hello
i just wanted to program 8051 present in CC2540 . i know that it can be done with cc debugger but is there an alternate option?
thanks
hello
thanks
There are likely other compilers which will work. We only support IAR, and if you use our BLE libraries, then you will need to use IAR. If your question is on CC debugger HW, the programming pins and functions are described in CC Debugger guide, so you would be able to flash for example from another device.
BR,
-Greg
