Dear friends,
at present, i am working on TMDXDOCK28M36 kit for testing F28M36P63C2.
My problem is Control suite example codes except blinky ,all other codes does not run on kit .
can anybody suggests me the right path.
Sanjeev.
Dear friends,
Sanjeev.
Hi Sanjeev,
sanjeev k said:My problem is Control suite example codes except blinky ,all other codes does not run on kit .
What issue are you facing? Any particular error? Do attach the screenshot of error window.
Gautam
sanjeev k said:i have not get any errors . code is programmed successfully.
For Testing purpose , i make a s/w break points to check it. and also set GPIO s to check.
You can refer this workshop which is meant for F28M35 but can be refered for F28M36:
http://processors.wiki.ti.com/index.php/F28M35x_Workshop
(Note: Use F28M36 based examples present in controlSuite)
Gautam
