• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » Concerto GPIO Problem
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • Concerto GPIO Problem
    This question is answered
    Joel Clasquin
    Posted by Joel Clasquin
    on Apr 25 2012 11:18 AM
    Intellectual400 points
    I'm trying to use GPIO128 through GPIO135 (names later changed to GPIO192 through GPIO199?), but I keep having problems with bit 1 of that port.  I can't clear that bit out of GPEDAT once it is set. See image below.  I just ran the line that set GPEDAT to 0x2 and that worked, and then I ran the line that should have made it 0x4, but instead, it is 0x6.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Joel Clasquin
      on Apr 25 2012 11:29 AM
      By the way, it seems likely that this type of problem is caused by incorrect configuration of the GPIO pins on the M3 side.  But I'm assuming that isn't the case since these GPIO pins appear to be controlled only by the C28.
      Report Abuse
      • Reply
    • Santosh Athuru
      Posted by Santosh Athuru
      on Apr 25 2012 13:04 PM
      Expert7330 points
      Joel,
      for GPIO128-135, Master subsystem doesn;t have to do any configuration. It is enough if it is out of reset. These GPIOs are controlled by Controlsubsystem only.
      I repeated the same steps as you did and I don't see the problem. Can you repeat the test after an XRSn? Also can you step through the assembly and make sure if your code is not getting optimized in a way you don't want it to be?
      One more thing you could try is directly write to the registers in a watch window or memory window and see if you can repeat the problem.
      Best Regards
      Santosh
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 25 2012 15:09 PM
      Thanks for the reply.
      I powered off my board, reset the emulator, exited CodeComposer, etc. and then ran the code again.  The problem was gone.  But then if I let it run the rest of my program, the problem comes back.  Bit 1 of GPEDAT is stuck on.
      At that point, if I do a software reset and reload the program, or just hit the "restart" button, when I get back to those same lines of code that I showed in my earlier post, writing a 1 to the data register causes it to be 3.  Writing 2 causes the data register to be 2.  Writing 4 to the data register causes it to be 6.
      Writing directly to the registers in the watch window doesn't work either.  If GPEDAT is 6 and I type in 0, the value becomes 2.  If I put a 2 in the GPECLEAR register nothing happens to GPEDAT.
      So I know something is happening when the rest of my program runs.  But I have no idea what my code could be doing to make this happen.  I know my program has a lot of IO reads and writes on these pins.  But how would that cause a bit to get stuck?
      Joel
      Report Abuse
      • Reply
    • Santosh Athuru
      on Apr 25 2012 16:46 PM
      Expert7330 points
      it could be that the IO is being accidentally configured back as input in your code, check the DIR register value for the IO at this point.
      see if you can send your main file....
      Best Regards
      Santosh
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 25 2012 17:12 PM
      I have learned that the only way to clear the "stuck bit" is to power off my board.  Hardware reset doesn't even work.
      I also tried a different piece of code.  I now have this in main()...
      void main(void)
          InitSysCtrl();
          IOWrite(1,1);
          IOWrite(1,2);
          IOWrite(1,4);
      And this is what the IOWrite function looks like....
      #pragma CODE_SECTION(IOWrite, "ramfuncs");
      void IOWrite(ulong Mask, ulong NewValue)
          int Temp;
          IO_DIR = 0xFF;
          if (Mask & 0x0000FF) {
              /* Put the 8 bits of data on the IO port pins */
              IO_PORT = NewValue & 0x0000FF;
              IO_WRITE = 1;
              ShortDelay
              IO_BANK0 = 1; /* Sends clock pulse to latch when IOWRITE and bank select are both true */
          ShortDelay /* Wait for latch */
          IO_WRITE = 0; /* Turn off all controls */
          ShortDelay
          IO_BANK0 = 0;
      Here are the defines used in the above code...
      #define ShortDelay  asm(" nop"); asm(" nop"); asm(" nop"); asm(" nop"); asm(" nop"); asm(" nop");
      #define IO_PORT GpioG2DataRegs.GPEDAT.all /* 8 bit I/O "data bus" is on group 2 GPIO pins (GPIO128 - GPIO135) */
      #define IO_DIR GpioG2CtrlRegs.GPEDIR.all /* If IO_DIR is set to one, the I/O port is for writing, 0 = reading */
      #define IO_BANK0 GpioG1DataRegs.GPADAT.bit.GPIO31 /* I/O port Bank 0 select (active high) is on PE7 (GPIO31) */
      #define IO_WRITE GpioG1DataRegs.GPBDAT.bit.GPIO35 /* = True to write to the 74HC273 selected by the bank selects above. PF3 (GPIO35) */
      NOTE:  The "ShortDelay" was added after I saw some strange behavior after successive writes to GPIO registers.  I added that delay a couple of weeks ago and thought I had fixed all the GPIO problems, but I guess not.
      When I run through main(), the first IOWrite() call makes GPEDAT = 1, the second call makes GPEDAT = 2, and the last one makes it 6 when it should be 4.  Keep in mind that the following worked instead of IOWrite function calls....
      GpioG2DataRegs.GPEDAT.all = 0x2;
      DELAY_US(100);
      GpioG2DataRegs.GPEDAT.all = 0x4;
       As for the DIR bits, I do have a function that reads these IO pins, so I commented it out to make sure the DIR bits never change.  That didn't help.  Also, when the bit in GPEDAT was "stuck" I went to the watch window and verified the DIR bits were still 0xFF.  They were.  Then I tried changing the value of the DIR register to 0 and then back to 0xFF.  The values changed correctly, but had no affect on GPEDAT being stuck.
      Report Abuse
      • Reply
    • Santosh Athuru
      on Apr 25 2012 18:10 PM
      Expert7330 points
      Joel,
      What do you mean by below? if you use the highlighted portion below instead of the IOWrite calls, it works?
      Joel Clasquin
      DELAY_US(100);
      are you running the test on Control card?
      Best Regards
      santosh
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 26 2012 08:53 AM
      Santosh,
      That's correct.  My code looks like this...
      //#pragma CODE_SECTION(main, "ramfuncs");
      void main(void)
      InitSysCtrl();
      IOWrite(1,1);
      IOWrite(1,2);
      IOWrite(1,4);
      GpioG2DataRegs.GPEDAT.all = 0x1;
      DELAY_US(100);
      DELAY_US(100);
      First, I commented out the three IOWrite calls and stepped through the rest of the lines.  GPEDAT changed to 1, 2, and then 4.
      Then I un-commented the IOWrite calls and stepped through.  GPEDAT changed to 1, 2, and then 6.
      This is not a ControlCard.  This is my board.
      A few notes: I've tried to two different prototype boards and they both do the same thing.  I've tried two different emulators (one is an XDS510 and the other is XDS100).  I powered off the board between the two tests mentioned above and restarted everything the same way, with one exception.  When I commented out the IOWrite function I had to manually type 0xFF into the GPEDIR register since that only happens in the IOWrite function.
      I'm really stuck.  Your help is appreciated.
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 26 2012 11:33 AM
      FYI - I just realized that I didn't have EALLOW before writing IO_DIR = 0xFF in the IOWrite function.
      Unfortunately, adding that didn't fix the problem.
      Report Abuse
      • Reply
    • Santosh Athuru
      on Apr 26 2012 12:34 PM
      Expert7330 points
      Joel,
      are you setting IODIR for GPIO35 and GPIO31 anywhere in your  code? I see that your are toggling them in your IO_WRITE and IO_BANK0 macros?
      can you do a quick test for me on your board?
      in your main....shown below, comment out the highlighted functions and add lines shown in green
      void main(void)
      InitSysCtrl();
      IOWrite(1,1);
      IOWrite(1,2);
      IOWrite(1,4);
      GpioG1DataRegs.GPADAT.bit.GPIO31 = 1
      ShortDelay
      GpioG1DataRegs.GPBDAT.bit.GPIO35  = 1
      ShortDelay
      GpioG1DataRegs.GPADAT.bit.GPIO31 = 0
      ShortDelay
      GpioG1DataRegs.GPBDAT.bit.GPIO35  = 0
      ShortDelay
      DELAY_US(100);
      DELAY_US(100);
      after you do the above, if your problem comes back...see which one is causing the error, GPIO35 or GPIO31.
      Best Regards
      Santosh
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 26 2012 14:22 PM
      Thanks for sticking with this.
      I think we're on the right track.  I added the code as you suggested.  GPIO35 is definitely the problem.
      Yes, I am setting the DIR for GPIO35 and GPIO31.  The InitSysCtrl function calls InitGPIO.  Here's that function...
      void InitGPIO()
      EALLOW;
      // Configure GPIO pins to function as such
      GpioG2CtrlRegs.GPEMUX1.all = 0x0000; // GPIO functionality GPIO128-135 (I/O port "data bus")
      GpioG2CtrlRegs.GPEDIR.all = 0; // Set the direction of the data bus to "read" initiially. This will change when reading or writing.
      GpioG1CtrlRegs.GPAMUX2.bit.GPIO29 = 0; // GPIO29 and 30 are for analog mux channel selection
      GpioG1CtrlRegs.GPAMUX2.bit.GPIO30 = 0;
      GpioG1CtrlRegs.GPAMUX2.bit.GPIO31 = 0; // GPIO31 - 33 are I/O bank select bits
      GpioG1CtrlRegs.GPBMUX1.bit.GPIO32 = 0;
      GpioG1CtrlRegs.GPBMUX1.bit.GPIO33 = 0;
      GpioG1CtrlRegs.GPBMUX1.bit.GPIO34 = 0; // GPIO34 is IO_WRITE
      GpioG1CtrlRegs.GPBMUX1.bit.GPIO35 = 0; // GPIO35 is IO_READ
      GpioG1CtrlRegs.GPADIR.bit.GPIO29 = 1; // All I/O bus control signals are write, not read.
      GpioG1CtrlRegs.GPADIR.bit.GPIO30 = 1;
      GpioG1CtrlRegs.GPADIR.bit.GPIO31 = 1;
      GpioG1CtrlRegs.GPBDIR.bit.GPIO32 = 1;
      GpioG1CtrlRegs.GPBDIR.bit.GPIO33 = 1;
      GpioG1CtrlRegs.GPBDIR.bit.GPIO34 = 1;
      GpioG1CtrlRegs.GPBDIR.bit.GPIO35 = 1;
      GpioG1DataRegs.GPADAT.all = 0;
      GpioG1DataRegs.GPBDAT.all = 0; // Disable all the mux select bits
      EDIS;
      When I run this line of code...
      The GPBDAT register changes, but so does the GPEDAT register.  See attached screen shot.
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 26 2012 14:56 PM
      FYI - I changed the offending line of code a little bit.  Everything works OK if I set GPIO35 using GPBSET.
      Changed this line....
      GpioG1DataRegs.GPBDAT.bit.GPIO35 = 1;   // This did NOT work
      To this line....
      GpioG1DataRegs.GPBSET.bit.GPIO35;    // This does work
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 26 2012 16:04 PM
      Actually, it doesn't quite work.  GPBSET doesn't cause a problem with GPEDAT, but also doesn't actually set the bit in GPBDAT.  It seems to do nothing.
      Report Abuse
      • Reply
    • Santosh Athuru
      on Apr 26 2012 17:39 PM
      Expert7330 points
      Joel,
      Now when you are using GPIO0 to GPIO63 on your control subsystem, you should take care of assigning them to C28x subsytem from M3. Master subsytem owns these GPIO by default, they have to be switch to Control subsytem by using respective CSEL register.
      Please let me know if you are doing that, ahead of using GPIO35 in your C28x code.
      Best Regards
      Santosh
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 27 2012 09:27 AM
      Santosh,
      I do switch control to the C28.  I have tried three different methods in the M3 code.  The first line below is what I originally had.  It should switch GPIO35 to the C28 core, right?
      The second line is an attempt to switch the entire port.  That didn't help.
      The third method was copied from some example code I found.  That didn't help.
      When I run the M3 program and then look at GPIO_PORTF - GPIOCSEL register in the watch window, it is equal to 0xFF.
      //GPIOPinConfigureCoreSelect(GPIO_PORTF_BASE, 0x4F, GPIO_PIN_C_CORE_SELECT); // Pins 0, 1, 2, 3 and 6.
      //GPIOPinConfigureCoreSelect(GPIO_PORTF_BASE, 0xFF, GPIO_PIN_C_CORE_SELECT);
      HWREG(GPIO_PORTF_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY_DD;
      HWREG(GPIO_PORTF_BASE + GPIO_O_CR) |= 0x0000FF;
      for (i=0; i<20; i++){}
      HWREG(GPIO_PORTF_BASE+ GPIO_O_CSEL) = 0xFF;
      Report Abuse
      • Reply
    • Joel Clasquin
      on Apr 27 2012 10:42 AM
      Santosh,
      I just realized a mistake I made when I started using the GPBSET register.  I simply wasn't setting it equal to 1.  Now the following line of code does work...
      GpioG1DataRegs.GPBSET.bit.GPIO35 = 1;
      So, it seems like the only problem is that I can't use this...
      That line still appears to corrupt the GPEDAT register.
      But at least I have a workaround.
      Thanks a lot,
      Joel
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
