• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Bluetooth® Applications » PAN1323EMK PAN1323 Evaluation Kit
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Pankil Butala
Posted by Pankil Butala
on Nov 09 2011 16:25 PM
Prodigy50 points
I want to evaluate the PAN1323 ETU module. I have the following questions:-
1. Does the PAN1323EMK contain two PAN1323ETU modules ?
2. The features specified at http://www.ti.com/tool/pan1323emk#Technical%20Documents mention the PAN1323ETU supports only the classical bluetooth. However the features on the Panasonic website http://www.panasonic.com/industrial/electronic-components/rf-modules/bluetooth/pan1323etu.aspx mention that PAN1323ETU supports Classical Bluetooth, BLE and ANT+ and comes with an antenna. I am confused which ETU module is provided with the PAN1323EMK ?
3. Is it possible to connect external I2C devices like accelerometer/gyroscope/color sensor with the PAN1323EMK to transmit that data over a channel to some central aggregator that supports BT/BLE/ANT ?
wireless low power rf
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Miguel
    Posted by Miguel
    on Nov 11 2011 10:51 AM
    Suggested Answer
    Genius11545 points
    Pankil,
    Please find my comments below.
    1. Yes, the PAN1323EMK contains two PAN1323TUs.
    2.  The PAN1323ETU is intended for EVALUATION purposes ONLY. Therefore, the user can use it with any of the following combinations for evaluation purposes only: BT, BT+ ANT or BT+BLE. Please note that for PRODUCTION purposes, the user has to select the proper module depending on the combination.
    All this information is kind of written in here: http://www.ti.com/tool/pan1323emk#descriptionArea
    "This kit is an upgraded version of the PAN1315EMK.  The PAN1323 ETUs will be used for evaluation of different software configurations as they become available.  Possible combinations are Bluetooth classis, Bluetooth + ANT+ (separate kit available), and in the future  Bluetooth + BLE.  The PAN1323 that comes with the kit is for evaluation only. For production use, please use the Panasonic PAN1315, PAN1325, PAN1317 or PAN1327 modules."
    3. Yes, but the interface would have to made to the MCU, e.g MSP430 or Stellaris.
    ~Miguel
    Report Abuse
    • Reply
  • Pankil Butala
    on Nov 11 2011 11:55 AM
    Prodigy50 points
    Miguel,
    Thank you for your reply. I need all three modalities (BT/BLE/ANT+) for my device development, evaluation and comparisons (well especially BLE and ANT). I already have a functional device with MSP430 and ANT and I want to compare it with BLE and BT. Thus, these three modalities may not necessarily be active at same time. I could potentially make use of three separate plug and play modules one at a time. However, the part that confuses me from the description is the following :-
    1. BT + ANT+ (separate kit available): Does that mean that I need to buy three separate kits, one for BT or BT+ANT or BT+BLE individually ? Or are they three different plug and  play modules available in one kit that I can swap to use a particular solution ?
    2. In the future BT + BLE: Is this available currently ?
    3. I understand I will have to purchase the MSP430F5438 Experimenter board in addition to the eval kit. I have purchased the MSP-FET430U64 which contains the 64pin target board and USB Programmer. Would I still need the experimenter board ?
    -Pankil
    Report Abuse
    • Reply
  • Miguel
    Posted by Miguel
    on Nov 11 2011 14:59 PM
    Verified Answer
    Verified by Pankil Butala
    Genius11545 points
    Pankil,
    The PAN1323EMK would be the best fit for your evaluation. It allows you to test the three technologies with the same hardware. Of course, you just need to update the software. Currently, TI does not have a BT+BLE stack in a standard offering but you can contact either StoneStreetOne or MindTree for a custom solution.
    You need the MSP430F5438 Experimenter board because it allows you to plug in the MSP430BT5190 chip. This chip is required to run the MindTree BT stack.
    ~Miguel
    Report Abuse
    • Reply
  • Pankil Butala
    on Nov 15 2011 17:56 PM
    Prodigy50 points
    Miguel,
    Thank you for the answer. If I understand you correctly, right now TI does not provide BT+BLE stack in any standard offering. I am a little reluctant to get the hardware from TI and then approach a third party for a custom solution. In this situation I think I could get just the CC2540DK for BLE development. Does TI have a standard BLE stack offering for this?
    To re-iterate a little, I have a ANT solution up and running. Right now, I want to test it against BLE and maybe BT in near future. Would you recommend some other solution that I might have overlooked ?
    -Pankil.
    Report Abuse
    • Reply
  • Miguel
    Posted by Miguel
    on Jan 20 2012 17:33 PM
    Suggested Answer
    Genius11545 points
    Pankil,
    The CC2540DK is a BLE single mode device. TI is looking to add a BT+BLE solution in the future.
    Miguel
    Report Abuse
    • Reply
  • Daniel A.
    Posted by Daniel A.
    on Aug 01 2012 09:38 AM
    Intellectual370 points
    I want to connect the PAN1323EMK to a Stellaris devkit (not the wireless kit). As far as I'm concerned, the microcontroller I have in mind can run the Bluetopia stack since it's got 96K of RAM and 512K of flash. However, I can't see any reference design to connect a microcontroller to the PAN1323 module.
    I'd like to use the HCI UART interface so, if I'm not wrong I need to provide power supply to the PAN1323, a 32KHz signal and a shutdown line. Also the UART should include flow control.
    Am I right?
    Is there anywhere I can look at to find out how to connect a microcontroller to this module?
    Thanks and Regards,
    Daniel
    Report Abuse
    • Reply
  • Zahid Haq
    Posted by Zahid Haq
    on Aug 02 2012 13:20 PM
    Expert5030 points
    Hi Daniel,
    Yes, you are right. You can find schematics of an MSP430 interface near the end of this document for reference:
    http://www.panasonic.com/industrial/includes/pdf/PAN1323ETUDesignGuide.pdf
    ZH
    Please click the Verify Answer button on this post if it answers your question.
    Please visit our CC256x Forum Guidelines and FAQs
    Check out our CC256x Bluetooth Main Wiki page: http://processors.wiki.ti.com/index.php/CC256x
    Report Abuse
    • Reply
  • Daniel A.
    Posted by Daniel A.
    on Aug 03 2012 06:33 AM
    Hi Zahidul,
    Many thanks for your answer.
    What I can't really see is how the 32KHz is generated. From the design reference it's connected to P2.7 which is supposed to be configured as ADC12CLK. Does it mean that the software in the MSP430 configures the ADC to work at 32KHz and this signal is output through that PIN which is connected to the PAN module through a level converter?
    So my external microcontroller must generate that square wave, right?
    Daniel
    Report Abuse
    • Reply
  • Daniel A.
    Posted by Daniel A.
    on Aug 03 2012 06:44 AM
    Hi again,
    Sorry I was wrong and it's connected to P2.6/ACLK pin of the MSP430. Okay, it outputs the auxiliary clock sourced from the 32KHz external crystal divided by 1.
    If my microcontroller does not have such feature or I can't generate the square wave with that accuracy I guess that an external circuit should be used.
    Daniel
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
