• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » SimpleLink™ Wi-Fi® » CC3000 Won't Connect to WiFi network
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Jon Knoll
Posted by Jon Knoll
on Aug 11 2012 16:48 PM
Prodigy70 points
I've tried using FTC mode using my iphone.  The format I used was TTT5ssid02password.   Using 5 for the SSID length and 2 for WPA security.  LED8 blinks for a little while and then stops.  I get nothing after that.
I've tried modifying the ConnectUsingSSID method in the 'webserver' application to this:
    wlan_connect(2, ssidName, strlen(ssidName), NULL, "password", 8);
Where ssidName is the SSID for my network.  When I run the code in debug, I am stuck in the 'connection loop' with current currentCC3000State() returning a value of 3.
I've tried turning all security off on my router but nothing seems to work.
Thanks in advance for the help.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • //--Kelvin--\\
    Posted by //--Kelvin--\\
    on Aug 13 2012 08:37 AM
    Intellectual1335 points
    Hi Jon,
    So were you able to get the Basic WiFi Application compiled?  If so, you would be best served to test your connection with that application.  Next, lets try to make sure you can make a connection without security first, to eliminate any issues with security settings.  So go into your router and remove any security from your wireless settings, then reboot your router.  I would like to start by asking what type of router you are using and what are the rest of the wireless settings of the router.  If you are using the TP-Link router then all of the  mode settings, except for n-only should be fine.  However, some other routers may cause issues with the cc3000 connecting if any mixed mode settings are enabled which has n-mode included.  So please check for this, and try to change your mixed mode setting to b/g modes only.  Also please just do a quick check to make sure that there is no MAC filtering going on, you are broadcasting the SSID, and that the wirelsss radio is definitely enabled.  I only mention this becasue sometimes it is easy to look over seemingly obvious solutions.  So once all of this is checked, and you have the Basic WiFi application running, please type "01" to send the CC3000 into FTC and try your connection again.  If you are still having issues, it may help if you could post some screenshots of your router's wireless settings.  There may be some other setting that is causing the issue.
    Kelvin
    Please click the Verify Answer button on this post if it answers your question.  Thank You.
    Report Abuse
    • Reply
  • Jon Knoll
    Posted by Jon Knoll
    on Aug 17 2012 21:34 PM
    Verified Answer
    Verified by Jon Knoll
    Prodigy70 points
    Hey Kelvin,
    Thanks for the reply, I was actually able to figure out my problem when I actually read through all of the wikis.  I needed to download the patch programmer and update the device.  Once I did that I was able to connect without a problem.  Thanks!
    Report Abuse
    • Reply
  • Manoj Kumar1
    Posted by Manoj Kumar1
    on Feb 21 2013 07:03 AM
    Prodigy165 points
    Hi Jon,
               I trying to do FTC using FRAM board+CC3000 . when type 01 in Hyperterminal LED6 keep on Blinking. FTC is not happening. here the screenshot of My TP-Link wireless setting.
    1727.Screenshot_tplink.docx
    Problem with FTC
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
