• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » c2000 spi voltage problem on c28 core
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • c2000 spi voltage problem on c28 core
    This question is answered
    Adrien DES BOUILLONS
    Posted by Adrien DES BOUILLONS
    on Aug 16 2012 08:59 AM
    Intellectual350 points
    hello,
    I am using the SPI A on the c28 core of my F28M35x processor
    I tried the example provide by Kris Parrent here http://e2e.ti.com/support/microcontrollers/tms320c2000_32-bit_real-time_mcus/f/171/t/171156.aspx#625809
    My outputs have the good comportments but not the right voltage.
    The chipselects works fine but the SPISIMOA on GPIO16 and the SPICLKA on GPIO18 have only 20mV variation voltage between the high level and the low level
    My pin are not connected is it the problem ?
    Thanks in advance
    Adrien
    C2000 SPI F28M35x voltage
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Randy jue
      Posted by Randy jue
      on Aug 16 2012 09:36 AM
      Prodigy10 points
      thank you
      Report Abuse
      • Reply
    • Kris Parrent
      Posted by Kris Parrent
      on Aug 16 2012 09:39 AM
      Expert5985 points
      Adrien,
      Sounds like your muxing might not be configured right and you are only seeing the internal noise on the output.  Can you confirm?
      Kris
      Report Abuse
      • Reply
    • Adrien DES BOUILLONS
      on Aug 16 2012 09:54 AM
      Kris,
      My pins are configure like this one :
      GpioCtrlRegs.GPAQSEL2.bit.GPIO18 = 3;
      GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 1;
      And I use the setup_m3 example for the m3 core which enable the pull up
      yes I feel that I am seeing only the internal noise, but I don't know how I can see the right signal with the good voltage.
      Adrien
      Report Abuse
      • Reply
      on Aug 17 2012 10:09 AM
      Kris,
      I tried to continue some tests and it appears that all my SPI signals are good but not on the Docking station pins.
      They are good on the connectivity Mux of my control card and it's the same things for many others signals.
      I thought that signals on the connectivity Mux were the same on the connectivity Mux pins and on my docking station pins but it's not the case.
      Do you know why ?
      I have this problem for SPI A pins (GPIO16 - 19) and on the GBPMUX1 pins (GPIO32 - 47). I had not tried the others.
      Adrien
      Report Abuse
      • Reply
    • Kris Parrent
      on Aug 21 2012 23:33 PM
      Verified Answer
      Verified by Adrien DES BOUILLONS
      Expert5985 points
      Adrien,
      Did you manage to resolve this?  I assume you are setting the jumper on the connectivity mux between the two bottom rows to bring the signal from the mux to the docking station pin?
      Kris
      Report Abuse
      • Reply
      on Aug 22 2012 01:55 AM
      Kris,
      Yes my problem has been resolve ... by setting the jumper.
      Thanks a lot Kris.
      Adrien
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
