• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » RFID/NFC Forum » TRF7970 Too many errors in datasheet
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Rolf Molitor98973
Posted by Rolf Molitor98973
on Mar 05 2012 05:46 AM
Prodigy90 points
The actual datasheet for TRF7970 is full of errors ( SLOS743 - AUGUST 2011). It seems to be a copy of the datasheet for TRF7960, slightly modified with the new features / functions of the TRF7970.  In particular the length of the FIFO is mixed several times between 12 bytes and 128 bytes. The description of Register 0x1C (FIFO status) on page 74 must be wrong because it says that there are just 4 bits as FIFO counter.
Is there any clarification on the FIFO matter available. Is there an updated datasheet available ?
Btw the position of C7 in the application schematics on pages 13 and 14 is wrong (...what is a little bit embarrasing)
Thank you...
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Axxe
    Posted by Axxe
    on Mar 05 2012 05:57 AM
    Intellectual645 points
    i've noticed it too, and i've already asked for some explanations about the FIFO status register here -> http://e2e.ti.com/support/low_power_rf/f/667/t/168173.aspx but I still didn't get any answer.
    Report Abuse
    • Reply
  • Josh Wyatt
    Posted by Josh Wyatt
    on Mar 05 2012 07:52 AM
    Expert8045 points
    0268.TRF7970A_SPI_MSP430F23x0_schematic.pdf
    7558.TRF7970A_Parallel_MSP430F23x0_schematic.pdf
    Updated schematics attached - DS update is on the way - no kidding this time. :) Should be updated on the web this week.
    Sorry it has taken this long - BTW - in the DS - there are multiple links (like on almost every page) to submit document feedback - this is the correct mechanism for when you find errors in our docs.
    RE: the FIFO status register - i thought i had answered this before.
    The answer is that B7 of this register is the overflow indicator and B6: B0 now indicate # of bytes in the register to read (value is n, not n-1, like what is seen in the TRF796x devices.)
    BR-
    Josh
    Please click the Verify Answer
    button on this post if it answers your question.
    Report Abuse
    • Reply
  • Rolf Molitor98973
    on Mar 05 2012 08:27 AM
    Prodigy90 points
    Thank you Josh,
    looking forward to the updated DS.
    I never really noticed the "Submit Document Feedback" on the bottom of each page as a way to submit errors. I will use it in the future.
    Rolf
    Report Abuse
    • Reply
  • Josh Wyatt
    on Mar 06 2012 09:06 AM
    Expert8045 points
    as promised - the updated version of the DS is up on the web now in the TRF7970A product folder.
    http://www.ti.com/lit/ds/symlink/trf7970a.pdf
    BR-
    Josh
    Report Abuse
    • Reply
  • Rolf Molitor98973
    on Mar 06 2012 10:35 AM
    Prodigy90 points
    Thank you Josh,
    the new one is much better !
    Although your link still points to the old datasheet.
    I got the updated one under the following link from the TFR7970A folder:
    http://www.ti.com/lit/ds/slos743a/slos743a.pdf
    There are still some minor errors.
    This time i used the 'Submit Document Feedback' at the bottom of each page of the new DS to tell you, what I did notice.
    The new DS still says, that B3 of register 0x00 has to be "1" to select the Main RX input. That isn't right, is it ?
    Rolf
    Report Abuse
    • Reply
  • John Crusoe
    Posted by John Crusoe
    on Apr 07 2012 16:00 PM
    Prodigy120 points
    Josh Wyatt
    Are you sure?
    The default value for register 0x01 is not 0x02 (ISO15693 high bit rate, one subcarrier, 1 out of 4) but 0x21 NFC Mode 106 kbps.
    In another thread I written the copy and paste for bit 5/6 in register 0x1A.
    I'm a newbie and I never found error in datasheets, for this datasheet is too easy find errors.
    Report Abuse
    • Reply
  • Josh Wyatt
    on Apr 07 2012 20:13 PM
    Expert8045 points
    john -
    this time its your mistake. The default for register 0x01 is 0x02.
    BR-
    Josh
    Report Abuse
    • Reply
  • John Crusoe
    on Apr 11 2012 12:04 PM
    Prodigy120 points
    After command 0x03 (0x83 with SPI)
    read register 0x01(0x41 with SPI) return 0x21.
    I test many times before write it, and now I retest another one, always 0x21.
    My TRF7970A is not a clone chinese, I hope.
    In my board EN2 is attached to GND and EN became VCC, one second after power up.
    Can you explain me?
    Thank you
    John.
    Report Abuse
    • Reply
  • Josh Wyatt
    on Apr 17 2012 11:34 AM
    Expert8045 points
    John -
    the sequence for the TRF7970A should be: bring up the EN line, 0x83 (soft init), write the 0x09 register with B7=0 (if using 13.56MHz crystal), then you can read the registers - please try this out for me.
    BR-
    Josh
    Report Abuse
    • Reply
  • John Crusoe
    on Apr 19 2012 02:55 AM
    Prodigy120 points
    Josh
    This is my sequence:
    • Power UP
    • wait some seconds, I need to sent command in UART for testing.
    • bring up the EN line
    • delay 5 ms
    • 0x83 soft init
    • delay 5 ms
    • write 0b00010001 (0x11) in register 0x09. I have 13.56MHz crystal and only B7 is changed.
    • delay 5 ms
    • read register 0x01 always 0x21
    All other registers is read correctly, only register 0x01 hasn't default value. My TRF7970A is sample from TI, can't be a clone chinese. My TRF7970A works very well with my tests ISO14443A/B and ISO15963. It's not broken.
    I hope someone do the same test and report it.
    John
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
