• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » "IsrTicker" does not increase
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • "IsrTicker" does not increase
    This question is not answered
    Yang Hu1
    Posted by Yang Hu1
    on May 01 2012 14:36 PM
    Prodigy30 points
    I am now working on the kit "TMDS2MTRPFCKIT", which has a Piccolo F28035 control CARD
    I followed the guide to build and test the kit incrementally. However on the first level, I connected the board and in debug mode, enabled real time, and then change the "EnableFlag" to 1. then the IsrTicker should increase to show that the system interrupt is working properlly.
    The codes I use comes with the control suite, I suppose they are correctly written
    But after I change the "EnableFlag" to 1, the "IsrTicker" does not increase. It seems everything is static and not changing. (the monitored variable shows a constant 0 instead of a sinusoidal waveform)
    I just started working on the MCUs, and really unfamiliar with the hardware. Can anyone give some hint on how to debug and find out where is wrong, and how to check why the interrupt is working?
    Piccolo F28035 interrupt IsrTicker Motor
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Kris Parrent
      Posted by Kris Parrent
      on May 02 2012 09:52 AM
      Expert5985 points
      You may want to try running the code in non-real time mode, and then while the code is still running, enable real time mode.  You also need to make sure to set each window in the debug perspective which will use real time mode on continuous refresh to see the values update.
      Kris
      Report Abuse
      • Reply
    • Jared Allen
      Posted by Jared Allen
      on May 31 2012 12:30 PM
      Intellectual440 points
      I am in a similar predicament.  I have switched between non-real time and real time mode while the debugger is running, and each window is set to continuously refresh.  Still no dice.  However, my system is slightly different.
      CCS version 5.2
      DRV8302 evaluation board with TMS320F28035PNT controlCARD
      I just loaded up the InstaSPIN project and followed the "DRV830x-HC-C2-KIT" How to Run Guide, although I had to deviate from the instructions at times due to the instructions being written for CCS version 4.  Any assistance is greatly appreciated.
      **update** - I can see that the registers are updating via the Registers window, but nothing in the Expression window changes, which includes the IsrTicker.  LD3 on the controlCARD is blinking steadily.
      -Jared
      ccsv5
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
