• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Bluetooth® Applications » MSP430BT5190 + PAN1323 - Works with XT1CLK and not REFOCLK?
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
PhenomX
Posted by PhenomX
on Apr 07 2012 13:14 PM
Prodigy230 points
I have designed my own custom board to interface with the PAN1323ETU, however, I did not add an external crystal oscillator to source the ACLK. I was not careful enough and I did not realized that the EtherMind SDK sample uses the external crystal. I thought an easy solution would be to change the clock initialization and use REFOCLK instead to feed the ACLK pin. REFOCLK runs at the same frequency as the crystal oscillator and I checked this by directly checking pin 11.0 on the development board.
When I use the REFOCLK as the ACLK source, the Bluetooth fails to turn on and hangs in the following line inside the BT_UART_ISR:
#pragma vector=BT_UART_VECTOR
__interrupt void BT_UART_ISR(void)
      UART_TRANSMIT(buff_data);
Basically it waits for the CTS (P1.3) to go low but it never does. As soon as I change the ACLK source to the external crystal everything works. I was able to replicate this problem which I saw in my custom board in the development board. Additionally, this topic also claims to have tried to use a PWM to drive the Bluetooth slow clock unsuccessfully http://e2e.ti.com/support/low_power_rf/f/660/t/125986.aspx. He implies to have use an oscillator to drive the clock (most likely an external crystal). I don't understand why it works with one and not the other. I understand the accuracy of the crystal to be much better, but is that really the cause of the problem?
EDIT: I have found on the PAN1323ETU design guide the following about the requirements of the slow clock:
The slow clock's frequency accuracy must be 32.768 kHz +/- 250 ppm for Bluetooth
usage (according to the Bluetooth specification).
I cannot find the ppm spec for the REFOCLK to compare to the previous statement. I have also tried using an external function generator to generate a clock at the same frequency with no success. Could the code be hard coded to only work with XT1CLK?
Thanks in advance,
-Adrian
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Miguel
    Posted by Miguel
    on Apr 09 2012 22:48 PM
    Verified Answer
    Verified by PhenomX
    Genius11565 points
    Adrian,
    If MSP430_CTS is not going low during initialization, it indicates that the PAN13xx is not powering up correctly. Given your feedback, I think that your clock is not meeting the specs. Please note that the PAN13xx checks the slow clock accuracy during initialization in order to power up. The source does not have to be ACLK. It could be an external clock as long as it meets the requirements.
    Miguel
    slow clock power up
    Report Abuse
    • Reply
  • PhenomX
    Posted by PhenomX
    on Apr 10 2012 23:42 PM
    Prodigy230 points
    Miguel,
    Thank you for your response. Yes, apparently the internal 32.768kHz clock does not meet the specs. As soon as I used an external crystal it all worked.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
