Hi, I want to ask a tough question about adc-dac conversion.
I read an analog signal with f28377d board and then put the same signal on dac output. I observe both input analog signal and dac output signal. These signals are identical so dac and adc works well.
Howevever, when the frequency is lower than 500Hz threre is a delay between input signal and output signal. (about 250ms)
Why is that? I mean if I see the delay on high frequencies that could be logical but high frequencies are very well. The problem is low frequencies.
The code is below:
////adc_dac.h////
#ifndef ADC_DAC_H_
#define ADC_DAC_H_
//definitions for selecting ADC resolution
#define RESOLUTION_12BIT 0 //12-bit resolution
#define RESOLUTION_16BIT 1 //16-bit resolution (not supported for all variants)
//definitions for selecting ADC signal mode
#define SIGNAL_SINGLE 0 //single-ended channel conversions (12-bit mode only)
#define SIGNAL_DIFFERENTIAL 1 //differential pair channel conversions
#define TWO_PI 6.283185307179586476925286766559
void ConfigureADC(void);
void ConfigureDAC(void);
void SetupADCSoftware(void);
EALLOW;
AdcaRegs.ADCCTL2.bit.PRESCALE = 6; //set ADCCLK divider to /4
AdcaRegs.ADCCTL2.bit.RESOLUTION = RESOLUTION_12BIT;
AdcaRegs.ADCCTL2.bit.SIGNALMODE = SIGNAL_SINGLE;
AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1;
AdcbRegs.ADCCTL2.bit.PRESCALE = 6; //set ADCCLK divider to /4
AdcbRegs.ADCCTL2.bit.RESOLUTION = RESOLUTION_12BIT;
AdcbRegs.ADCCTL2.bit.SIGNALMODE = SIGNAL_SINGLE;
AdcbRegs.ADCCTL1.bit.INTPULSEPOS = 1;
AdcbRegs.ADCCTL1.bit.ADCPWDNZ = 1;
//DELAY_US(100);
EDIS;
EALLOW;
DacaRegs.DACCTL.bit.DACREFSEL=1; ////A09
DacaRegs.DACCTL.bit.MODE=0;
DacaRegs.DACCTL.bit.LOADMODE=0;
DacaRegs.DACOUTEN.bit.DACOUTEN=1;
DacbRegs.DACCTL.bit.DACREFSEL=1; ////A11
DacbRegs.DACCTL.bit.MODE=0;
DacbRegs.DACCTL.bit.LOADMODE=0;
DacbRegs.DACOUTEN.bit.DACOUTEN=1;
DaccRegs.DACCTL.bit.DACREFSEL=1; ////A14
DaccRegs.DACCTL.bit.MODE=0;
DaccRegs.DACCTL.bit.LOADMODE=0;
DaccRegs.DACOUTEN.bit.DACOUTEN=1;
//DELAY_US(100);
EDIS;
Uint16 acqps;
if(RESOLUTION_12BIT == AdcaRegs.ADCCTL2.bit.RESOLUTION){
acqps = 14; //75ns
else { //resolution is 16-bit
acqps = 63; //320ns
EALLOW;
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 2; //SOC0 will convert pin ANA15
AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC1CTL.bit.CHSEL = 3; //SOC1 will convert pin ANA17
AdcaRegs.ADCSOC1CTL.bit.ACQPS = acqps; //sample window is acqps + 1 SYSCLK cycles
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 1; //end of SOC1 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
AdcbRegs.ADCSOC0CTL.bit.CHSEL = 2; //SOC0 will convert pin ANA18
AdcbRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is acqps + 1 SYSCLK cycles
AdcbRegs.ADCSOC1CTL.bit.CHSEL = 3; //SOC1 will convert pin ANA20
AdcbRegs.ADCSOC1CTL.bit.ACQPS = acqps; //sample window is acqps + 1 SYSCLK cycles
AdcbRegs.ADCINTSEL1N2.bit.INT1SEL = 1; //end of SOC1 will set INT1 flag
AdcbRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcbRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
#endif /* ADC_DAC_H_ */
//////And the main/////
void main()
ConfigureADC();
ConfigureDAC();
SetupADCSoftware();
do {
while(AdcaRegs.ADCINTFLG.bit.ADCINT1 == 0);
AdcaResult0 = AdcaResultRegs.ADCRESULT0;
DacaRegs.DACVALS.bit.DACVALS=AdcaResult0;
} while(1);
Thank you for all your attention. Have a nice day.
