• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » RFID/NFC Forum » [NFC] How to connect TRF7970A NFC device to any of the OMAP development platforms (like Beagleboard, OMAP3XX EVM, OMAP4 Panda board etc)?
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Sreenath Sharma
Posted by Sreenath Sharma
on Aug 09 2011 06:21 AM
Prodigy20 points
Does anybody know how to connect TRF7970A NFC device or any other NFC controller  to any of the OMAP development platforms (like Beagleboard, OMAP3XX EVM, OMAP4 Panda board etc)?
The main requirement is to study in detail about the porting of non NXP NFC controller hardware on Android and NFC HCI interface. I am only interested in evaluation modules which have connectivity over serial bus protocols like SPI/UART/I2C etc and this requirement rules out TRF7970A Evaluation Module (EVM), which provides connectivity over USB.
Please comment on the below queries.
1. Availability of add on card/module based on TRF7970A NFC controller that can be connected to any of the available OMAP platforms over serial protocol bus like SPI/UART/I2C.
2. Is it possible to glue wire and take out SPI connection between the TRF7970A NFC controller and MSP430F2370 micro controller, so that TRF7970A can be connected to any OMAP evaluation boards.
Sreenath
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Josh Wyatt
    Posted by Josh Wyatt
    on Aug 09 2011 07:29 AM
    Expert7985 points
    Sreenath -
    yes - if you have a look at the attached schematic, on the TRF7970A EVM, just like the TRF7960EVM, you can use header 5 to wire in your microprocessor for SPI or Parallel. Header 1 and Header 3 have the data clock and IRQ pins you also need to access and you would also need to wire in to the top of R24 for the EN line. Boards have been shipped to the eStore and should show up in stock in a few days at the latest. so you can go ahead and order.
    https://estore.ti.com/TRF7970AEVM-TRF7970A-Evaluation-Module-P2586.aspx
    1803.TRF797x_EVM_Rev A1_Schematic.pdf
    BR-
    Josh
    Please click the Verify Answer
    button on this post if it answers your question.
    Report Abuse
    • Reply
  • Sreenath Sharma
    on Aug 11 2011 00:04 AM
    Prodigy20 points
    Thanks a lot for the information.
     - What is the voltage level of the SPI interface between TRF7970 and MSP430F2370? Is it 1.8V or 3.3V?
    - Is there any Linux driver available for TRF7970? If yes what are the physical buses it supports (like, SPI, UART, I2C etc.)?
    Report Abuse
    • Reply
  • Josh Wyatt
    on Aug 11 2011 07:11 AM
    Expert7985 points
    Sreenath -
    the voltage level on the I/O can be from 1.8 to 5V. Common use case for example is 3.3VDC and can be taken care of by connecting VDD_X (output) to VDD_I/O (input), and the output of VDD_X is programmable via Register 0x0B, and as VDD_I/O can be connected to external voltage level between 1.8 to 5VDC, this is also another way to handle the I/O voltage level setting. (this is identical to the way the TRF7960 and -60A are)
    We have a team internal to TI who has developed the Linux driver using SPI interface. As they have just completed it, it is not quite ready for distribution, but we will make that available when it is ready.
    BR-
    Josh
    Report Abuse
    • Reply
  • Chris Westervelt
    Posted by Chris Westervelt
    on Aug 24 2011 11:07 AM
    Intellectual430 points
    Josh,
    Is there any way I can get a preliminary version of the driver for Linux.  I am trying to finish up hardware configuration requirements  using 7960 in Android Froyo.
    Report Abuse
    • Reply
  • Patrick Gerber
    Posted by Patrick Gerber
    on Oct 11 2011 01:37 AM
    Prodigy10 points
    Hello  Josh,
    Do you have some news from this driver ?
    I am interested to use this chip with an OMAP based board. This board will of course run Linux and I will be really happy to have your driver.
    Thanks in advance
    Patrick
    Report Abuse
    • Reply
  • Poh Leong Ng
    Posted by Poh Leong Ng
    on Oct 31 2011 05:28 AM
    Intellectual755 points
    Hi Josh,
    Do we have a rough date that the driver will be ready? Besides Linux, will TI be releasing drivers that support WinCE6/7 and Android?
    Poh Leong
    Report Abuse
    • Reply
  • Josh Wyatt
    on Nov 09 2011 08:20 AM
    Expert7985 points
    Poh -
    The code should be available shortly for the new AM3715 flashboard. it is being finished right now and they are very close to being done. i will try to come back to you on this shortly with a link to that.
    BR-
    Josh
    Report Abuse
    • Reply
  • kevin Guo12526
    Posted by kevin Guo12526
    on Nov 10 2011 17:08 PM
    Intellectual450 points
    Josh Wyatt
    Poh -
    Hi Josh:
    Does the code work for TRF7960 as well?
    Kevin
    Report Abuse
    • Reply
  • Paul Thomas
    Posted by Paul Thomas
    on Oct 16 2012 18:20 PM
    Prodigy110 points
    Any news on the TRF7970A Linux kernel driver? Looking in the mainline there is a driver for the NXP PN533 & PN544 under the NFC subsystem.
    thanks,
    Paul
    Report Abuse
    • Reply
  • Robert Mitschke
    Posted by Robert Mitschke
    on Jan 05 2013 06:55 AM
    Prodigy20 points
    I would also be very interested in getting access to such a driver. We are currently evaluating whether to use the TI or the NXP Chip and the only reason keeping us from going with TI at the moment is the lack of such a driver.
    I looked at the flashboard website but the currently release still says it does not support NFC yet.
    Even if the driver is not finished, I would be willing to use anything that is available as a starting point and provide improvements that we might make.
    I would very much appreciate a response with more information on the availability of such a driver.
    Thanks!
    Report Abuse
    • Reply
  • Tim Simerly
    Posted by Tim Simerly
    on Jan 07 2013 10:59 AM
    Intellectual2315 points
    Robert:
    Attached is a Linux driver for a TRF7070A device that used SPI to communicate with the ARM on the AM335x EVM.  This was used for a previous demo and is not productized code, but you can use for reference wrt using SPI for a different EVM with an ARM on-board.
    Tim
    5775.nfc_demo_am335x.tar.gz
    Report Abuse
    • Reply
  • Robert Mitschke
    on Jan 08 2013 04:15 AM
    Prodigy20 points
    Hi Tim,
    sounds awesome. Unfortunately when I download the file it is corrupt. I tried downloading on different machines with different unpacking tools. None could read it.
    Can you upload it again or send it to me via email? Thank you!
    Robert
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
