• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » Concerto F23M35H52C USB Peripheral
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • Concerto F23M35H52C USB Peripheral
    This question is answered
    Miro Petrovic
    Posted by Miro Petrovic
    on May 06 2012 07:28 AM
    Prodigy210 points
    I had a problem with ControlSuite V120 usb_host_msc - mass storage project on Concerto evaluation board. Program displayed NODEV> prompt  with memory stick connected. I changed the card with new one and same thing happened. As I had in the past the same problem with Stellaris LM3S9B92 evaluation board I put USB0ID to GND and program started working. Does it mean that on F23M35H52C there is the same problem as on LM3S9B92 Rev. B? Does it mean that I can't use freely USB0VBUS and USB0ID pin  in host mode for other functions?
    Miro
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Trey German
      Posted by Trey German
      on May 09 2012 08:39 AM
      Suggested Answer
      Genius14510 points
      Miro,
      There are some known issues with regards to USB on Concerto.  Specifically the VBUS and ID pins have an issue with clamping to the supply rails.  Please check out the silicon errata for this device.  That being said the example should still work.
      Try updating your controlsuite and using the v130 device support files.  I personally released these files and tested the USB examples last week and they were in fact working.
      Trey
      Trey German
      C2000 Applications
      If a post answers your question, please mark it with the "verify answer" button.
      Visit these helpful C2000 Links!
      C2000 TI Wiki Pages
      TI Forum Sitemap
      ControlSUITE
      C2000 Getting Started
      CLA FAQs
      Workshop Material!
      Report Abuse
      • Reply
    • Miro Petrovic
      on May 12 2012 10:46 AM
      Prodigy210 points
      I tested example with v130 device support files.( In usb_host_msc example there is no difference beetwen v120 and v130 usb_host_msc.c and startup_ccs files). The result was the same as with v120 - usb_host_msc project. It starts working only if I connect USB0ID to GND. This could be explained if the USB0ID pin has an issue with clamping to supply rails as you suggested me in your answer or that I've bad lack and 2 concerto boards with GPIO46 pin damaged. I didn't  find USB0ID clamping issue in Concerto errata. It's written that only VBUS pin has an issue. Let's speak now about VBUS pin clamping to supply rails issue. Does it mean that I can't use this pin as PF6_GPIO38 input/output or we have a problem only in case  VBUS is selected as alternate function on that pin.
      Miro
      Concerto
      Report Abuse
      • Reply
    • Trey German
      on May 14 2012 07:44 AM
      Genius14510 points
      Both VBUS and ID have the same problem.  I believe the IO's still work if USB is not in use.  They are still partially functional, but this clamping issue can prevent propper operation if OTG is attempted.
      Trey
      Trey German
      C2000 Applications
      C2000 TI Wiki Pages
      TI Forum Sitemap
      ControlSUITE
      CLA FAQs
      Workshop Material!
      Report Abuse
      • Reply
    • Miro Petrovic
      on May 18 2012 11:49 AM
      Verified Answer
      Verified by Miro Petrovic
      Prodigy210 points
       I've tested VBUS and ID pins as general purpose outputs while serving USB memory stick and everything is working correctly. So for me this argument is closed.
      Miro
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
