• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » FLASH in Concerto devices, ARM part
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • InstaSPIN Simulation Tool
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • FLASH in Concerto devices, ARM part
    This question is answered
    Walter Saegesser
    Posted by Walter Saegesser
    on Jun 11 2012 04:46 AM
    Prodigy140 points
    The Stellaris Cortex-M3 devices have Flash that can be erased per 1kB block and written to by an API function from any code. Is this still the case with the Cortex-M3 part of a Concerto device, e.g. F28M35H52C1? Or is it strictly sectored as in the C2000 series and can only be erased and programmed from functions running in RAM?
    Does the Ethernet BootP protocol also work for first-time-programming or is the Ethernet boot-mode only used to load a loader application to RAM?
    Walter
    Concerto
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Santosh Athuru
      Posted by Santosh Athuru
      on Jun 11 2012 10:57 AM
      Verified Answer
      Verified by Walter Saegesser
      Expert7660 points
      Walter,
      I can answer the second question. I'll let someone else from the team answer the first one or you can open a new thread after closing this one for the first one alone.
      Walter Saegesser
      All boot modes on Concerto as of today support downloading application to RAM. Boot loaders on Concerto doesn;t suppport flash programming, customers have to write their own loader that does the flash programming using the flash programming API.
      Best Regards
      Santosh
      Report Abuse
      • Reply
    • Vamsi Gudivada
      Posted by Vamsi Gudivada
      on Jun 11 2012 16:52 PM
      Verified Answer
      Intellectual2935 points
      Walter,
      Sizes of the sectors of F28M35x Flash is given in datasheet.  Please refer to datasheet.
      F28M35x Flash is divided in to sectors of sizes 16K and 64K.
      F021 Flash API can be executed only from RAM.
      Thanks and regards,
      Vamsi
      Report Abuse
      • Reply
    • Walter Saegesser
      on Jun 11 2012 23:48 PM
      Verified Answer
      Prodigy140 points
      Thanks, Santosh and Vamsi, for your answers.
      In the meantime I have hunted out the Flash API document. I found a note there (page 10):
      The F021 Flash API library cannot be executed from the same bank as the active bank selected for the
       API commands to operate on. On single bank devices, the F021 Flash API must be executed from RAM.
       As the Concerto has two independent Flash banks, I conclude that the Master should be able to program the Control from Flash and vice versa. The API  function "Fapi_setActiveFlashBank()" seems to be applicable to Concerto. Am I wrong with this assumption?
      Walter
      Report Abuse
      • Reply
    • Vamsi Gudivada
      on Jun 12 2012 10:23 AM
      Verified Answer
      Walter,
      In F28M35x, Master subsystem Flash bank is accessible only to Master core M3 and Control subsystem Flash bank is accessible only to Slave C28x core.
      Master can not program/erase C28x Flash bank and C28x core can not program/erase M3 Flash bank.
      Hence for F28M35x devices, I mentioned in earlier post that Flash API should be executed from RAM.
      Thanks and regards,
      Vamsi
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
