• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » SimpleLink™ Wi-Fi® » CC3000 Demo assistance
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Jason Kriek
Posted by Jason Kriek
on Apr 05 2012 19:21 PM
Expert3320 points
Customer of mine is trying to get the sensor app up and running, can you please offer some assistance here:
I am working with MSP-EXP430FR5739 board and CC3000 WiFi module model TiWi-SL. I am trying to get the Sensor Demo app to work. The problem I am hitting is when the PC (the GUI app) initiates connection, connection never gets established. Network analyzer shows the packets are sent and received back and forth correctly for a short while, but after 2-3 successful SYN packets there is SYN packet sent from the PC to the device, that never gets any response, like it's never received by the device. The behavior does not seem to be always the same, sometimes I think I see data packet (with payload 'DATA' in ASCII) but no response. Sometimes there is a short (<1s) visualization of the blue "moon" in the GUI but it quickly disappears.
DHCP works always, and I can always send data out over UDP in my test app, and sometimes (randomly) I can even establish an outgoing TCP connection, but as soon as I start sending over TCP the MCU starts behaving erratically and I cannot step over machine instructions in the debugger.
Jason
Please click the Verify Answer button on this post if it answers your question.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • GustavoL
    Posted by GustavoL
    on Apr 05 2012 19:32 PM
    Intellectual590 points
    Hi Jason,
    Your problem is a bit strange given that the GUI does in fact send the "DATA" string. This means that the TCP connection has established.
    For some reason, the board isn't sending the data or something is happening to the data in the air or otherwise
    There are a few possible issues where this can happen:
    1) There were a few known issues of this with older software versions and in some specific languages where the data is not correctly translated. Can you describe the customer's setup and the version of the sensor app they're using?
    2) I have seen an issue when this can happen in congested networks when mixed mode b,g,n is enabled. If you have control of the router, please change the settings
    so that the router only uses a mixed mode of b,g (i.e. don't use 802.11n and see how that works).
    3) Congestion in general can cause packets to be dropped. After a certain amount of time passes, the GUI assumes that the node has disconnected and will "drop" it. Is this a congested environment?
    Gustavo
    Report Abuse
    • Reply
  • Jason Kriek
    on Apr 09 2012 13:05 PM
    Expert3320 points
    Thanks Gustavo,
    I received some more info form the customer:
    <quote>
    I just narrowed down our problem a little:
    - First Time Config problem with TPLINK router shows when I try to push the button on the router or run Quick Setup from the router. However if use the Android/iPhone application everything magically works. In our designed system we won't have a cell phone to initiate the connection, so we need to understand what is that 'magic' that the Android app is doing and be able to do the same from the router itself.
    - the TCP problem was also to do with the router setup. If I establish connection to the router using wlan_connect API, I run into the TCP issues. However if I do First Time Config and then establish connection through existing profiles, TCP works fine. Same as above, we are going to need some clarification there so to be sure that we can run this with various routers setups.
    </quote>
    Thoughts?
    Jason
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 09 2012 22:20 PM
    Jason,
    1) The customer is incorrectly using First Time Config. The button the customer is pushing is the WPS button that is not at all related to First Time Config. WPS is not universally supported whereas First Time Config is, and the CC3000 does not support WPS.
    In First Time Config there is not magic. The CC3000, when placed in first time config mode (in the sensor app this is done via a button), will scan the air looking for a specially crafted Probe Request or Beacon. These packets are normally crafted when a user uses a device to connect to a network. In the case of First Time Config, the name of the network is crafted as such that it conveys information about which network actually they should connect to. More information on this is available here:
    http://processors.wiki.ti.com/index.php/CC3000_First_Time_Configuration
    The AP itself is not involved at all with First Time Config. The customer/user does not need to do anything to it. The interaction is solely between the CC3000 and another device that can transmit the information using a WiFi interface.
    2) I am not sure about the second problem since I believe the customer is incorrectly using what he believes is "First Time Config".
    The Laptop/Computer needs to be associated to the AP. Whether that is using WPS or the passphrase, that is up to the customer.
    The CC3000 needs to also be associated to that same AP. If it is the TP-LINK AP provided in the kit, this can all be done automatically using the USB once, or done with first time config. Another option is with wlan_connect. It is possible that the customer is calling the API incorrectly. Please provide a code snippet to see how the function is being called.
    Note that the best approach for this is to modify the demo_config.h file fields and not the code itself.
    Gustavo
    Report Abuse
    • Reply
  • Jason Kriek
    on Apr 11 2012 10:02 AM
    Expert3320 points
    Thanks Gustavo,
    Customer response:
    Here is more information on the connectivity issues.
    The first problem is adding a profile through the API , instead of using First Time Config. I wonder if I've set the password field correctly:
     char tplink[] = "TP-LINK";
    unsigned char password[]  = "sifra123";
     err = wlan_ioctl_set_connection_policy(DISABLE, DISABLE, DISABLE);
        err =  wlan_add_profile(WLAN_SEC_WPA, tplink,
                                 7, NULL,
                                     0,
                                     0,
                                     0,
                                     0,
                                     password,
                                     8);
    // after thisi restart CC3000, all the steps just like with First Time Config,
     The second problem is TCP issue when using wlan_connect. Itseems to be due to using Huawei HG520c router instead of the TP-Link router. The WiFi connection was OK with both routers, but TCP connection failed with the Huawei router - exactly the same code.
     Overall I am mostly concerned aboutWPS as that seems to be the easiest way of connecting and does not require the user to connect any additional devices to do the setup.
    Thanks for the help.
     -Jason
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 10:50 AM
    Jason,
    After adding the profile, the customer should re-enable the use of profiles using the set_connection_policy API:
    wlan_ioctl_set_connection_policy(DISABLE, DISABLE, ENABLE);
    When using the Huawei router, how does he know the TCP connection is failing? Can he ping the CC3000 module?
    How is the AP configured? DId he try to disable mixed mode bgn and just have bg enabled?
    Gustavo
    Report Abuse
    • Reply
  • Jason Kriek
    on Apr 11 2012 12:46 PM
    Expert3320 points
    Response Below:
    Stored profiles:
    Yes I already set connection policy that way, every time I reset CC3000 and want to connect to a stored profile. Similar as with first time config.
     Huawei router:
     TCP connection is failing because HCI wait for event times out after 60 seconds and connect() returns error. I can't remember if ping worked on Huawei, but UDP send from the device worked, but there were problems receiving UDP (HCI waiting for event times out).
    I am not sure how to describe the config on the router because there are many options, but I have 10 other devices working fine with it. I haven't tried bg mode because I didn't want to add additional constraints on which routers this will work on. We can try this later if needed to debug this.
    Thanks Gustavo.
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 13:02 PM
    Jason,
    Does the customer have a WiFi sniffer? The only way now to see what is going on is to use such sniffer to see whether the CC3000 sends the SYN packet when it wants to connect.
    Even if the customer has no WiFi sniffer, using WIreshark can reveal whether such SYN packet has arrived at the computer.
    By the way, did customer rewrite the software? The sensor application does not use connect. If the customer isn't using the sensor application, he should at least try to see if it works with the other router. If it does, then the issue is with the customer's code. However, given that the TP-LINK AP works, I can only assume that there might be a firewall preventing the port that the CC3000 is using from communicating. Customer should disable any firewall and security to see if that works.
    Gustavo
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 13:08 PM
    Jason,
    I forgot to mention. Another thing the customer should do is use iperf, or its java equivalent jperf, between two computers connected to the Huawei router and see if that works.
    http://sourceforge.net/projects/iperf/files/jperf/jperf%202.0.0/jperf-2.0.0.zip/download
    Just run the jperf bat file and the GUI will load. Make sure customer tries the exact same port as the application is using in the connection.
    If this fails to work, then the router is likely filtering packets on the port.
    Gustavo
    Report Abuse
    • Reply
  • Nikola Bulatovic103326
    Posted by Nikola Bulatovic103326
    on Apr 11 2012 13:32 PM
    Prodigy120 points
    Hi Gustavo,
    Thanks for your replies. I will get back to you about the Huawei router.
    But for now, can you please give me an advice what am I doing wrong with the wlan_add_profile call? That seem like the most basic thing that should work with TPLink router, since First Time Config can work with it. Did I miss any parameters or any special NVRAM setup?
    Nikola
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 13:40 PM
    Nikola,
    From the posts I don't understand what is the exact issue. Are you unable to connect to the AP when you add a profile?
    What code are you executing (a code snippet would be helpful)? Are you deleting other profiles (in some of the reference code, 3 profiles are deleted).
    Gustavo
    Report Abuse
    • Reply
    on Apr 11 2012 13:53 PM
    Prodigy120 points
    Gustavo,
    The issue with saving the profile is that when CC3000 restarts it cannot connect to any of the stored profiles. However if I use first time config instead of wlan_add_profile, then it is saved correctly. So the issue seems to be in the way I am using wlan_add_profile API. A snipped of the code is above in this thread.
    Note that this is a separate issue from the Huawei router issue.
    Nikola
    Report Abuse
    • Reply
    on Apr 11 2012 13:57 PM
    Prodigy120 points
    Yes, I have used wlan_del_profile several times to make sure the first-time-configured ones are all erased for this test (that part is not visible in the code snipped above because it's in a different function).
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 14:03 PM
    Nikola,
    From your description it seems that the connect using profiles flag policy is not set, so the CC3000 on startup doesn't use the profile. On the other hand, the First time config function or functionality does set the policy correctly, which is why first time config continues connecting.
    I suggest you use similar calls to the set policy functions as that one used in first time config function.
    Gustavo
    Report Abuse
    • Reply
    on Apr 11 2012 14:10 PM
    Prodigy120 points
    Gustavo,
    I do always set the policy to use profiles, just like the sample in Basic WiFi Sample. Here is my restart function, which I call after setting the profile:
    void wlan_restart()
    P3OUT &= ~BIT7;
    ulCC3000Connected = 0;
    ulCC3000DHCP = 0;
    wlan_stop();
    __delay_cycles(6000000);
    wlan_start(0);
    wlan_set_event_mask(HCI_EVNT_WLAN_KEEPALIVE|HCI_EVNT_WLAN_UNSOL_INIT|HCI_EVNT_WLAN_ASYNC_PING_REPORT);
    Nikola
    Report Abuse
    • Reply
  • GustavoL
    Posted by GustavoL
    on Apr 11 2012 14:24 PM
    Nikola,
    Enable fast connect as well, the second parameter in the connection policy function and see whether that works.
    Gustavo
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
