Hi! I have problem in following the tutorial procedures on TMS320F2808 eZdsp DSP/ BIOS. It happened in the step 2 of the following:
Testing With Code Composer Studio
DSP/BIOS - GS1
Now you can test the program. Since the program writes one line to a DSP/BIOS log, testing is simple.
Choose File®Load Program. In the Debug subfolder, select the program you just built, hello.out, and click Open.
Choose DSP/BIOS®Message Log. A Message Log area appears at the bottom of the Code Composer Studio window.
When I pressed Message Log, error message popped out that,' Unknown error. A required library is not loaded: vbd.dll.' I know where is the file, however, how to load it, I've already repeated the steps many times that I should not follow the procedures wrongly. Please advise how to config the Message Log.
