I am trying to complile a program using the compiler for a DSP2803x using CCSv4. I am trying to use embedded C++ and the compiler is failing.
1st: Does the C2000 compiler support C++?
I am getting the following errors/warnigs:
I am also working with a Stellaris micro and have the same C++ setting but no warnings/errors. Also is there startup code associated with running a C2000?
"../Application/Main_main.cpp", line 109: warning: linkage specification is not allowed At end of source: error: expected a "}" 1 error detected in the compilation of "../Application/Main_main.cpp". Can someone please help me solve these problems? Thank you, Luke
