• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » F28335 ADC sampling delay
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • F28335 ADC sampling delay
    This question is not answered
    wauters gregory
    Posted by wauters gregory
    on Nov 03 2011 08:58 AM
    Prodigy160 points
    hi all,
    I am using a PWM to trigger my ADC ISR, when I toggle an output in the ADC ISR, The delay between each sampling is 400Khz. I need 800Khz at least.
    has anyone an idea of what I am doing wrong to be so slow ???.
    Thanks a million for your support,
    greg.
    void InitCan(void)
        // Specific clock setting
        SysCtrlRegs.HISPCP.all = ADC_MODCLK;    // HSPCLK = SYSCLKOUT/2*ADC_MODCLK
         // init the ADC, calibration
        InitAdc();
        // ADC SETUP
        //sequential sampling mode
        AdcRegs.ADCTRL3.bit.SMODE_SEL   = 0x0;
        AdcRegs.ADCMAXCONV.all             = 0x0000;
        // Set up ADC to perform 1ere conversions on A0
        AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0;
        // selection reference exterieure 2.048V
        AdcRegs.ADCREFSEL.bit.REF_SEL = 0x1;
        //enable ISR to CPU
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1 = 0x0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 0x1;
        AdcRegs.ADCTRL1.bit.ACQ_PS   = ADC_SHCLK;
        //ADC operates as a 16-state sequencer
        AdcRegs.ADCTRL1.bit.SEQ_CASC = 0x1;
        AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
        AdcRegs.ADCTRL2.bit.RST_SEQ1 = 0x1;
    interrupt void  adc_isr(void)
        GpioDataRegs.GPASET.bit.GPIO2 = 1;
        g_AdcMesure.uiVoieMes[g_iCptMes]    = AdcRegs.ADCRESULT0   >>4;
        // Reinitialize for next ADC sequence
        AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
        AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
       // Acknowledge interrupt to PIE
        PieCtrlRegs.PIEACK.bit.ACK6 = 1;
        GpioDataRegs.GPACLEAR.bit.GPIO2 = 1;
    void InitEPwm(void)
       // Initialize ePWM2
    //--- Must disable the clock to the ePWM modules if you
    //--- want all ePMW modules synchronized.
        asm(" EALLOW");                        // Enable EALLOW protected register access
        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
        asm(" EDIS");                        // Disable EALLOW protected register access
    //--- Configure ePWM2 to trigger the ADC at 800 kHz rate
        EPwm2Regs.TBCTL.bit.CTRMODE = 0x3;        // Disable the timer
        EPwm2Regs.TBCTL.all = 0xC033;            // Configure timer control register
    // bit 15-14     11:     FREE/SOFT, 11 = ignore emulation suspend
    // bit 13        0:      PHSDIR, 0 = count down after sync event
    // bit 12-10     000:    CLKDIV, 000 => TBCLK = HSPCLK/1
    // bit 9-7       000:    HSPCLKDIV, 000 => HSPCLK = SYSCLKOUT/1
    // bit 6         0:      SWFSYNC, 0 = no software sync produced
    // bit 5-4       11:     SYNCOSEL, 11 = sync-out disabled
    // bit 3         0:      PRDLD, 0 = reload PRD on counter=0
    // bit 2         0:      PHSEN, 0 = phase control disabled
    // bit 1-0       11:     CTRMODE, 11 = timer stopped (disabled)
        EPwm2Regs.TBCTR = 0x0000;                // Clear timer counter
        EPwm2Regs.TBPRD = ADC_SAMPLE_PERIOD;    // // 187 = (187.5-1) = 150 MHz SYSCLKOUT / 800 KHz sampling
        EPwm2Regs.TBPHS.half.TBPHS = 0x0000;    // Set timer phase
        EPwm2Regs.ETPS.all = 0x0100;            // Configure SOCA
    // bit 15-14     00:     EPWMxSOCB, read-only
    // bit 13-12     00:     SOCBPRD, don't care
    // bit 11-10     00:     EPWMxSOCA, read-only
    // bit 9-8       01:     SOCAPRD, 01 = generate SOCA on first event
    // bit 7-4       0000:   reserved
    // bit 3-2       00:     INTCNT, don't care
    // bit 1-0       00:     INTPRD, don't care
        EPwm2Regs.ETSEL.all = 0x0A00;            // Enable SOCA to ADC
    // bit 15        0:      SOCBEN, 0 = disable SOCB
    // bit 14-12     000:    SOCBSEL, don't care
    // bit 11        1:      SOCAEN, 1 = enable SOCA
    // bit 10-8      010:    SOCASEL, 010 = SOCA on PRD event
    // bit 3         0:      INTEN, 0 = disable interrupt
    // bit 2-0       000:    INTSEL, don't care
        EPwm2Regs.TBCTL.bit.CTRMODE = 0x0;        // Enable the timer in count up mode
    //--- Enable the clocks to the ePWM module.
    //--- Note: this should be done after all ePWM modules are configured
    //--- to ensure synchronization between the ePWM modules.
        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;    // HSPCLK to ePWM modules enabled
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Edwin Krasser
      Posted by Edwin Krasser
      on Nov 03 2011 09:25 AM
      Expert2220 points
      Hi!
      Your timer causes an interrupt every 188 clock cycles. Hence, your ADC interrupt service routine must be (a lot) faster than that. If it is not, you will miss interrupts. You use gpio2 as monitor for your isr runtime. How long does it take?
      Edwin Krasser
      Report Abuse
      • Reply
    • wauters gregory
      on Nov 03 2011 09:47 AM
      Prodigy160 points
      hi !!!
      the period is 6.24µsec, the duty cycle almost 50%.
      best regards,
      greg.
      Report Abuse
      • Reply
    • Edwin Krasser
      on Nov 03 2011 10:43 AM
      Expert2220 points
      Hi!
      This means that you are approximately 3 us in your interrupt service routine? Hence you cannot get every interrupt because you are still in the isr when the next interrupt request occurs.
      Edwin Krasser
      Report Abuse
      • Reply
    • wauters gregory
      on Nov 04 2011 03:28 AM
      Prodigy160 points
      Hi !,
      does it mean I can reach a sampling rate of 1/3µsec ?. I can not figure out what the DSP is doing during the other 3µsec ?.
      Anyway, I want to achieved a 800Khz sampling rate, is it possible with the F28335 and how ?. I have lowered the set-up and hold to its minimum, my ADC freq is 25Mhz so can I reach the 12.5MSPS rate ?.
      n
      Report Abuse
      • Reply
    • Edwin Krasser
      on Nov 04 2011 04:09 AM
      Expert2220 points
      Hi!
      Well, the ADC is able to achieve 12.5 MSPS. But how do you want to process this data? At 12.5 MSPS you have got 12 clock cycles per sample. Hence you cannot work with interrupts, you have to start a free running adc at maximum sampling rate and a synchronous data acquisition loop with exactly 12 clock cycles storing the conversion results into a buffer. But in this time, your processor cannot handle anything else. And after storing all the data you can process it.
      At 1 MSPS you will have 150 clock cycles per sample. This might be enough for calling the isr and store the data (and perhaps some very simple processing). But: How many cycles does your processing function need? Do you have any other interrupts in your system?
      Edwin Krasser
      Report Abuse
      • Reply
    • wauters gregory
      on Nov 04 2011 05:31 AM
      Prodigy160 points
      Hi !!!,
      In my application I can acquire all the 8192 samples and then handle them. So The solution would be:
      1/ start a free running ADC @ 1MSPS
      2/ acquire and store data in SRAM 8192 times
      3/ stop ADC and process data
      Am I correct ?. How do you garantee that the storing of conversion match exactly the sampling time ?
      greg Wauters.
      Report Abuse
      • Reply
    • Edwin Krasser
      on Nov 04 2011 06:00 AM
      Expert2220 points
      Hi!
      If you just need 1 MHz sampling rate, you can try the interrupt concept. But keep your isr short. And if you want to use a synchronous loop it's the best to write a short assembler function which disables interrupts, starts the adc and does the data acquisition loop 8192 times. Of course, your loop will be much too fast. Just insert some NOPs (rpt #n || nop ... n+1 NOPs).
      Best regards and good luck,
      Edwin Krasser
      Report Abuse
      • Reply
    • wauters gregory
      on Nov 22 2011 04:26 AM
      Prodigy160 points
      Hi edwin,
      just to thank you for the time you spend on my issue, It works grand now. One big timing improvement was to run my code from RAM.
      best regards,
      greg.
      Report Abuse
      • Reply
    • Rui Chen
      Posted by Rui Chen
      on Aug 02 2012 06:56 AM
      Prodigy150 points
      I am having some problems with an application that is similar to the one described in this thread.
      I want to:
      1) Sample 1000 ADC values on A0 with 12.5MSPS and store the values in an array
      2) Analyze the values
      3) Send result by SCI to PC
      4) Repeat
      So the main difference to the problem described in this thread is that I need 12.5MSPS. Based on the example Example_2833xAdcSeq_ovdTest I have written a program that does step 1-4. However my sampling frequency is just about 1MSPS, how do i setup my ADC to sample at 12.5MSPS?
      Here is an extract of my code:
      // ADC start parameters
      #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT
      #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz
      #endif
      #if (CPU_FRQ_100MHZ)
      #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz
      #endif
      #define ADC_CKPS 0x1 // ADC module clock = HSPCLK/2*ADC_CKPS = 25.0MHz/(1*2) = 12.5MHz
      #define ADC_SHCLK 0xf // S/H width in ADC module periods = 16 ADC clocks
      #define AVG 1000 // Average sample limit
      #define ZOFFSET 0x00 // Average Zero offset
      #define BUF_SIZE 2048 // Sample buffer size
      //declare global vars and functions
      main()
      Uint16 i;
      // Step 1. Initialize System Control:
      // PLL, WatchDog, enable Peripheral Clocks
      // This example function is found in the DSP2833x_SysCtrl.c file.
      InitSysCtrl();
      // Specific clock setting for this example:
      EALLOW;
      SysCtrlRegs.HISPCP.all = ADC_MODCLK; // HSPCLK = SYSCLKOUT/ADC_MODCLK
      EDIS;
      // Step 2. Initialize GPIO:
      // For this example, only init the pins for the SCI-A port.
      // This function is found in the DSP2833x_Sci.c file.
      InitSciaGpio();
      // Step 3. Clear all interrupts and initialize PIE vector table:
      // Disable CPU interrupts
      DINT;
      // Initialize the PIE control registers to their default state.
      // The default state is all PIE interrupts disabled and flags
      // are cleared.
      // This function is found in the DSP2833x_PieCtrl.c file.
      InitPieCtrl();
      // Disable CPU interrupts and clear all CPU interrupt flags:
      IER = 0x0000;
      IFR = 0x0000;
      // Output on GPIO34
      EALLOW;
      GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0; // GPIO
      GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1; // output
      EDIS;
      // For this example, init the ADC
      InitAdc();
      // Specific ADC setup for this example:
      AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 1 Cascaded mode
      AdcRegs.ADCTRL1.bit.CONT_RUN = 1; // Setup continuous run
      // Step 5. User specific code, enable interrupts:
      scia_fifo_init(); // Initialize the SCI FIFO
      scia_echoback_init(); // Initalize SCI for echoback
      // Clear SampleTable
      for (i=0; i<BUF_SIZE; i++)
      SampleTable[i] = 0;
      // Start SEQ1
      AdcRegs.ADCTRL2.all = 0x2000;
      // Take ADC data and log the in SampleTable array
      for(;;)
      GpioDataRegs.GPBSET.bit.GPIO34 = 1; // GPIO34 is high
      //sample and put values in SampleTable
      for (i=0; i<AVG; i++)
      while (AdcRegs.ADCST.bit.INT_SEQ1== 0) {} // Wait for interrupt
      SampleTable[i] =((AdcRegs.ADCRESULT0>>4) );
      // print contents of SampleTable on SCI
      for(i = 0; i < AVG; i++)
      if(i%10 == 0)
      scia_msg("\r\n");
      else
      scia_msg(" ; ");
      printNum(SampleTable[i]);
      scia_msg("\r\n...done!\r\n");
      GpioDataRegs.GPBCLEAR.all = 0x4; // GPIO34 is low
      //wait until next cycle
      pause(100);
      //define functions
      Report Abuse
      • Reply
    • Edwin Krasser
      on Aug 02 2012 07:31 AM
      Expert2220 points
      Hi!
      You have got a sample time of 16 clock cycles. Not okay, you need to sample as fast as possible. Now you just can achieve 25 MHz / 16 samples per second, even if the adc was infinitely fast.
      Edwin Krasser
      Report Abuse
      • Reply
    • Rui Chen
      Posted by Rui Chen
      on Aug 02 2012 09:21 AM
      Prodigy150 points
      Hi Edwin,
      Thanks for your fast reply!
      I've changed
      to
      #define ADC_SHCLK  0x0
      and it works much better now! However, I still only get around 5MSPS :( Could it be that I loose half my sampling rate when I write the ADC value to the SamplingTable array in:
      Or is it some register that I have set to the wrong value?
      Thanks!
      Report Abuse
      • Reply
    • Edwin Krasser
      on Aug 03 2012 00:07 AM
      Expert2220 points
      Hi!
      I think your loop is not fast enough. Just think about the cpu clock frequency. At 12.5 MHz sampling rate you just have 12 ticks for storing the adc results. For high speed adc sampling I suggest to write a free running loop that stores the adc results into an array. Write it in assembler and be sure every loop cycle takes exactly 12 ticks (insert nops ifyou need). Something like that:
        AVG -> ar0
        SampleTable -> xarn
      loop:
        adcresult -> acc
        acc -> *xarn++
        nop ; some nops to get exactly 12 ticks per loop
      banz loop,ar0--
      Edwin Krasser
      Report Abuse
      • Reply
    • Rui Chen
      Posted by Rui Chen
      on Aug 03 2012 01:57 AM
      Prodigy150 points
      Thanks a lot Edwin, I havent worked with assembler before but I guess this is a good opportunity to learn. I'll try to write the sampling loop in assembler as you suggest.
      Best wishes!
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
