• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » Need some help in troubleshooting
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • Need some help in troubleshooting
    This question is not answered
    Andrew Ong
    Posted by Andrew Ong
    on Mar 05 2012 06:44 AM
    Prodigy60 points
    Hello to everyone,
    I am new to this DSP board and would like to ask for some help in troubleshooting, ie. to connect to my PC.
    Below are some of the technical information
    Operating System: Windows XP 32bit
    DSP: TMS320F2812
    Software: CCS 3.1
    Drivers: C2000 -> CCS 3.1 Driver Release 3.01.04C
    Error Message when I tried connecting in CCS 3.1:
    Error connecting to the target: Error 0x80000200/-1031 Fatal Error during: OCS, Device driver: Problem with the Emulation Controller. It is recommended to RESET EMULATOR. This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target. Sequence ID: 0 Error Code: -1031 Error Class: 0x80000200 I/O Port = 378 Board Name: F2812 eZdsp Cpu Name: cpu_0 Abort: Close Code Composer Studio. Retry: Try to connect to the target again. Cancel: Remain disconnected from the target Diagnostic: Run diagnostic utility.
    Additional Information: I have tried to reset the emulator using the SDConfig program. And SDConfig replied affirmatively to my reset command. In my CCS Setup, I have chosen
    F2812 eZdsp. Below is my SD Config screenshot.
    Please advise.
    Let me know if more information is needed. Thank you for reading.
    Have a nice day.
    F2812 C2000 Ezdsp TMS320F2812 C28x
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Brett Novak
      Posted by Brett Novak
      on Mar 05 2012 10:41 AM
      Intellectual940 points
      Hi Andres - it looks like an issue with the XDS510 drivers.
      Try updating with these - http://www.sdidownloads.com/downloads/support/ccs31/Release-30104C/setupCCSPlatinum_v30104C.ZIP
      and let us know if you have the same issue.
      Report Abuse
      • Reply
    • Andrew Ong
      on Mar 06 2012 22:20 PM
      Prodigy60 points
      Hello Brett,
      I have updated the CCS using your file (uninstalling followed by installing the new drivers)
      However, when I select F2812 eZdsp in CCS Setup, I get the following error:
      CCS does run when I click OK. But the same connection error occurs when I tried to connect (shown below):
      By the way, my TMS320F2812 is connected to the PC via a printer cable directly. What should be my hardware product? XDS510PP_PLUS? or should it be XDS510PP?
      Any suggestions? Hope to hear some good news soon!
      Thank you and have a nice day.
      Andrew Ong
      Report Abuse
      • Reply
    • Andrew Ong
      on Mar 07 2012 00:22 AM
      Prodigy60 points
      My apologies, the f2812.gel error was because I forgot to reinstall the target content from the CD supplied.
      Now, there are no problems in starting the CCS v3.1
      However, when I tried to connect from the Debug menu, the following error occurs:
      SDConfig is the same as the one in previous post, using SPP8 as emulator port mode. I have also configured my parallel port mode in BIOS to be SPP. Is there any problems with the configurations?
      What is this Error 1150 about? I do not have anything connected to the JTAG port on the board, instead connection is made to PC via printer cable only.
      Thank you for your help so far and I hope to hear from you soon.
      Andrew Ong
      Report Abuse
      • Reply
    • Andrew Ong
      on Mar 11 2012 22:20 PM
      Prodigy60 points
      Hi to all,
      anyone have any ideas or suggestions with regards to this error 1150? Please help, the problem still exists and I can't continue my work.
      Andrew
      Report Abuse
      • Reply
    • Mitja Nemec
      Posted by Mitja Nemec
      on Mar 12 2012 02:16 AM
      Genius4175 points
      Right click on "my computer"/manage/device manager/ports/printer port/port settings/use any interrupt assigned
      Restart the PC
      in CCS setup make sure that the port address is the same that actual port address
      Hope this help
      Regards, Mitja
      Report Abuse
      • Reply
    • Andrew Ong
      on Mar 13 2012 22:53 PM
      Prodigy60 points
      Mitja Nemec
      Restart the PC
      Hope this help
      Regards, Mitja
      When you say make sure port address is the same as that actual port address? what do u mean by actual port address?
      My Device Manager LPT Port Number is LPT1 and my CCS Setup PP Emulator address is 0x378. I do not see any other addresses other than these two. Can you advise further?
      I am perplexed when CCS error says "JTAG protocol reset" when in my setup, I am using a printer cable to connect the board to the computer parallel port.
      In addition, I am able to reset my emulator from within Sdconfig v3.1. Does this narrow down the problem? What could be the problem here?
      Andrew
      Report Abuse
      • Reply
    • Andrew Ong
      on Mar 13 2012 23:11 PM
      Prodigy60 points
      I tried using SDConfig v3.1 to test my connection. Prior to this, I set my BIOS to SPP.
      It was verified that the board is connected under Configuration->Verify:
      ** Checking for a valid emulator/eZdsp
        $$ You are connected to:
        $$ EmuProductName=XDS510PP_PLUS
        $$ EmuPortAddr=0x378
        $$ EmuPortMode=SPP8
        $$ ProductId=10
        $$ ProductVersion=84
      However, when I tried to test connection under Emulator->Test:
        $$ EmuPortMode=SPP8
        $$ ProductId=10
      ** Checking emulator/eZdsp scan connection
      ** Emulator Test **
       $$ EmuPortMode=SPP8
       $$ ProductId=10
       ** Emulator Scan Test
      ERROR >> JTAG IR scan test failed
        >> Check power to your emulator/eZdsp
        >> Then check your port mode/address
      Thing is, I am not sure what is JTAG and I am currently using a printer cable to connect the board to the computer's parallel port. Anyone can help?
      Andrew
      Report Abuse
      • Reply
    • Mitja Nemec
      on Mar 14 2012 01:34 AM
      Genius4175 points
      Andrew,
      I am just guessing here but I assume you are using eZdsp2818 ? This board has the emulator already on board (Altera FPGA I think). I you have different setup you most probably have XDS510PP+ (not there is a difference if you are having "XDS501PP" or "XDS510PP+") and you are connecting to custom board with DSP.
      We can just assume that emulator/debuger is just a bus interface between JTAG bus and parallel bus.
      the sdconfig messages you are getting basically say that PC is able to connect to emulator/debuger, but the emulator/debugger is unable to connect to DSP. Either DSP has no supply, emulator/debugger does not detect the supply or DSP's JTAG interface does not work. If you have another board available try if it works there
      Regards, Mitja
      Report Abuse
      • Reply
    • julio justino
      Posted by julio justino
      on May 05 2012 14:59 PM
      Prodigy10 points
      I have the same problem here.  I can not connect the JTAG (XDS510pp) and the target (TMS320C2812). I have changed the JTAG, the board and reinstalled the drive, but none of then solved my problem.  It happened with 3 boards that were working well before.
      I have tried running with an eZdsp2812 and worked well. So I think the probIem is the target, but it is very strange that all boards stopped work at the same time, presenting the same error (error 1031).
      Has anyone got any sugestions about what is happening?
      Regards, Julio
      Report Abuse
      • Reply
    • Rafal Piotuch
      Posted by Rafal Piotuch
      on Jul 31 2012 12:48 PM
      Prodigy60 points
      Hi I have similar problem with eZdspf2812 board..
      When I try to connect using parallel port -  this occurs:
      Error 0x80000200/-2092
      Device driver: Emulation Connection Loss Detected on Target CPU.
      Sequence ID: 0
      Error Code: -2092
      I/O Port = 378
      Cpu Name: cpu_0
      Former the board was working correct, but after the voltage brake down, when I try to connect I get the message..
      It also stops me in further work :(
      RP
      Report Abuse
      • Reply
    • Mitja Nemec
      on Aug 01 2012 02:18 AM
      Genius4175 points
      Most likely you damaged your DSP and the only available solution is to replace it. It should be easy if you have eZdsp with socket.
      And this is as much as I can do to help.
      Regards, Mitja
      Report Abuse
      • Reply
    • Rafal Piotuch
      on Aug 01 2012 02:31 AM
      Prodigy60 points
      Thank You very much for your quick replay..
      I asked my Colleague about possible cause of a voltage breake down.. As it occured the short circuit was made with autotransformer --->DMC1500 --> eZdsp2812 -->PP (LPT) --> PC --> ground :(
      After the connection of power supply everything turned off.. And the residual current device was triggered :(
      So I think this was the cause of a problem.
      So I hope that the only thing that was damaged was the processor :(
      RP
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
