• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » RT-SineFIRFFT Example reports "Ethernet with uIP" instead of IP address
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • RT-SineFIRFFT Example reports "Ethernet with uIP" instead of IP address
    This question is answered
    Joseph Istre
    Posted by Joseph Istre
    on Apr 02 2012 20:37 PM
    Prodigy20 points
    I have had a lot of success compiling\using multiple TI examples for the Concerto Control card, and overall I am pretty impressed. However, the template example "RT-SineFIRFFT" is giving me trouble. The quick start guide says that when the code starts it will report the IP address it got assigned through DHCP. Then you are supposed to use that IP address when connecting to Concerto with the provided GUI. However, I do not ever get a IP address reported. After I start the m3 code, it will report on the serial port "Ethernet with uIP", but never the IP address.
    If I try the alternative method that the quick start guide recommends, which is to use a static IP address for Concerto and reconfigure my computer's TCP settings, then the GUI can never find the Concerto card.
    Solutions?
    controlCard Concerto RT_Sine_FIR_FFT "Ethernet with uIP"
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Trey German
      Posted by Trey German
      on Apr 19 2012 13:13 PM
      Verified Answer
      Verified by Joseph Istre
      Genius14510 points
      Hi Joseph,
      It sounds to me like you are running into an issue with the GEL files.  The GEL files setup the C28 core so that it can be run without being setup by the M3 in a debug environment, but this prevents the standard IPC boot procedure for the C28 from working.  If you remove the GEL file from the C28 side, your code should start running as intended.
      To remove the GEL file, select the C28 core in the debug window and go to Tools, GEL Files.  In the window that appears in the bottom, right click on the GEL file and select remove.  Reset the target, and try running the example again.
      Let me know if this works for you,
      Trey German
      Trey German
      C2000 Applications
      If a post answers your question, please mark it with the "verify answer" button.
      Visit these helpful C2000 Links!
      C2000 TI Wiki Pages
      TI Forum Sitemap
      ControlSUITE
      C2000 Getting Started
      CLA FAQs
      Workshop Material!
      Report Abuse
      • Reply
    • Joseph Istre
      on Apr 30 2012 15:24 PM
      Prodigy20 points
      Thanks Trey! That did the trick. Is there a particular reason that I need to both "Reset CPU" and "Restart" both M3 and C28 for this example to work. It seems overly complicated. In other words, is there a setting I need in CCS v5 to add so that all I have to do is "Build", "Load", and "Resume".
      Thanks again,
      Joe
      Report Abuse
      • Reply
    • Trey German
      on Apr 30 2012 16:12 PM
      Verified Answer
      Genius14510 points
      Joe,
      I suggest resetting and restarting because I know it works everytime that way.  I believe when you restart a reset is issued to the processor, but I'm unsure.
      While we could make a button that did everything for you, it would abstract away too much of what is going on behind the scenes and could potentially cause issues in end applications.  We've tried to give customers as much visibility into this product to make it easier to understand (not that that is really easy...).
      Trey
      Trey German
      C2000 Applications
      C2000 TI Wiki Pages
      TI Forum Sitemap
      ControlSUITE
      CLA FAQs
      Workshop Material!
      Report Abuse
      • Reply
    • Ron Budman
      Posted by Ron Budman
      on Sep 04 2012 02:30 AM
      Prodigy50 points
      I have the same problem, however removing the gel file did not help.
      also the demo gui does not connect to the card.
      ron.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
