• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » Switching power source between coin cell and debug header automatically?
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
rswl88
Posted by rswl88
on Aug 08 2012 04:55 AM
Intellectual375 points
I am running my CC2540 directly off a coin cell battery.
I've noticed that the CC debugger has a 3.3V pin that can be used to power my system.
Is there a simple circuit that I can use to enable the system to switch to the cc debugger power source automatically when the debug header is connected?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Joakim Lindh
    Posted by Joakim Lindh
    on Aug 08 2012 06:08 AM
    Genius13370 points
    If you are referring to the CC2540 Keyfob you can short circuit R1 placeholder with a 0ohm resistor (or just some lead or scrap metal). By that you'll be able to power the keyfob from the debugger.
    Best Regards.
    Report Abuse
    • Reply
  • rswl88
    Posted by rswl88
    on Aug 08 2012 07:49 AM
    What I am after is a way to do it automatically.  Is there any circuits that could be built to get around this?
    Currently, I am thinking of placing a diode at the 3V output from the coin cell, but I am afraid the voltage drop across the diode will be too high.
    Report Abuse
    • Reply
  • Igor Sherer
    Posted by Igor Sherer
    on Aug 08 2012 08:10 AM
    Guru21965 points
    You know, it's quite a challenge.
    May be this kind of question should be asked on the analogue forums, not the RF one.
    Don't forget that CC253x/4x are sleeping devices which means that they are switching
    power, drawn current can be from 25mAmps to several uAmps, so you should be careful
    when placing an active part. You shouldn't be afraid of voltage drop, since CC254x can
    operate from 2.1Volts. So as long as the supply voltage is around 2.7 volts and voltage
    drop on diode doesn't exceed 0.5 volts. I recommend you to use schottky bariers, typically
    they have very low drop voltage ~0.2V
    Br,
    Igor
    Report Abuse
    • Reply
  • Eng351
    Posted by Eng351
    on Aug 08 2012 13:35 PM
    Expert2980 points
    Schottkys are easiest but if you need full 3.0V from battery then you will need a NCH fet, NPN and schottky to switch the battery. Connect like this:
    1. Battery +ve to load +ve
    2. 3.3V debug to load +ve via Schottky 0.3V diode.
    2. NCH Drain to battery -ve
    2. NCH Source to GND
    3. NCH Gate connected with pull up resistor (4K7 etc) to battery +ve
    4. NPN transistor with collector connected to NCH gate, emitter to GND.
    5. Voltage divider from 3.3 debug to NPN base to give 0.6V when debug = 3.3V (this is important as you dont want the battery disabled before this voltage has reached 3.3V
    6. Large cap between circuit +ve and GND 10uF+
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
