• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » [F28027] SOCFRC causes fail during ADC offset self cal
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • [F28027] SOCFRC causes fail during ADC offset self cal
    This question is not answered
    Toby Mole
    Posted by Toby Mole
    on May 16 2012 08:05 AM
    Expert1670 points
    Hi
    I have copied the adcOffsetSelfCal() and its dependent functions from the piccolo example files and is called when I set up the ADCs for use after device initialisation and before my main loop starts.
    However in the function adcConversion() the SOC 0-7 are initially forced to start the "ping-pong" sampling, and in my code this causes a ISR_ILLEGAL interrupt to be raised. I dont understand why.
    If I set it so the while() that comes after the force only runs once it seems to run OK, but if I comment out the force, the while runs OK... adcConversion() is below
    static Uint16 adcConversion(void) {
    	// This function initiates several ADC conversions and returns the average. It uses ADCINT1 and ADCINT2
    	//  to "ping-pong" between SOC0-7 and SOC8-15 and is referred to as "ping-pong" sampling
    	//  * IMPORTANT * This function will overwrite previous ADC settings
        Uint16 index;
        Uint16 sampleSize;
        Uint16 mean;
        Uint16 AcqpsVal;
        Uint16 i;
        Uint32 sum;
        index = 0;			// Initialize index to 0
        sampleSize = 256;	// Set sample size to 256 (**NOTE: Sample size must be multiples of 2^x where is an integer >= 4)
        sum = 0;			// Set sum to 0
        mean = 999;			// Initialize mean to known value
        AcqpsVal = 6;		// Set the ADC sample window to the desired value (Sample window = ACQPS + 1)
        AdcRegs.ADCSOC0CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC1CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC2CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC3CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC4CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC5CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC6CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC7CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC8CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC9CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC10CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC11CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC12CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC13CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC14CTL.bit.ACQPS = AcqpsVal;
        AdcRegs.ADCSOC15CTL.bit.ACQPS = AcqpsVal;
    										// Enable ping-pong sampling
        AdcRegs.INTSEL1N2.bit.INT1E = 1;	// Enabled ADCINT1 and ADCINT2
        AdcRegs.INTSEL1N2.bit.INT2E = 1;
        AdcRegs.INTSEL1N2.bit.INT1CONT = 0;	// Disable continuous sampling for ADCINT1 and ADCINT2
        AdcRegs.INTSEL1N2.bit.INT2CONT = 0;
        AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1;//ADCINTs trigger at end of conversion
    										// Setup ADCINT1 and ADCINT2 trigger source
        AdcRegs.INTSEL1N2.bit.INT1SEL = 6;	// EOC6 triggers ADCINT1
        AdcRegs.INTSEL1N2.bit.INT2SEL = 14;	// EOC14 triggers ADCINT2
    										// Setup each SOC's ADCINT trigger source
        AdcRegs.ADCINTSOCSEL1.bit.SOC0 = 2;	// ADCINT2 starts SOC0-7
        AdcRegs.ADCINTSOCSEL1.bit.SOC1 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC2 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC3 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC4 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC5 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC6 = 2;
        AdcRegs.ADCINTSOCSEL1.bit.SOC7 = 2;
        AdcRegs.ADCINTSOCSEL2.bit.SOC8 = 1;	// ADCINT1 starts SOC8-15
        AdcRegs.ADCINTSOCSEL2.bit.SOC9 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC10 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC11 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC12 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC13 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC14 = 1;
        AdcRegs.ADCINTSOCSEL2.bit.SOC15 = 1;
    	DELAY_US(1000);						// Delay 1ms before converting ADC channels
    	//ADC Conversion
    	AdcRegs.ADCSOCFRC1.all = 0x00FF;	// Force Start SOC0-7 to begin ping-pong sampling
    	while( index < sampleSize ){
    		while (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0){}	// Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum
    		AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;			// Must clear ADCINT1 flag since INT1CONT = 0
    		sum += AdcResult.ADCRESULT0;
            sum += AdcResult.ADCRESULT1;
            sum += AdcResult.ADCRESULT2;
            sum += AdcResult.ADCRESULT3;
            sum += AdcResult.ADCRESULT4;
            sum += AdcResult.ADCRESULT5;
            sum += AdcResult.ADCRESULT6;
            sum += AdcResult.ADCRESULT7;
    		while (AdcRegs.ADCINTFLG.bit.ADCINT2 == 0){}	// Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum
            AdcRegs.ADCINTFLGCLR.bit.ADCINT2 = 1;			// Must clear ADCINT2 flag since INT2CONT = 0
    		sum += AdcResult.ADCRESULT8;
            sum += AdcResult.ADCRESULT9;
            sum += AdcResult.ADCRESULT10;
            sum += AdcResult.ADCRESULT11;
            sum += AdcResult.ADCRESULT12;
            sum += AdcResult.ADCRESULT13;
            sum += AdcResult.ADCRESULT14;
    		sum += AdcResult.ADCRESULT15;
    		index+=16;
        AdcRegs.INTSEL1N2.bit.INT1E = 0;	// Disable ADCINT1 and ADCINT2 to STOP the ping-pong sampling
        AdcRegs.INTSEL1N2.bit.INT2E = 0;
        mean = sum / sampleSize;			// Calculate average ADC sample value
        return mean;
    Piccolo F28027 CCSv4 controlSTICK f2802x
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Devin Cottier
      Posted by Devin Cottier
      on May 16 2012 09:27 AM
      Expert7155 points
      Looking over the code, everything looks fine.  Are you sure that the EALLOW bit is set before this function is called?  The INTSEL1N2 registers are EALLOW protected (as are some of the other registers being accessed in the function).
      I didn't follow how calling the adcOffsetSelfCal() related to your issue.  Did the issue begin after you put the function call in your code?
      Report Abuse
      • Reply
    • Toby Mole
      Posted by Toby Mole
      on May 16 2012 09:58 AM
      Expert1670 points
      Hi Devin
      Thanks for your response. My adcInit() calls adcOffsetSelfCal() which itself calls two functions adcChanSelect() and adcConversion, the 3 of which are direct from the example files. The issue began after I started trying to call adcOffsetCal() from my adcInit()
      Though I did have problems with my multiple EDIS; being called (thanks for mentioning that) this doesnt seem to have solved the problem.
      I have noticed that If I comment out the CPU enabling of the interrupt generated by the EOC of my regular ADC readings (i.e. at the end of adcInit()) then the ISR_ILLEGAL is not raised... however this leaves me with no interrupt for my actual ADC results... So I guess i must have some error with my interrupt occurring?
      Below I have included my adcInit(), adcOffsetSelfCal() and adcChanSelect() functions:
      void adcInit(void) {
      	// Setup ADC A1, B1 & B2 to be triggerd by at 10kHz PWM3B
      	// ADCs use round robin, so ADC B2 is last and when it's
      	// finished it triggers ADC interrupt 1 (ADCINT1)
          EALLOW;
      	AdcRegs.ADCCTL1.bit.ADCREFSEL = 0;	// Use internal bandgap
      	AdcRegs.ADCCTL1.bit.ADCBGPWD = 1;	// Power up band gap
      	AdcRegs.ADCCTL1.bit.ADCPWDN = 1;	// Power up rest of ADC
      	AdcRegs.ADCCTL1.bit.ADCREFPWD = 1;	// Power up reference
      	AdcRegs.ADCCTL1.bit.ADCENABLE = 1;	// Enable ADC
      	DELAY_US(1000);						// Wait 1ms for ADC to power on
      	adcOffsetSelfCal();					// Calibrate ADC zero offset
      	AdcRegs.ADCCTL1.bit.INTPULSEPOS	= 1;// Create interrupt pulses 1 cycle prior to result output latch
      										// SOC0 must be read then discarded as part of workaround for first sample errata
      	AdcRegs.ADCSOC0CTL.bit.CHSEL = 9;	// Convert ADC-B1 (CH1) when SOC0 is recieved
      	AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 9;	// Set SOC0 to be triggered by ADCTRIG9 (ePWM3, ADCSOCA),
      										//  due to round robin, this will be first conversion
      	AdcRegs.ADCSOC0CTL.bit.ACQPS = 6;	// Set SOC0 S/H window to 7 ADC clk cycles (6 ACQPS plus 1)
      	AdcRegs.ADCSOC1CTL.bit.CHSEL = 9;	// Convert ADC-B1 (CH1) (I_pk) when SOC1 is recieved
      	AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 9;	// Set SOC1 to be triggered by ADCTRIG9 (ePWM3, ADCSOCA),
      										//  due to round robin, this will be second conversion
      	AdcRegs.ADCSOC1CTL.bit.ACQPS = 6;	// Set SOC1 S/H window to 6 clk cycles (117ns)
      	AdcRegs.ADCSOC2CTL.bit.CHSEL = 10;	// Convert ADC-B2 (CH2) (V_dc) when SOC2 is recieved
      	AdcRegs.ADCSOC2CTL.bit.TRIGSEL = 9;	// Set SOC2 to be triggered by ADCTRIG9 (ePWM3, ADCSOCA),
      										//  due to round robin, this will be third conversion
      	AdcRegs.ADCSOC2CTL.bit.ACQPS = 6;	// Set SOC2 S/H window to 6 clk cycles (117ns)
      	AdcRegs.INTSEL1N2.bit.INT1SEL = 2;	// EOC2 causes ADCINT1
      	AdcRegs.INTSEL1N2.bit.INT1E = 1;	// Enable ADC interrupt 1
      	PieVectTable.ADCINT1 = &adc_isr;	// Map ADCINT 1 to ADC ISR
      	EDIS;
      	AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;// Clear ADCINT1 flag
      	setPwm(&EPwm3Regs, 10000, 0, 0);	// Set ePWM3 time-base to 10 kHz
      										// Set ePWM3B event trigger to ADCTRIG9 (ADCSOCA)
      	EPwm3Regs.ETSEL.bit.SOCAEN = 1;		// Enable SOC on A group
      	EPwm3Regs.ETSEL.bit.SOCASEL = 1;	// Select SOC from ZRO
      	EPwm3Regs.ETPS.bit.SOCAPRD = 1;		// Generate pulse on first event
      	PieCtrlRegs.PIECTRL.bit.ENPIE = 1;	// Enable the PIE block
      	PieCtrlRegs.PIEIER10.bit.INTx1 = 1;	// Enable PIE Group 10 - INT1
      	IER |= M_INT10;						// Enable CPU INT1
      void adcOffsetSelfCal(void) {
         // This function re-calibrates the ADC zero offset error by converting the VREFLO reference with
         //  the ADC and modifying the ADCOFFTRIM register. VREFLO is sampled by the ADC using an internal
         //  MUX select which connects VREFLO to A5 without sacrificing an external ADC pin.
          Uint16 AdcConvMean;
          //EALLOW;
          AdcRegs.ADCCTL1.bit.ADCREFSEL = 0;					//Select internal reference mode
          AdcRegs.ADCCTL1.bit.VREFLOCONV = 1;					//Select VREFLO internal connection on B5
          adcChanSelect(13);									//Select channel B5 for all SOC
          AdcRegs.ADCOFFTRIM.bit.OFFTRIM = 80;				//Apply artificial offset (+80) to account for a negative offset that may reside in the ADC core
          AdcConvMean = adcConversion();						//Capture ADC conversion on VREFLO
          AdcRegs.ADCOFFTRIM.bit.OFFTRIM = 80 - AdcConvMean;	//Set offtrim register with new value (i.e remove artical offset (+80) and create a two's compliment of the offset error)
          AdcRegs.ADCCTL1.bit.VREFLOCONV = 0;					//Select external ADCIN5 input pin on B5
          //EDIS;
      static void adcChanSelect(Uint16 chNo) {
      	// This function selects the ADC channel to convert by setting all SOC channel selects to a single channel.
      	//  * IMPORTANT * This function will overwrite previous SOC channel select settings
          AdcRegs.ADCSOC0CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC1CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC2CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC3CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC4CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC5CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC6CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC7CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC8CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC9CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC10CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC11CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC12CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC13CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC14CTL.bit.CHSEL = chNo;
          AdcRegs.ADCSOC15CTL.bit.CHSEL = chNo;
      Report Abuse
      • Reply
    • Toby Mole
      Posted by Toby Mole
      on May 17 2012 04:26 AM
      Expert1670 points
      If I power down the ADC core  and then power it up again after the self cal and before the ADC is setup for normal use then there appears to be no errors.
      However, having added all ADC registers to the watch window there appears to be no difference between Initialising with the self cal or without other than the ADCBUSYCHAN bits in ADCCTL1... these just indicate that some channel has been converted (in the selfCAL()) and dont actually indicate that anything further needs to happen right?
      Ta
      Report Abuse
      • Reply
    • Devin Cottier
      on May 18 2012 14:08 PM
      Expert7155 points
      I don't think you want to have the (PIE) Interrupt enabled while you run the self calibration function?  The ping-pong sampling contained inside the function does not use the PIE or ISR and it keeps the ADC busy.  I think you want to disable the PIE ADC ISR, call the self cal, then re-enable?
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
