Dear,all
I have a problem of debugging the IPC code of the Concerto. I use the code provided by TI. They are [mtoc_ipcdrviers_lite_m3] and [mtoc_ipcdrviers_lite_c28]. After building the project, I loaded the .out into both of the two cores. When I began to step debug the code on M3, it stopped at the function of [ IPCMtoCBootControlSystem(unsigned long ulBootMode) ] . And I also can't receive the right data from the C28x. I am confused about it. Who can tell me how to deal with the problem.
I don't have an effective method of debugging the IPC. Who has a good method. Please send some useful materials to my email: wangkang_seu@163.com.
Thank you very much!
Dear Wang,
please take a look at this post, you might be seeing similar issues.
http://e2e.ti.com/support/microcontrollers/tms320c2000_32-bit_real-time_mcus/f/171/p/205604/729878.aspx#729878
Also, go through this post, it helps to be aware of these things.
http://e2e.ti.com/support/microcontrollers/tms320c2000_32-bit_real-time_mcus/f/171/p/167999/612985.aspx#612985
Pleae let me know if you have more questions on the subject,
Best Regards
Santosh
