• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » Concerto ADC
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • Concerto ADC
    Concerto ADC
    This question is answered
    JasonHaedt
    Posted by JasonHaedt
    on Feb 01 2012 15:42 PM
    Expert2595 points
     I’ve noticed on the Concerto ADC that the sample rate they claim (up to 2.88MSPS) is only the conversion rate and not the whole true conversion time (i.e. sample time + conversion time).  Do they claim this due to having 2 sample-and-hold circuits?
    -Jason
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Devin Cottier
      Posted by Devin Cottier
      on Feb 01 2012 16:25 PM
      Expert7155 points
      The Concerto ADC has two sample and hold circuits with some degree of pipelining, so the sample rate does not directly correspond to the sample latency.  There are also 2 ADCs on Concerto, each with sample rate 2.88MSPS.
      Report Abuse
      • Reply
    • Ilya Peysakhov
      Posted by Ilya Peysakhov
      on Jun 20 2012 00:49 AM
      Prodigy130 points
      does it mean that continues sampling with concerto ADC will not allow to reach 2.8 MSPS continues sampling?
      Is it possible to get a clear answer on this matter, or example for this ADC configuration on single channel continues sampling?
      Thank you very much,
      Ilya
      Report Abuse
      • Reply
    • Devin Cottier
      on Jun 20 2012 09:49 AM
      Expert7155 points
      You will be able to get 2.8 MSPS on a single channel, sampling continuously (and since there are actually 2 ADC modules, you can get 2.8MSPS on two different channels at the same time).  My point is just that you can not calculate the sample rate using the formula:
      Sample Rate = 1 / total conversion time
      because the ADC architecture has some degree of pipelining.  Even though a sample is still converting, the ADC is able to begin the sampling phase for the next sample.
      This is not due to having 2 S+H.  The 2 S+H allows you to sample 2 signals at the exact same time, then convert them sequentially.  The total sample rate in this case will also be near 2.8MSPS, but the sample rate for a particular signal will be half of that.  Note that EACH of the 2 ADCs has 2 S+H, for 4 total S+H circuits.
      Report Abuse
      • Reply
    • Ilya Peysakhov
      on Jun 20 2012 10:52 AM
      Prodigy130 points
      My fastest configuration yet is attached, where it reaches little bit less than 1MSPS, but no more Idle time is remained to copy aside and handle the results?
      What am I doing wrong ?
      Ilya
      Report Abuse
      • Reply
    • Ilya Peysakhov
      Prodigy130 points
      Ilya
      Report Abuse
      • Reply
    • Ilya Peysakhov
      on Jun 20 2012 10:55 AM
      Prodigy130 points
      Ilya
      #include "DSP28x_Project.h" // Device Headerfile and Examples Include File
      #define DUTY_CYCLE_A 500
      #define DUTY_CYCLE_B 500
      #define PERIOD 1000
      #define BUFFER_LENGTH (1000)
      // Prototype statements for functions found within this file.
      interrupt void adc2_isr(void);
      void Adc_Config(void);
      // Global variables used in this example:
      Uint32 LoopCount;
      Uint16 ConversionCount;
      //Uint16 Voltage1[BUFFER_LENGTH];
      Uint16 Voltage2[BUFFER_LENGTH];
      main()
      // unsigned short analoginit;
      // Step 1. Initialize System Control for Control and Analog Subsytems
      // Enable Peripheral Clocks
      // This example function is found in the F28M35x_SysCtrl.c file.
      InitSysCtrl();
      // Step 2. Initialize GPIO:
      // This example function is found in the F28M35x_Gpio.c file and
      // illustrates how to set the GPIO to it's default state.
      InitGpio(); // Skipped for this example
      EALLOW;
      GpioG1CtrlRegs.GPCDIR.bit.GPIO70 = 1; //set PC6_GPIO70 as output //LED
      GpioG1CtrlRegs.GPADIR.bit.GPIO24 = 1; // Set as output
      EDIS;
      /* EALLOW;
      GpioG1CtrlRegs.GPADIR.bit.GPIO0 = 1; //Set as output
      GpioG1CtrlRegs.GPADIR.bit.GPIO8 = 1; //Set as output
      GpioG1CtrlRegs.GPAMUX1.bit.GPIO0 = 1; //Set mux to EPWM1A
      GpioG1CtrlRegs.GPAMUX1.bit.GPIO8 = 3; //Set mux to ADCSOCAn
      EDIS;
      // Step 3. Clear all interrupts and initialize PIE vector table:
      // Disable CPU interrupts
      DINT;
      // Initialize the PIE control registers to their default state.
      // The default state is all PIE interrupts disabled and flags
      // are cleared.
      // This function is found in the F28M35x_PieCtrl.c file.
      InitPieCtrl();
      // Disable CPU interrupts and clear all CPU interrupt flags:
      IER = 0x0000;
      IFR = 0x0000;
      // Initialize the PIE vector table with pointers to the shell Interrupt
      // Service Routines (ISR).
      // This will populate the entire table, even if the interrupt
      // is not used in this example. This is useful for debug purposes.
      // The shell ISR routines are found in F28M35x_DefaultIsr.c.
      // This function is found in F28M35x_PieVect.c.
      InitPieVectTable();
      // Interrupts that are used in this example are re-mapped to
      // ISR functions found within this file.
      EALLOW; // This is needed to write to EALLOW protected register
      PieVectTable.ADCINT1 = &adc2_isr;
      EDIS; // This is needed to disable write to EALLOW protected registers
      // Step 4. Initialize all the Device Peripherals:
      // This function is found in F28M35x_InitPeripherals.c
      // InitPeripherals(); // Not required for this example
      InitAdc2(); // For this example, init the ADC
      // Step 5. User specific code, enable interrupts:
      // Enable ADCINT1 in PIE
      PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable INT 1.1 in the PIE
      IER |= M_INT1; // Enable CPU Interrupt 1
      EINT; // Enable Global interrupt INTM
      ERTM; // Enable Global realtime interrupt DBGM
      LoopCount = 0;
      ConversionCount = 0;
      // Configure ADC
      EALLOW;
      Adc2Regs.ADCCTL2.bit.ADCNONOVERLAP = 0; // Enable non-overlap mode i.e.
      // conversion and future
      // sampling
      // events dont overlap
      //Adc1Regs.ADCCTL1.bit.INTPULSEPOS = 1; // ADCINT1 trips after
      // AdcResults latch
      Adc2Regs.INTSEL1N2.bit.INT1E = 1; // Enabled ADC2NT1
      Adc2Regs.INTSEL1N2.bit.INT1CONT = 1; // Disable ADC2NT1 Continuous
      // mode
      Adc2Regs.INTSEL1N2.bit.INT1SEL = 0; // setup EOC0 to trigger ADCINT1
      // to fire
      Adc2Regs.ADCSOC0CTL.bit.CHSEL = 0; // set SOC0 channel select to
      // ADC1A0
      // Adc1Regs.ADCSOC1CTL.bit.CHSEL = 2; // set SOC1 channel select to
      // ADC1A2
      AnalogSysctrlRegs.TRIG1SEL.all = 0; // Assigning
      // ADC TRIGGER 1 of the ADC module
      Adc2Regs.ADCSOC0CTL.bit.TRIGSEL = 0; // Set SOC0 start trigger to
      // ADC Trigger 1(EPWM1 SOCA) of the
      // adc
      Adc2Regs.ADCSOC0CTL.bit.ACQPS = 6; // set SOC0 S/H Window to 7 ADC
      // Clock Cycles, (6 ACQPS plus
      // 1)
      Adc2Regs.ADCSOC1CTL.bit.ACQPS = 6; // set SOC1 S/H Window to 7 ADC
      // 1)
      EDIS;
      // count
      // Wait for ADC interrupt
      Adc2Regs.ADCSOCFRC1.bit.SOC0 = 1;
      for(;;)
      LoopCount++;
      if (0 == (LoopCount % 1000000))
      //GpioG1DataRegs.GPATOGGLE.bit.GPIO70 = 1;
      if(GpioG1DataRegs.GPCDAT.bit.GPIO70 == 0)
      GpioG1DataRegs.GPCSET.bit.GPIO70 = 1;
      else
      GpioG1DataRegs.GPCCLEAR.bit.GPIO70 = 1;
      Adc2Regs.ADCSOCFRC1.bit.SOC0 = 1; // retriger next conversion
      Voltage2[ConversionCount] = Adc2Result.ADCRESULT0;
      // If 1000 conversions have been logged, start over
      if(ConversionCount == BUFFER_LENGTH - 1)
      GpioG1DataRegs.GPATOGGLE.bit.GPIO24 = 1;
      else ConversionCount++;
      Adc2Regs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Clear ADCINT1 flag reinitialize
      // for next SOC
      PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE
      //Adc2Regs.ADCSOCFRC1.bit.SOC0 = 1; // retriger next conversion
      return;
      Report Abuse
      • Reply
    • RickyRosinski
      Posted by RickyRosinski
      on Jun 20 2012 11:38 AM
      Intellectual1105 points
      How did you set up the system clock in the M3 code and the ACIB clock?  Can you show me that code?
      Ricky
      Report Abuse
      • Reply
    • Ilya Peysakhov
      on Jun 21 2012 03:55 AM
      Prodigy130 points
      i am using the configuration which based on adc_soc example from
      C:\TI\controlSUITE\device_support\f28m35x\vBeta1\F28M35x_examples_Control\adc_soc\c28
          // Initialize the Analog Sub-System and set the clock divider to divide by 4
          (**InitAnalogSystemClock)(ACLKDIV4);
      Report Abuse
      • Reply
    • RickyRosinski
      on Jun 21 2012 09:34 AM
      What example did you use for the M3 core?  I need to know the clock settings in the M3 code.  If you used the setup_m3 example then is this the code you used?
          // Sets up PLL, M3 running at 75MHz and C28 running at 150MHz
          SysCtlClockConfigSet(SYSCTL_USE_PLL | (SYSCTL_SPLLIMULT_M & 0xF) |
                               SYSCTL_SYSDIV_1 | SYSCTL_M3SSDIV_2 |
                               SYSCTL_XCLKDIV_4);
      Ricky
      Report Abuse
      • Reply
    • Ilya Peysakhov
      on Jun 21 2012 09:40 AM
      Prodigy130 points
      that's right, setup_m3 as it is
      Report Abuse
      • Reply
    • RickyRosinski
      on Jun 25 2012 13:48 PM
      I found an error in your ADC2 setup code.  If you want ADC2 trigger 1 to be tied to EPWM1 SOCA the following lines need to be changed.
      The comments are also reversed.
      AnalogSysctrlRegs.TRIG1SEL.all = 5;  // Set SOC0 start trigger to ADC Trigger 1(EPWM1 SOCA) of the adc
      Adc2Regs.ADCSOC0CTL.bit.TRIGSEL = 5; // Assigning ADC TRIGGER 1 of the ADC module to SOC0
      Settings these bit fields to 0 is reserved.
      Also just a note.  You have the ADCNONOVERLAP bit set to 0, but the comment says that this statement enables non-overlap mode.  Setting this bit
      to 0 actually puts the ADC in overlap mode.  This is what you want to get the fastest performance, so maybe you can change the comment for clarity.
      Ricky
      Report Abuse
      • Reply
    • Ilya Peysakhov
      on Jun 26 2012 08:38 AM
      Verified Answer
      Verified by JasonHaedt
      Prodigy130 points
      1. I set those bits to 0, because trigering is performed from the code by
      Adc2Regs.INTSEL1N2.bit.INT1CONT = 1 // setting continues mode
      and
      inside interrupt handler (this is the only way it's working although continues mode expected to spare the last writing)
      2. I am not using the EPWM triger because I need to sample it as fast as possible, is it possible to set the EPWM to triger each SOC 0.5 usec for example?
      3. Do I need to link the (EOC0 to SOC1)  (EOC1 to SOC2) (EOC2 to SOC3) and so on untill 8 and all CHSEL to one leg?
      Do you may be have a simple example on how to sequentially sample even with 1 Msps?
      Thank
      BR,
      Ilya
      Report Abuse
      • Reply
    • RickyRosinski
      on Jun 29 2012 14:40 PM
      Verified Answer
      Here is code that should run at the max ADC sampling speed.
      Adc1Regs.ADCCTL1.bit.INTPULSEPOS    = 1;    //adcint pulse position at end of sample
      Adc1Regs.INTSEL1N2.bit.INT1E = 1;       //enable ADCINT1
      Adc1Regs.INTSEL1N2.bit.INT2E = 1;       //enable ADCINT2
      Adc1Regs.INTSEL1N2.bit.INT1CONT = 0;    //disable continuous mode for ADCINT1
      Adc1Regs.INTSEL1N2.bit.INT2CONT = 0;    //disable continuous mode for ADCINT2
      Adc1Regs.INTSEL1N2.bit.INT1SEL = 6;     //EOC6 will trigger ADCINT1
      Adc1Regs.INTSEL1N2.bit.INT2SEL = 14;    //EOC14 will trigger ADCINT2
      Adc1Regs.ADCINTSOCSEL1.bit.SOC0 = 2;    //ADCINT2 starts SOC0
      Adc1Regs.ADCINTSOCSEL1.bit.SOC1 = 2;    //ADCINT2 starts SOC1
      Adc1Regs.ADCINTSOCSEL1.bit.SOC2 = 2;    //ADCINT2 starts SOC2
      Adc1Regs.ADCINTSOCSEL1.bit.SOC3 = 2;    //ADCINT2 starts SOC3
      Adc1Regs.ADCINTSOCSEL1.bit.SOC4 = 2;    //ADCINT2 starts SOC4
      Adc1Regs.ADCINTSOCSEL1.bit.SOC5 = 2;    //ADCINT2 starts SOC5
      Adc1Regs.ADCINTSOCSEL1.bit.SOC6 = 2;    //ADCINT2 starts SOC6
      Adc1Regs.ADCINTSOCSEL1.bit.SOC7 = 2;    //ADCINT2 starts SOC7
      Adc1Regs.ADCINTSOCSEL2.bit.SOC8 = 1;    //ADCINT1 starts SOC8
      Adc1Regs.ADCINTSOCSEL2.bit.SOC9 = 1;    //ADCINT1 starts SOC9
      Adc1Regs.ADCINTSOCSEL2.bit.SOC10 = 1;   //ADCINT1 starts SOC10
      Adc1Regs.ADCINTSOCSEL2.bit.SOC11 = 1;   //ADCINT1 starts SOC11
      Adc1Regs.ADCINTSOCSEL2.bit.SOC12 = 1;   //ADCINT1 starts SOC12
      Adc1Regs.ADCINTSOCSEL2.bit.SOC13 = 1;   //ADCINT1 starts SOC13
      Adc1Regs.ADCINTSOCSEL2.bit.SOC14 = 1;   //ADCINT1 starts SOC14
       Adc1Regs.ADCINTSOCSEL2.bit.SOC15 = 1;   //ADCINT1 starts SOC15
      Adc1Regs.ADCSOCFRC1.all = 0x00FF; // force SOC0-15
      while(1){
      while (Adc1Regs.ADCINTFLG.bit.ADCINT1 == 0){}
      Adc1Regs.ADCINTFLGCLR.bit.ADCINT1 = 1;          //clear ADCINT1
      // Read ADC Results 0 -7 here
      while (Adc1Regs.ADCINTFLG.bit.ADCINT2 == 0){}
      Adc1Regs.ADCINTFLGCLR.bit.ADCINT2 = 1;              //clear ADCINT2
      // Read ADC Results 8 -15 here
      } // loop until done sampling
      //disable adcint1 and adcint2 to STOP the ping-pong sampling
      Adc1Regs.INTSEL1N2.bit.INT1E = 0;
      Adc1Regs.INTSEL1N2.bit.INT2E = 0;
      Report Abuse
      • Reply
    • Pat Harris
      Posted by Pat Harris
      on Jul 11 2012 16:35 PM
      Expert2105 points
      Ricky,
      I plan to use all the available analog inputs provided with the Concerto eval module. This is channels ADC1 - A0,A2, A3, A4, A6, A7, B4 and ADC2 - A0, A2, A3, A4, A6, A7, B0, B4. I could not find the correlation to actual input pin from the SOC number or channel number in the headeer files.  Could you explain the relationship or point me to the information?
      Pat
      Report Abuse
      • Reply
    • RickyRosinski
      on Jul 11 2012 16:53 PM
      Pat,
      The SOC number correlates to the ADC result register, so SOC0 puts its result in ADC Result 0, and SOC1 puts its result in ADC Result 1, and so on.  It does not matter which ADC channel you use, SOC0 result will always go in ADC Result 0.  As far as relating an ADC pin to an ADC channel, see below.
      ADC1 - A0 is ADC1INA0 pin - channel field in SOC register should be 0
      ADC1 - A2 is ADC1INA2 pin - channel field in SOC register should be 2
      ADC1 - B5 is ADC1INB4 pin - channel field in SOC register should be 12 since B0 needs an 8 in the channel field in the SOC register
      Ricky
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
