
    • Reply
  • Asha Vijay
    on Jul 17 2012 23:52 PM
    Prodigy60 points
    Thanks Kazola for your reply.
    I've tried couple of these values and minimum I could achieve is 10 seconds.
    In my sendData function, I'm transmitting only 20 bytes. Could not transmit for 4 times in the same connection interval. And all the transmit failures are re-transmitted. I observed that If I've to transmit all the packets without fail, it takes atleast 10 seconds.
    Again, here are my settings:
    #define DEFAULT_ENABLE_UPDATE_REQUEST         FALSE
    #define DEFAULT_DESIRED_CONN_TIMEOUT          3000
    I'm calling sendData at every 10 ms period.
    The transfer speed is one issue, and another issue is supervision timeout. All the data transfer is successful most of the times. But soon after transfer, the link will be lost with supervision timeout. Is there any way to increase the connection interval once the data transfer is completed to keep the link alive?
    Report Abuse
    • Reply
  • kazola
    Posted by kazola
    on Jul 18 2012 01:50 AM
    Guru10665 points
    Let's hear the opinion of others on this.
    I'm able to achieve around 5kBps with BLE, sorry. Perhaps you are within a very crowded wireless environment?
    Please remember 10 is NOT 10ms but 10 x 1.25 = 12.5ms.
    Regarding the supervision timeout thing..... check the forum! Nick explained in this link the same issue you are facing :)
    http://e2e.ti.com/support/low_power_rf/f/538/p/142874/515743.aspx#515743
    Report Abuse
    • Reply
  • Willis1
    Posted by Willis1
    on Aug 03 2012 19:22 PM
    Expert8185 points
    Hi Vijay-
    A couple questions for you:
    Are you running this on your own hardware or on TI hardware (e.g. a CC2540 keyfob)?
    Could you show us a sniffer capture in which this timeout occurs?
    Are you using power management?
    Are you using a 32.768kHz crystal on your board? If so, what is the accuracy of the crystal?
    Failures like this are often due to clock drift, which causes the slave clock to become unstable and miss connection events from the master, though we see this less often in cases like yours with a short connection interval. This clock drift can occur if the board is laid out in a way in which there is noise on the 32.768kHz crystal input to the CC254x. Oftentimes sending a lot of data will make this issue worse.
    Report Abuse
    • Reply
  • Asha Vijay
    on Aug 06 2012 05:39 AM
    Prodigy60 points
    Hi Willis,
        Here are my answers to your question.
        *  I'm running the code on TI's CC2540 Keyfob, as well as our hardware. Both are having the same performance.
        * I'm attaching the sniffer capture, which has data capture of 8960 bytes twice. And after 2nd attempt timeout occurs. Please refer to the attached file largedataxfer.psd
          6153.largedataxfer.psd
        *  I've enabled POWER_SAVING macro in my project.
        * Yes, 32.768KHz crystal is used in our board.
      Additional point of my observation -
           I reduce the connection interval to 6 and run my sendData function every 7 ms instead of 20 ms, I'm seeing the data 0x2300 bytes (8960 bytes) is being transferred within 5 seconds. From the sniffer capture, I can see the data is transmitted completely without error. After that I see BTool is dumping the received packets for the next 2 minutes (too long to wait for next data transfer command). After completing the dumping of the packets, BTool throws Supervision Timeout Is this the BTool overhead of processing the data.  But, if I'm slower in data transmission by increasing the connection interval to 80 - 800 (Min - Max) and call the event to sendData once every 20ms, the chances of timeout is very less. Is there any way to increase the speed without connection loss. By referring to sniffer capture, please suggest something.
      Asha
    Report Abuse
    • Reply
  • tylerw
    Posted by tylerw
    on Aug 06 2012 19:22 PM
    Intellectual525 points
    Hi Asha,
    May I ask, what is your slave latency setting?
    I have seen a similar issue when using slave latency, I posted about it - http://e2e.ti.com/support/low_power_rf/f/538/t/196428.aspx
    -Tyler
    Report Abuse
    • Reply
  • Asha Vijay
    on Aug 06 2012 23:25 PM
    Prodigy60 points
        I've set the slave latency to 0. And BLE stack is 1.2.0
    Report Abuse
    • Reply
  • Willis1
    Posted by Willis1
    on Aug 07 2012 13:56 PM
    Expert8185 points
    Asha-
    A few comments/questions:
    1.I realized that you are still using the default connection interval of 100ms. After the connection is established with a 100ms interval, you are never sending the connection parameter update. To do this, you need to change the value of DEFAULT_ENABLE_UPDATE_REQUEST from FALSE to TRUE. This should improve your throughput significantly.
    2. I would strongly recommend that you move to v1.2.1 (the latest version available at www.ti.com/blestack). They API is 100% compatible with v1.2, and it fixes some minor bugs in the stack.
    3. As far as the supervision timeout goes, I can't really see anything wrong with what you are doing on the sniffer capture. One possibility could be that if there is any noise on the lines from the 32kHz crystal and the CC254x, it could cause clock drift which could then cause the supervision timeout. Does the timeout always occur at the same time, or is it somewhat random? Also, after you fix items 1 and 2 above please let us know if you see the issue still. Using a shorter connection interval would help reduce timeouts caused by clock drift, but would not fix the root problem.
    Report Abuse
    • Reply
  • Asha Vijay
    on Aug 09 2012 12:11 PM
    Prodigy60 points
    Willis,
    1. To get the sniffer capture of one complete 8K data and to show supervisor timeout occurs after completion of one or 2 packet transfer, I have set the DEFAULT_ENABLE_UPDATE_REQUEST to FALSE. This is taking 100ms connection interval.
    2. I've tried by setting DEFAULT_ENABLE_UPDATE_REQUEST to TRUE. But with the updated connection parameters, the transfer fails after 3-4 packets (of 20 bytes each). I'm not even successful with one complete transfer of 8KB of data. When the same macro is set to FALSE, I'm able to complete the data transfer without any error. I'm also trying to set update gaprole parameter just before transmitting large packet and restoring back to higher connection interval once the transfer is completed. But even after updating the connection interval, it fails to transmit more than 4 packets. I may have to finetune the connection interval, to make atleast one full 8KB transfer.
    3. Now I've moved to BLE stack v1.2.1
    4. Regarding supervision timeout, depending on connection interval - when set to larger values the occurrence of supervision timeout is less. Whereas, with connection interval 80 - 80, after 1st or 2nd transfer of 8KB, supervision timeout occurs.
    Report Abuse
    • Reply
  • tylerw
    Posted by tylerw
    on Aug 09 2012 12:19 PM
    Sorry to keep popping in on this thread, but I have also seen the issue from item (2).  Please see
    http://e2e.ti.com/support/low_power_rf/f/538/t/183876.aspx
    -Tyler
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
