• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » SimpleLink™ Wi-Fi® » WARNING of Running CC3000 FRAM Sensor GUI
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
YOO JIN
Posted by YOO JIN
on Mar 19 2012 08:11 AM
Prodigy110 points
Dear. TI
http://processors.wiki.ti.com/index.php/CC3000_Wi-Fi_MSP430_FRAM_Getting_Started_Guide
I successfully follow Step 5.
But, there is some mismatch  in Step 6 and Step 7.
I can see "COM5 => Configuration Successful"
But, LED5 and LED6 are off. GUI on PC show 0 Node Connected.
And I can see as below message
WARNING:  RXTX Verion mismatch
          Jar version = RXTX-2.2pre1
          native lib Versioin = RXTX-2.2pre2
I test ping from PC to FRAM board. Ping is successful. I believe that netwrok connection is ok between PC and FRAM board.
Sensor App Version is v1.0.7
Would you check GUI side? Unfortunately, I am not a JAVA user.
cc3000 CC3000 fast connection FRAM cc3000 first time config CC3000 Wi-Fi MSP430 FRAM Getting Started Guide
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Gustavo L
    Posted by Gustavo L
    on Mar 19 2012 08:35 AM
    Verified Answer
    Verified by YOO JIN
    Genius9990 points
    Hello Yoo,
    Everything seems OK as far as the setup from what I read.
    What language does your ping respond in? If it does not respond in English and say "Received = 1", then the GUI
    will not find the device properly. This is a known issue that will be corrected. You may try to change the language temporarily to English
    by going to Control Panel -> Region and Language, changing the formats to "English".
    Gustavo
    Please click the Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • YOO JIN
    Posted by YOO JIN
    on Mar 20 2012 02:30 AM
    Prodigy110 points
    Dear. Gustavo
    After changing language into English, I can see successfully working GUI.
    Thank you for your answer.
    YOO
    Report Abuse
    • Reply
  • Gustavo L
    Posted by Gustavo L
    on Mar 20 2012 08:47 AM
    Genius9990 points
    Yoo,
    I am happy you were able to get it running. We will resolve the issue in our next release.
    Gustavo
    Report Abuse
    • Reply
  • Lucio Macellari
    Posted by Lucio Macellari
    on Apr 10 2012 11:38 AM
    Prodigy30 points
    Gustavo,
    I have the same problem.
    On my kit, only the first 4 leds are ON.
    Could ypu please explain better what I have to change on Control Panel?
    I changed the numeric/datetime format but the kit still don't work.
    Lucio
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 11:10 AM
    Intellectual590 points
    Lucio,
    Sorry I missed your post.
    You need to change the language of the computer from Italian to English, at least temporarily.
    TO do this go to Control Panel -> Region and Language  and change the Format to English (United States).
    Gustavo
    Report Abuse
    • Reply
  • Lucio Macellari
    on Apr 12 2012 05:40 AM
    Prodigy30 points
    Gustavo,
    changing the SO language to english solves the problem.
    Now the demo works.
    It is strange, because on the v1.0.7 release notes the language problem seems to be fixed.
    Lucio
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 12 2012 08:41 AM
    Lucio,
    The issue in the release notes occured in UNICODE OSes such as Japanese and Chinese. The bug in that case was in the code where it was incorrectly translating raw bytes into characters.
    The issue you see is in the ping wrapper and is due to the fact that your ping is in a language other than english. Therefore, even though the ping actually works and finds the CC3000, the ping wrapper fails to correctly interpret it since it depends on an english phrase.
    Gustavo
    Report Abuse
    • Reply
  • Eddy Gigon
    Posted by Eddy Gigon
    on Apr 17 2012 08:11 AM
    Prodigy30 points
    Gustavo,
    I have the same problem, but I can not change the language. If I change the language in the control pannel as you mentionned, this does not change the command language and it still does not work. To Change the OS language is an option I do not have (only with premium edition if you have french or german...) Where can I change the english phrase you are speaking about ?
    Eddy
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 17 2012 09:59 AM
    Eddy,
    Line 2048 of FRAMSensorAppGUI.pde is the one that checks. Instead of checking for "Received = ", you should do:
    if(inputLine.indexOf("100%") == -1)
    This way, we make sure 100% doesn't show up which would indicate 100% loss of packets.
    Gustavo
    Report Abuse
    • Reply
  • Eddy Gigon
    on Apr 19 2012 01:23 AM
    Prodigy30 points
    I've tried to modify the java file instead of the PDE, I already did it before and have replaced Received = with the french reçu =  But this does not work. (I'm not familiar with the ccs programming tool and the CSS programm installation did not run properly on my computer, and now I'm unable to the uninstall this SW).
    I will wait on another version for evaluation if any.
    Thank you for your support
    Eddy
    Report Abuse
    • Reply
  • Pedro5084
    Posted by Pedro5084
    on Apr 19 2012 22:29 PM
    Intellectual2390 points
    Hi Eddy,
    Did you also compiled the java code and generated the executalbe jar file. Or did you try running the .pde file with processing software (
    http://processing.googlecode.com/files/processing-1.5.1-windows.zip) and another request, could you paste a successful and a failing ping requests.
    Report Abuse
    • Reply
  • Eddy Gigon
    on Apr 20 2012 12:00 PM
    Prodigy30 points
    Hi Pedro
    I tried by using the processing SW you mentionned and it's now OK thank you very much for you support.
    Eddy
    Report Abuse
    • Reply
  • Yan Jia-hong
    Posted by Yan Jia-hong
    on Aug 22 2012 02:35 AM
    Intellectual600 points
    CC3000 fast connection CC3000 RTOS CC3000 Sensor_App CC3000 event handler Accept TCP CC3000 event handler netapp_ipconfig bug CC3000 bug CC3000 HostDriver CC3000 bug CC3000HostDriver TCP connect()
    Report Abuse
    • Reply
  • Yan Jia-hong
    on Aug 22 2012 02:43 AM
    I can run CC3000 FRAM Sensor GUI tool ,but it is error to here .  CAN you help me??  AP link to CC3000+FRAM   is OK,now
    CC3000 fast connection CC3000 UDP send data CC3000 RTOS CC3000 event handler Accept TCP
    Report Abuse
    • Reply
  • Yan Jia-hong
    on Aug 22 2012 02:47 AM
    > assoc TP-LINK_2CEAFA
    OK
    Restarting MSP430...ÿ
    -------Press ENTER for terminal prompt--------
    Sensor App Version: v1.0.10
    WLAN Enabled
    Attempting to connect using SSID: TP-LINK_2CEAFA
    Connected to AP: TP-L
    CC3000 MAC Address: 0:0:ca:2:c:1f
    CC3000 IP Address: 192.168.1.100
    Starting Server...
    Server Initialized on port 1204
    Waiting for Clients
    CC3000 fast connection CC3000 RTOS CC3000 Sensor_App CC3000 event handler Accept TCP CC3000 event handler netapp_ipconfig bug CC3000 HostDriver
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
