I am trying to interface eeprom IC (at24c02) with F28069 using I2C.In I2c_eeprom example I am write the different data on different memory location of eeprom,then read back the data of respective memory location.In read operation I get same data for all memory location which I write on last memory location.. I want to do random memory read operation.
Ex. write :- 0x1234 on 0x00001
0x5678 on 0x0002
Read :- 0x7878 on 0x0001
0x7878 on 0x0002
Please find attached file of code.
5773.Example_2806xI2C_eeprom.c
// TI File $Revision: /main/3 $ // Checkin $Date: March 3, 2011 16:16:13 $ //########################################################################### // // FILE: Example_2806xI2c_eeprom.c // // TITLE: F2806x I2C EEPROM Example // // ASSUMPTIONS: // // This program requires the F2806x header files. // // This program requires an external I2C EEPROM connected to // the I2C bus at address 0x50. // // As supplied, this project is configured for "boot to SARAM" // operation. The F2806x Boot Mode table is shown below. // // $Boot_Table: // // While an emulator is connected to your device, the TRSTn pin = 1, // which sets the device into EMU_BOOT boot mode. In this mode, the // peripheral boot modes are as follows: // // Boot Mode: EMU_KEY EMU_BMODE // (0xD00) (0xD01) // --------------------------------------- // Wait !=0x55AA X // I/O 0x55AA 0x0000 // SCI 0x55AA 0x0001 // Wait 0x55AA 0x0002 // Get_Mode 0x55AA 0x0003 // SPI 0x55AA 0x0004 // I2C 0x55AA 0x0005 // OTP 0x55AA 0x0006 // ECANA 0x55AA 0x0007 // SARAM 0x55AA 0x000A <-- "Boot to SARAM" // Flash 0x55AA 0x000B // Wait 0x55AA Other // // Write EMU_KEY to 0xD00 and EMU_BMODE to 0xD01 via the debugger // according to the Boot Mode Table above. Build/Load project, // Reset the device, and Run example // // $End_Boot_Table // // // Description: // // This program will write 1-14 words to EEPROM and read them back. // The data written and the EEPROM address written to are contained // in the message structure, I2cMsgOut1. The data read back will be // contained in the message structure I2cMsgIn1. // // //########################################################################### // $TI Release: 2806x C/C++ Header Files V1.10 $ // $Release Date: April 7, 2011 $ //########################################################################### #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // Note: I2C Macros used in this example can be found in the // F2806x_I2C_defines.h file // Prototype statements for functions found within this file. void I2CA_Init(void); Uint16 I2CA_WriteData(struct I2CMSG *msg); Uint16 I2CA_ReadData(struct I2CMSG *msg); interrupt void i2c_int1a_isr(void); void Write_Data(Uint8 id); void Read_Data(Uint8 id); Uint16 I2CA_Random_ReadData(struct I2CMSG *msg); Uint16 Error; #define I2C_SLAVE_ADDR 0x50 #define I2C_NUMBYTES 2 #define I2C_R_NUMBYTES 2 #define I2C_W_NUMBYTES 2 #define I2C_EEPROM_HIGH_ADDR 0x00 #define I2C_EEPROM_LOW_ADDR0 0x04 #define I2C_EEPROM_LOW_ADDR1 0x01 #define I2C_EEPROM_LOW_ADDR2 0x02 #define I2C_EEPROM_LOW_ADDR3 0x03 #define I2C_EEPROM_LOW_ADDR4 0x04 // Global variables // Two bytes will be used for the outgoing address, // thus only setup 14 bytes maximum struct I2CMSG I2cMsgOut1[3]={ { I2C_MSGSTAT_SEND_WITHSTOP, I2C_SLAVE_ADDR, I2C_W_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR0, 0x12, // Msg Byte 1 0x34 }, { I2C_MSGSTAT_SEND_WITHSTOP, I2C_SLAVE_ADDR, I2C_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR1, 0x56, // Msg Byte 1 0x78 }, { I2C_MSGSTAT_SEND_WITHSTOP, I2C_SLAVE_ADDR, I2C_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR2, 0x08, // Msg Byte 1 0x02 } };// Msg Byte 1 struct I2CMSG I2cMsgIn1[3]={ { I2C_MSGSTAT_SEND_NOSTOP, I2C_SLAVE_ADDR, I2C_R_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR0 }, { I2C_MSGSTAT_SEND_NOSTOP, I2C_SLAVE_ADDR, I2C_R_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR0 }, { I2C_MSGSTAT_SEND_NOSTOP, I2C_SLAVE_ADDR, I2C_R_NUMBYTES, I2C_EEPROM_HIGH_ADDR, I2C_EEPROM_LOW_ADDR2 } }; struct I2CMSG *CurrentMsgPtr; // Used in interrupts Uint16 PassCount; Uint16 FailCount; Uint16 Count; void main(void) { // Uint16 Error; Uint16 i; // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the F2806x_SysCtrl.c file. InitSysCtrl(); // Step 2. Initalize GPIO: // This example function is found in the F2806x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Setup only the GP I/O only for I2C functionality InitI2CGpio(); // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the F2806x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in F2806x_DefaultIsr.c. // This function is found in F2806x_PieVect.c. InitPieVectTable(); // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. EALLOW; // This is needed to write to EALLOW protected registers PieVectTable.I2CINT1A = &i2c_int1a_isr; EDIS; // This is needed to disable write to EALLOW protected registers // Step 4. Initialize all the Device Peripherals: // This function is found in F2806x_InitPeripherals.c // InitPeripherals(); // Not required for this example I2CA_Init(); // Step 5. User specific code // Clear Counters PassCount = 0; FailCount = 0; Count = 0; // Clear incoming message buffer for (i = 0; i < I2C_MAX_BUFFER_SIZE; i++) { I2cMsgIn1[0].MsgBuffer[i] = 0x0000; I2cMsgIn1[1].MsgBuffer[i] = 0x0000; I2cMsgIn1[2].MsgBuffer[i] = 0x0000; } // Enable interrupts required for this example // Enable I2C interrupt 1 in the PIE: Group 8 interrupt 1 PieCtrlRegs.PIEIER8.bit.INTx1 = 1; // Enable CPU INT8 which is connected to PIE group 8 IER |= M_INT8; EINT; // Application loop for(;;) { if(PassCount == (0)) { CurrentMsgPtr = &I2cMsgOut1[0]; Write_Data(0); } if(PassCount == (1)) { CurrentMsgPtr = &I2cMsgOut1[1]; Write_Data(1); } if(PassCount == (2)) { CurrentMsgPtr = &I2cMsgOut1[0]; Write_Data(2); } if(PassCount == (3)) { CurrentMsgPtr = &I2cMsgIn1[0]; Read_Data(0); } if(PassCount == (4)) { CurrentMsgPtr = &I2cMsgIn1[1]; Read_Data(1); } if(PassCount == (5)) { CurrentMsgPtr = &I2cMsgIn1[0]; Read_Data(2); } } // end of for(;;) } // end of main void I2CA_Init(void) { // Initialize I2C I2caRegs.I2CSAR = 0x0050; // Slave address - EEPROM control code I2caRegs.I2CPSC.all = 6; // Prescaler - need 7-12 Mhz on module clk I2caRegs.I2CCLKL = 10; // NOTE: must be non zero I2caRegs.I2CCLKH = 5; // NOTE: must be non zero I2caRegs.I2CIER.all = 0x24; // Enable SCD & ARDY interrupts I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset // Stop I2C when suspended I2caRegs.I2CFFTX.all = 0x6000; // Enable FIFO mode and TXFIFO I2caRegs.I2CFFRX.all = 0x2040; // Enable RXFIFO, clear RXFFINT, return; } Uint16 I2CA_WriteData(struct I2CMSG *msg) { Uint16 i; // Wait until the STP bit is cleared from any previous master communication. // Clearing of this bit by the module is delayed until after the SCD bit is // set. If this bit is not checked prior to initiating a new message, the // I2C could get confused. if (I2caRegs.I2CMDR.bit.STP == 1) { return I2C_STP_NOT_READY_ERROR; } // Setup slave address I2caRegs.I2CSAR = msg->SlaveAddress; // Check if bus busy if (I2caRegs.I2CSTR.bit.BB == 1) { return I2C_BUS_BUSY_ERROR; } // Setup number of bytes to send // MsgBuffer + Address I2caRegs.I2CCNT = msg->NumOfBytes+2; // Setup data to send I2caRegs.I2CDXR = msg->MemoryHighAddr; I2caRegs.I2CDXR = msg->MemoryLowAddr; // for (i=0; i<msg->NumOfBytes-2; i++) for (i=0; i<msg->NumOfBytes; i++) { I2caRegs.I2CDXR = *(msg->MsgBuffer+i); } // Send start as master transmitter I2caRegs.I2CMDR.all = 0x6E20; return I2C_SUCCESS; } Uint16 I2CA_ReadData(struct I2CMSG *msg) { // Wait until the STP bit is cleared from any previous master communication. // Clearing of this bit by the module is delayed until after the SCD bit is // set. If this bit is not checked prior to initiating a new message, the // I2C could get confused. if (I2caRegs.I2CMDR.bit.STP == 1) { return I2C_STP_NOT_READY_ERROR; } I2caRegs.I2CSAR = msg->SlaveAddress; if(msg->MsgStatus == I2C_MSGSTAT_SEND_NOSTOP) { // Check if bus busy if (I2caRegs.I2CSTR.bit.BB == 1) { return I2C_BUS_BUSY_ERROR; } I2caRegs.I2CCNT = 2; I2caRegs.I2CDXR = msg->MemoryHighAddr; I2caRegs.I2CDXR = msg->MemoryLowAddr; I2caRegs.I2CMDR.all = 0x2620; // Send data to setup EEPROM address } else if(msg->MsgStatus == I2C_MSGSTAT_RESTART) { // I2caRegs.I2CSAR = (msg->SlaveAddress | 0x01); I2caRegs.I2CCNT = 4; // Setup how many bytes to expect I2caRegs.I2CMDR.all = 0x2C20; // Send restart as master receiver } return I2C_SUCCESS; } interrupt void i2c_int1a_isr(void) // I2C-A { Uint16 IntSource, i; // Read interrupt source IntSource = I2caRegs.I2CISRC.all; // Interrupt source = stop condition detected if(IntSource == I2C_SCD_ISRC) { // If completed message was writing data, reset msg to inactive state if (CurrentMsgPtr->MsgStatus == I2C_MSGSTAT_WRITE_BUSY) { CurrentMsgPtr->MsgStatus = I2C_MSGSTAT_INACTIVE; FailCount++; PassCount++; } else { // If a message receives a NACK during the address setup portion of the // EEPROM read, the code further below included in the register access ready // interrupt source code will generate a stop condition. After the stop // condition is received (here), set the message status to try again. // User may want to limit the number of retries before generating an error. if(CurrentMsgPtr->MsgStatus == I2C_MSGSTAT_SEND_NOSTOP_BUSY) { CurrentMsgPtr->MsgStatus = I2C_MSGSTAT_SEND_NOSTOP; } // If completed message was reading EEPROM data, reset msg to inactive state // and read data from FIFO. else if (CurrentMsgPtr->MsgStatus == I2C_MSGSTAT_READ_BUSY) { CurrentMsgPtr->MsgStatus = I2C_MSGSTAT_INACTIVE; for(i=0; i < 2; i++) { CurrentMsgPtr->MsgBuffer[i] = I2caRegs.I2CDRR; } PassCount++; Count++; } } } // end of stop condition detected // Interrupt source = Register Access Ready // This interrupt is used to determine when the EEPROM address setup portion of the // read data communication is complete. Since no stop bit is commanded, this flag // tells us when the message has been sent instead of the SCD flag. If a NACK is // received, clear the NACK bit and command a stop. Otherwise, move on to the read // data portion of the communication. else if(IntSource == I2C_ARDY_ISRC) { if(I2caRegs.I2CSTR.bit.NACK == 1) { I2caRegs.I2CMDR.bit.STP = 1; I2caRegs.I2CSTR.all = I2C_CLR_NACK_BIT; } else if(CurrentMsgPtr->MsgStatus == I2C_MSGSTAT_SEND_NOSTOP_BUSY) { CurrentMsgPtr->MsgStatus = I2C_MSGSTAT_RESTART; } } // end of register access ready else { // Generate some error due to invalid interrupt source asm(" ESTOP0"); } // Enable future I2C (PIE Group 8) interrupts PieCtrlRegs.PIEACK.all = PIEACK_GROUP8; } //=========================================================================== // No more. //=========================================================================== void Write_Data(Uint8 id) { // Check the outgoing message to see if it should be sent. // In this example it is initialized to send with a stop bit. if(I2cMsgOut1[id].MsgStatus == I2C_MSGSTAT_SEND_WITHSTOP) { Error = I2CA_WriteData(&I2cMsgOut1[id]); // If communication is correctly initiated, set msg status to busy // and update CurrentMsgPtr for the interrupt service routine. // Otherwise, do nothing and try again next loop. Once message is // initiated, the I2C interrupts will handle the rest. Search for // i2c_int1a_isr in this file. if (Error == I2C_SUCCESS) { CurrentMsgPtr = &I2cMsgOut1[id]; I2cMsgOut1[id].MsgStatus = I2C_MSGSTAT_WRITE_BUSY; } } }// end of write section void Read_Data(Uint8 id) { if(I2cMsgIn1[id].MsgStatus == I2C_MSGSTAT_SEND_NOSTOP) { // EEPROM address setup portion while(I2CA_ReadData(&I2cMsgIn1[id]) != I2C_SUCCESS) // while(I2CA_Random_ReadData(&I2cMsgIn1[id]) != I2C_SUCCESS) { // Maybe setup an attempt counter to break an infinite while // loop. The EEPROM will send back a NACK while it is performing // a write operation. Even though the write communique is // complete at this point, the EEPROM could still be busy // programming the data. Therefore, multiple attempts are // necessary. } // Update current message pointer and message status CurrentMsgPtr = &I2cMsgIn1[id]; I2cMsgIn1[id].MsgStatus = I2C_MSGSTAT_SEND_NOSTOP_BUSY; } // Once message has progressed past setting up the internal address // of the EEPROM, send a restart to read the data bytes from the // EEPROM. Complete the communique with a stop bit. MsgStatus is // updated in the interrupt service routine. else if(I2cMsgIn1[id].MsgStatus == I2C_MSGSTAT_RESTART) { // Read data portion while(I2CA_ReadData(&I2cMsgIn1[id]) != I2C_SUCCESS) // while(I2CA_Random_ReadData(&I2cMsgIn1[id]) != I2C_SUCCESS) { // Maybe setup an attempt counter to break an infinite while // loop. } // Update current message pointer and message status CurrentMsgPtr = &I2cMsgIn1[id]; I2cMsgIn1[id].MsgStatus = I2C_MSGSTAT_READ_BUSY; } }// end of read section
Please do needfully.
Waiting for reply.
