Eric,
For each device we provide a flash API. This API is used for all programming solutions whether it is through code composer studio, SDFlash, an SCI port, etc. The API does the work of program and erase. How the customer calls the API is up to them. In the case of the SCI they can download a small kernel through the SCI port using the bootloader in the boot ROM of the device. This kernel will then takeover the SCI communication and make calls to the flash API as required.
Jeff Stafford put together a great application report that describes this process. Take a look here:
http://focus.ti.com/general/docs/techdocsabstract.tsp?abstractName=spraaq2
Cheers,Lori
Original Question:
Hi Lori,
I just read your remarks on the url mentioned below.
You mention a way of programming through the SCI port.
Could you please let me know how the customer can do that, or any other way….?
Thanks and kind regards,
Eric.
