• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » PWM chopper
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • PWM chopper
    PWM chopper
    This question is not answered
    Prathamesh dhanpalwar
    Posted by Prathamesh dhanpalwar
    on Aug 07 2012 06:16 AM
    Intellectual410 points
        I have tried to look for PWM chopper module example project in control suite, but couldnt find any. Can anyone let me know how can I get better understanding of it. I need to generate 7 pwms with a gap before the next 7 pwms.
    Regards-
    pwm 100% dutycycle PWM issue 100% PWM problem 100% PWM duty_cycle 100% duty cycle CHOPPER pwm chopper
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Kris Parrent
      Posted by Kris Parrent
      on Aug 07 2012 10:49 AM
      Expert5985 points
      What device are you using?
      Report Abuse
      • Reply
    • Prathamesh dhanpalwar
      on Aug 07 2012 13:15 PM
      F28069 experimenter's kit....
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 07 2012 13:47 PM
      Expert5985 points
      Unfortunately, we do not have any examples in controlSUITE for this device as you mentioned.  Have you looked over the PWM Chopper section of the PWM User's Guide?  It is 3 pages (283-286) available here: http://www.ti.com/lit/ug/spruh18c/spruh18c.pdf
      If you poke around with the chopper registers I think you will find it is a relatively simple submodule.  Specifically, you will want to play with the CHPFREQ and CHPDUTY bits in PCCTL.
      Kris
      Report Abuse
      • Reply
      on Aug 07 2012 14:28 PM
      Yes, I have gone through it and tried my hands on it. But that didnt help much and therefore I tried searching for an example. The submodule description in the piccolo reference is quite insufficient for clear understanding.
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 07 2012 14:34 PM
      Expert5985 points
      Can you post the code you have so far and a detailed description of what you are trying to do?  For example, I believe you said you wanted 7 pulses.  What frequency / duty cycle are you looking for?  Is the first pulse the same width as the following pulses?
      Kris
      Report Abuse
      • Reply
      on Aug 07 2012 15:21 PM
      Intan_RHA2000-EVAL_datasheet.pdf
      I am trying to interface an analog front end(16 channels) for EMG recordings out of which I want to access 1st 8 channels and it is through SPI protocol and I need to have 3 pwms for this operation. Step, which tells the analog front end to go to next channel(for mux), reset(active low) that tells the chip to start from 1st channel again and convert signal, which tells the ADC to start the conversion.
      I am at home now and will send you the code tomorrow when I reach office. By the way, what I am doing now is my reset signal is having 4KHz freq(TPRD = 10000) and step signal is  having 32KHz and CNV signal is same but inverted. But I dont want the step to be continuous train of pulse. I must have a gap after 7 pulses after which reset is used. You can get a better idea by having a look at the attachment (page 10).
      Regards-
      Report Abuse
      • Reply
      on Aug 08 2012 02:11 AM
      void InitEPwm1Reset()
      // Setup TBCLK
      EPwm1Regs.TBPRD = 10000; // Set timer period 801 TBCLKs
      EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
      EPwm1Regs.TBCTR = 0x0000; // Clear counter
      // Set Compare values
      EPwm1Regs.CMPA.half.CMPA = 1250; // Set compare A value
      EPwm1Regs.CMPB = 125; // Set Compare B value
      // Setup counter mode
      EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up/down
      EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
      EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
      EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
      // Set actions
      EPwm1Regs.AQCTLA.bit.CBU = AQ_CLEAR; // clear PWM1A on event B, up count
      EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; // set PWM1A on event A, up count
      void InitEPwm2Cnv()
      // Setup TBCLK
      EPwm2Regs.TBPRD = 1250; // Set timer period 801 TBCLKs
      EPwm2Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
      EPwm2Regs.TBCTR = 0x0000; // Clear counter
      EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up/down
      EPwm2Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
      EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
      EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;
      // Set actions
      EPwm2Regs.AQCTLA.bit.ZRO = AQ_CLEAR; // Clear PWM2A on event zero
      EPwm2Regs.AQCTLA.bit.PRD = AQ_SET; // Set PWM2A on period
      void InitEPwm3Step(void)
      // Setup TBCLK
      EPwm3Regs.TBPRD = 1250; // Set timer period
      EPwm3Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
      EPwm3Regs.TBCTR = 0x0000; // Clear counter
      EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;// Count up/down
      EPwm3Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
      EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
      EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
      // Set Actions
      EPwm3Regs.AQCTLA.bit.ZRO = AQ_SET; // Set PWM3A on zero
      EPwm3Regs.AQCTLA.bit.PRD = AQ_CLEAR; // Clear PWM3A on period
      // Interrupt where we will receive data from the ADC
      EPwm3Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
      EPwm3Regs.ETSEL.bit.INTEN = 1; // Enable INT
      EPwm3Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 1st event
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 08 2012 09:04 AM
      Expert5985 points
      Thank you for the information.  Please allow me some time to review it.  I will get back to you by the end of the week.
      Kris
      Report Abuse
      • Reply
      on Aug 08 2012 09:14 AM
      Ok Kris. Thank you.
      Regards-
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 08 2012 14:22 PM
      Expert5985 points
      If you have a GPIO (one with a TZ option on it) to spare, I think using a CBC trip is really a better solution for this.  You would just externally connect the reset PWM output to this and set each of the step and CNV waveforms to be forced low on a CBC trip action.  I think we could make the chopper work sufficiently, but using the trip function makes this a true active low reset function.  Let me know your thoughts.
      Kris
      Report Abuse
      • Reply
      on Aug 09 2012 02:57 AM
      Actually, I cannot figure out how CBC(TZ) will solve the purpose or in other words, how can I make use of it. Can you let me know how?
      Regards-
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 09 2012 09:25 AM
      Expert5985 points
      Sure,
      So what we would do in this case is configure your step signal to generate the proper frequency and duty cycle, not worrying about blanking out the 8th pulse (the trip will take care of this).  We set the other PWM channel to be complimentary of the generated STEP signal for the CNV signal.  So for simplicity let's say STEP is on PWM2A and CNV is on PWM2B.
      Now let's take PWM1A and generate the reset signal.  We would set this up to operate at a 87.5% duty cycle (87.5 = 7/8 since it is only low for 1 pulse out of 8) at whatever frequency gave the low pulse the desired width (the same width as your step/cnv pulses).  Now if we tie the output of this PWM to a TZ and configure PWM2A and PWM2B outputs to always be forced low while the trip is active, this will automatically blank out the 8th pulse for you.  The CBC trip works such that the condition is evaluated every TBCLK- so as long as PWM1A is low, the outputs of PWM2A and PWM2B will stay low.  When the condition clears the PWM2A/B outputs will continue as normal.  I think this will give you more control over your outputs than the chopper would.  For example, if you want to stop transmitting now you can just set the PWM1A output low and the other 2 signals are automatically stopped until you resume operation.
      Kris
      Report Abuse
      • Reply
      on Aug 10 2012 07:32 AM
      Hello Kris,
         Let me summarize to let you know if I understood you correctly. So, the trip signal is the reset (when low), and the TZCTL(TZA and TZB) registers must be used to set the action when the trip signal is encountered. I have never worked with this before, so will give it a try and let you know. By the way, what did you mean by saying -
      '' We would set this up to operate at a 87.5% duty cycle (87.5 = 7/8 since it is only low for 1 pulse out of 8) at whatever frequency gave the low pulse the desired width (the same width as your step/cnv pulses).  Now if we tie the output of this PWM to a TZ ''.
      Regards-
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 10 2012 13:15 PM
      Expert5985 points
      Correct, PWM2A and PWM2B (or whichever PWMs you decide to use for the STEP / CNV) signal would use the TZ submodule to force the outputs low while the reset signal is low.
      The RESET signal will be generated by another PWM.  From the waveform, it looked like the RESET low pulse was the same width as the high pulses on STEP / CNV.  I'm not sure if this is a requirement by your application or not.  If it's not, you can ignore that statement.  Basically, I was wanting to run the RESET PWM at a slower frequency so that you wouldn't have to modify the registers inbetween periods.  So essentially, 1/8 of the period on the RESET PWM (the low pulse) would be the equivalent to 1/2 the period (the high pulse) on the STEP PWM (assuming this is running at 50% duty cycle).  This is certainly a bit confusing, but running the RESET at a slower frequency keeps the RESET period without ever having to interact with the PWM registers.  Maybe I'm over thinking your application though :)
      EDIT:  I think the 87.5% is incorrect now that I'm thinking about it.  But the idea stays the same.  Might need to play with the numbers some.
      Kris
      Report Abuse
      • Reply
      on Aug 10 2012 13:32 PM
      am not very clear:)....Am I correct in the following code...I guess I made some mistake..
      void init(void)
      /* Step 1. Initialize System Control:
      PLL, WatchDog, enable Peripheral Clocks
      InitSysCtrl();
      /* Step 2. Initialize GPIO:
      InitSpiaGpio(); //Setup GPI/O for SPI-A functionality
      InitSciaGpio(); //Setup GPI/O for SCI-A functionality
      InitEPwm1Gpio(); //Setup GPI/O for ePWM1 functionality
      InitEPwm2Gpio(); //Setup GPI/O for ePWM2 functionality
      // InitEPwm3Gpio(); //Setup GPI/O for ePWM3 functionality
      InitTzGpio();
      /* Step 3. Clear all interrupts and initialize PIE vector table:
      Disable CPU interrupts
      DINT;
      /* Initialize PIE control registers to their default state.
      The default state is all PIE interrupts disabled and flags
      are cleared.
      InitPieCtrl();
      // Disable CPU interrupts and clear all CPU interrupt flags:
      IER = 0x0000;
      IFR = 0x0000;
      /* Initialize the PIE vector table with pointers to the shell Interrupt
      // Service Routines (ISR).
      // This will populate the entire table, even if the interrupt
      // is not used in this example. This is useful for debug purposes.
      InitPieVectTable();
      EALLOW; // This is needed to write to EALLOW protected registers
      PieVectTable.EPWM3_INT = &epwmstep_isr; //Enable interrupt on pwn3
      EDIS; // This is needed to disable write to EALLOW protected registers
      // Interrupts that are used in this example are re-mapped to
      // ISR functions found within this file.
      PieVectTable.EPWM2_TZINT = &epwm2_tzint_isr;
      // Step 4. Initialize all the Device Peripherals:
      // This function is found in F2806x_InitPeripherals.c
      spi_init(); // Initialize SPI
      spi_fifo_init(); // Initialize the SPI FIFO
      scia_fifo_init(); // Initialize the SCI FIFO
      scia_echoback_init(); // Initialize SCI for echoback
      EALLOW;
      SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
      EDIS;
      InitEPwm1Reset();
      InitEPwm2Cnv();
      InitEPwm2Step();
      InitEPwm2Example();
      EALLOW;
      SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
      EDIS;
      // Enable CPU INT3 which is connected to EPWM1-3 INT:
      IER |= M_INT3;
      IER |= M_INT2;
      // Enable EPWM INTn in the PIE: Group 3 interrupt 1-3
      PieCtrlRegs.PIEIER3.bit.INTx3 = 1;
      // Enable EPWM INTn in the PIE: Group 2 interrupt 1-3
      PieCtrlRegs.PIEIER2.bit.INTx2 = 1;
      // Enable global Interrupts and higher priority real-time debug events:
      EINT; // Enable Global interrupt INTM
      ERTM; // Enable Global real-time interrupt DBGM
      __interrupt void epwm2_tzint_isr(void)
      // Clear the flags - we will continue to take
      // this interrupt until the TZ pin goes high
      EALLOW;
      EPwm2Regs.TZCLR.bit.CBC = 1;
      EPwm2Regs.TZCLR.bit.INT = 1;
      EDIS;
      // Acknowledge this interrupt to receive more interrupts from group 2
      PieCtrlRegs.PIEACK.all = PIEACK_GROUP2;
      void InitEPwm2Example()
      // Enable TZ1 and TZ2 as one cycle-by-cycle trip sources
      EALLOW;
      EPwm2Regs.TZSEL.bit.CBC1 = 1;
      EPwm2Regs.TZSEL.bit.CBC2 = 1;
      // What do we want the TZ1 and TZ2 to do?
      EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
      EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
      // Enable TZ interrupt
      EPwm2Regs.TZEINT.bit.CBC = 1;
      EDIS;
      // Setup TBCLK
      // Set actions
      // Set Actions
      EPwm2Regs.AQCTLB.bit.ZRO = AQ_SET; // Set PWM3A on zero
      EPwm2Regs.AQCTLB.bit.PRD = AQ_CLEAR; // Clear PWM3A on period
      // Setup TBCLK
      // Set actions
      void InitEPwm2Cnv()
      // Setup TBCLK
      // Set actions
      void InitEPwm2Step(void)
      // Setup TBCLK
      EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;// Count up/down
      // Set Actions
      EPwm2Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
      EPwm2Regs.ETSEL.bit.INTEN = 1; // Enable INT
      EPwm2Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 1st event
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
